[Swift-user] error in capitalise.swift when following tutorial on Mac
Yadu Nand
yadudoc1729 at gmail.com
Mon Jul 1 19:49:08 CDT 2013
Hi Andrew,
Thanks for reporting this. We have a intermediate fix for the bug.
If you could please copy the following file :
http://ci.uchicago.edu/~wilde/_swiftwrap to the libexec folder in the
0.94 release folder, the bug should be fixed.
This is a Mac only bug which which uses an app with stdin. Please let
us know that if that works for you, or if you need any help.
Yadu
On Mon, Jul 1, 2013 at 4:35 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Andrew, I suspect (but am not yet sure) that you've discovered a bug in Swift argument passing.
> A member of the team is looking into this. Thanks for the report.
> - Mike
>> From: "Andrew Shewmaker" <agshew at gmail.com>
>> To: swift-user at ci.uchicago.edu
>> Sent: Monday, July 1, 2013 4:23:33 PM
>> Subject: [Swift-user] error in capitalise.swift when following tutorial on Mac
>> Hi,
>> I like the look of swift, but I've run into an issue as I'm learning
>> about it.
>> I'm obviously doing something wrong, but I can't seem to see it. I've
>> attached my version of capitalise.swift and tc.data and some files
>> generated
>> by the execution. Any help would be appreciated.
>> I've been able to run a few of the example swift programs
>> on my Mac (latest version), but when I try capitilise.swift, I get:
>> stderr.txt:
>> /var/tmp/capitalise-20130701-1448-bcjykob9/shared/_swiftwrap: line
>> 507: : command not found
>> stdout.txt:
>> Caused by:
>> Application /usr/bin/tr failed with an exit code of 127
>> capitalise, capitalise.swift, line 15
>> I did add tr to the tc.data file, and tr works when run by hand.
>> With verbosity, I see:
>> TASK_DEFINITION: Task(type=JOB_SUBMISSION,
>> identity=urn:0-1-1-1372713225973) is /bin/bash shared/_swiftwrap
>> tr-btzz0qbl -jobdir b -scratch -e /usr/bin/tr -out capitalise.2.txt
>> -err stderr.txt -i capitalise.1.txt -d -if capitalise.1.txt -of
>> capitalise.2.txt -k -cdmfile -status files -a [a-z] [A-Z]
>> Submit: in: /var/tmp/capitalise-20130701-1513-3sldolzb command:
>> /bin/bash
>> /var/tmp/capitalise-20130701-1513-3sldolzb/shared/_swiftwrap
>> jobs queued: 0
>> jobs queued: 0
>> FAILURE jobid=tr-btzz0qbl - Failure file found
>> jobs queued: 0
>> jobs queued: 0
>> jobs queued: 0
>> jobs queued: 0
>> NO_STATUS_FILE jobid=tr-btzz0qbl - Error file missing
>> jobs queued: 0
>> jobs queued: 0
>> jobs queued: 0
>> jobs queued: 0
>> jobs queued: 0
>> END_FAILURE thread=0-1 tr=tr
>> Execution failed:
>> Exception in tr:
>> Arguments: [[a-z], [A-Z]]
>> Host: localhost
>> Directory: capitalise-20130701-1513-3sldolzb/jobs/b/tr-btzz0qbl
>> stderr.txt:
>> /var/tmp/capitalise-20130701-1513-3sldolzb/shared/_swiftwrap: line
>> stdout.txt:
>> Caused by:
>> Detailed exception:
>> Exception in tr:
>> Host: localhost
>> stderr.txt:
>> stdout.txt:
>> Caused by: Application /usr/bin/tr failed with an exit code of 127
>> Thanks,
>> Andrew Shewmaker
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
More information about the Swift-user
