[Swift-user] Questions about concurrent_mapper and parameter lists
Jorgen Brandt joergen.brandt at onlinehome.de
Tue Apr 30 03:31:20 CDT 2013
Dear Sir or Madam,
I just started using Swift. There is several things, though, I cannot
figure out.
- I want to perform a computation in parallel, using the filesys_mapper
to parse my input directory and the concurrent_mapper to create the
corresponding output files. The output files are created temporarily but
they are not there any more, when the execution finishes. What do I do
wrong? (See listings below.)
- I want to append an array of filenames (of which I do not know its
length at compile-time) to the parameter list of an app. I tried several
things but had no luck so far. I'd expected that something like
type Text;
app( Text o )mycatReduce( Text[] inputset ) {
  cat @inputset stdout=@o;
would work and indeed the above snippet survives compilation. But the
stage-in does not seem to work. Cat complains about its input not being
there. (Listings below.)
I've been googling around but the only thing I've found that may relate
to this problem is your article in Computer 42 (11) from 2009 in which
it says
<< Swift's foreach construct performs a simple map operation, and the
act of passing a multimember dataset to a procedure provides a simple
and natural way to implement reduction operations. >>
No example was given though.
I appreciate any help and hope not to steal too much of your time.
Best regards
Jorgen
The rest of this email explains in detail what I have done: I am
currently working with Swift 0.94 (RC4). I have a working directory
containing a folder 'infileset'. this folder contains 2 files: 'a.txt'
and 'b.txt'.
--- Start Listing -------------------------------------------
jorgen at turing:~/workspace_set/swift/test$ ls infileset
a.txt  b.txt
jorgen at turing:~/workspace_set/swift/test$ cat infileset/a.txt
Hello
jorgen at turing:~/workspace_set/swift/test$ cat infileset/b.txt
World
--- End Listing ---------------------------------------------
In this working directory I also store my swift-script.
jorgen at turing:~/workspace_set/swift/test$ cat test_simple.swift
type Text;
app( Text o )mycat( Text input ) {
  cat @input stdout=@o;
( Text[] oset )mycatMap( Text[] inputset ) {
  foreach input, i in inputset {
    oset[ i ] = mycat( input );
    trace( @filename( oset[ i ] ) );
Text[] p <filesys_mapper; location="infileset", suffix=".txt">;
Text[] q <concurrent_mapper; location="outfileset", prefix="map_output",
suffix=".txt">;
Text r <"outfileset/reduce_output.txt">;
q = mycatMap( p );    // So far so good, but the output q is not persistent.
r = mycatReduce( p ); // Drops out with 'infileset/a.txt
infileset/b.txt: No such
                      // file or directory'
Running this script yields the following:
~/software/swift-0.94/bin/swift test_simple.swift
Swift 0.94 swift-r6320 cog-r3615
RunID: 20130430-1017-sfans555
Progress:  time: Tue, 30 Apr 2013 10:17:56 +0200
SwiftScript trace: outfileset/_concurrent/map_output--array//elt-0.txt
SwiftScript trace: outfileset/_concurrent/map_output--array//elt-1.txt
Progress:  time: Tue, 30 Apr 2013 10:17:57 +0200  Selecting site:1
Checking status:1  Finished successfully:1
Execution failed:
	Exception in cat:
    Arguments: [infileset/a.txt infileset/b.txt]
    Host: localhost
    Directory: test_simple-20130430-1017-sfans555/jobs/c/cat-ceb95s8l
    stderr.txt: /bin/cat: infileset/a.txt infileset/b.txt: No such file
or directory
    stdout.txt:
Caused by:
	File not found:
/var/tmp/test_simple-20130430-1017-sfans555/shared/outfileset/reduce_output.txt
	mycatReduce, test_simple.swift, line 25
The script created an .rlog file called
test_simple-20130430-1017-sfans555.0.rlog.
# Log file created Tue Apr 30 10:17:56 CEST 2013
:q.[0]!file://localhost/outfileset/_concurrent/map_output--array//elt-0.txt
Also, the script created a swift.log file with the following content:
jorgen at turing:~/workspace_set/swift/test$ cat swift.log
2013-04-30 10:17:53,338+0200 DEBUG Loader Swift started
Eventually, the script created a log file called
test_simple-20130430-1017-sfans555.log.
2013-04-30 10:17:53,377+0200 DEBUG Loader arguments: [test_simple.swift]
2013-04-30 10:17:53,381+0200 DEBUG Loader Max heap: 954466304
2013-04-30 10:17:53,383+0200 DEBUG textfiles BEGIN SWIFTSCRIPT:
type Text;
suffix=".txt">;
2013-04-30 10:17:53,383+0200 DEBUG textfiles END SWIFTSCRIPT:
2013-04-30 10:17:53,384+0200 INFO  Loader test_simple.swift: source file
is new. Recompiling.
2013-04-30 10:17:54,647+0200 DEBUG Loader Swift configuration ([]):
{pgraph.node.options=color="seagreen", style="filled",
clustering.min.time=60, clustering.queue.delay=4,
sites.file=/home/jorgen/software/swift-0.94/bin/../etc/sites.xml,
ticker.prefix=Progress:  time:, provenance.log=false,
kickstart.enabled=maybe,
tc.file=/home/jorgen/software/swift-0.94/bin/../etc/tc.data,
foreach.max.threads=16384, lazy.errors=false, ticker.date.format=,
sitedir.keep=false, throttle.score.job.factor=0.2,
kickstart.always.transfer=false, throttle.host.submit=2,
replication.limit=3, clustering.enabled=false, pgraph=false,
file.gc.enabled=true, replication.min.queue.time=60,
wrapper.parameter.mode=args, replication.enabled=false,
throttle.transfers=4, wrapperlog.always.transfer=false,
throttle.submit=4, pgraph.graph.options=splines="compound",
rankdir="TB", caching.algorithm=LRU,
logfile=test_simple-20130430-1017-sfans555.log,
use.wrapper.staging=false, tracing.enabled=true,
provider.staging.pin.swiftfiles=false, wrapper.invocation.mode=absolute,
mapping.checker=on, execution.retries=0, cdm.broadcast.mode=file,
status.mode=files, use.provider.staging=false, throttle.file.operations=8}
2013-04-30 10:17:54,647+0200 DEBUG textfiles using default sites file
2013-04-30 10:17:54,655+0200 DEBUG VDL2ExecutionContext Stack dump:
Level 1
[iA = 0, iB = 0, bA = false, bB = false]
	vdl:instanceconfig = Swift configuration ([]):
	vdl:operation = run
	swift.home = /home/jorgen/software/swift-0.94/bin/..
	PATH_SEPARATOR = /
2013-04-30 10:17:54,657+0200 INFO  VDL2ExecutionContext swift.home =
2013-04-30 10:17:55,636+0200 INFO  swift Using sites file:
2013-04-30 10:17:55,702+0200 INFO  swift Using tc.data:
2013-04-30 10:17:55,830+0200 INFO  AbstractScheduler Setting resources
to: {localhost=localhost}
2013-04-30 10:17:56,660+0200 INFO  swift Swift 0.94 swift-r6320 cog-r3615
2013-04-30 10:17:56,661+0200 INFO  swift RUNID id=run:20130430-1017-sfans555
2013-04-30 10:17:56,746+0200 INFO  TRACE DECLARE, line 19, thread main, p
2013-04-30 10:17:56,760+0200 INFO  TRACE VARIABLE, line 19, thread main,
p INITIALIZED <filesys_mapper; input = true, location = "infileset",
suffix = ".txt">
2013-04-30 10:17:56,777+0200 INFO  TRACE VARIABLE, line 19, thread main,
p MAPPING [0], file://localhost/infileset/a.txt
2013-04-30 10:17:56,778+0200 INFO  TRACE VARIABLE, line 19, thread main,
p MAPPING [1], file://localhost/infileset/b.txt
2013-04-30 10:17:56,784+0200 INFO  TRACE DECLARE, line 20, thread main, q
2013-04-30 10:17:56,785+0200 INFO  TRACE VARIABLE, line 20, thread main,
q INITIALIZED <concurrent_mapper; input = null, location = "outfileset",
prefix = _concurrent/map_output-, thread_prefix = , suffix = ".txt">
2013-04-30 10:17:56,786+0200 INFO  TRACE VARIABLE, line 21, thread main,
r INITIALIZED <single_file_mapper; input = null, file =
outfileset/reduce_output.txt>
2013-04-30 10:17:56,787+0200 INFO  TRACE DECLARE, line 21, thread main,
r <single_file_mapper; input = null, file = outfileset/reduce_output.txt>
2013-04-30 10:17:56,809+0200 INFO  TRACE CALL, line 7, thread 0-5,
mycatMap(inputset = p)
2013-04-30 10:17:56,810+0200 INFO  TRACE APPCALL, line 15, thread 0-6,
mycatReduce(inputset = p)
2013-04-30 10:17:56,811+0200 DEBUG swift PROCEDURE line=15 thread=0-6
name=mycat_reduce
2013-04-30 10:17:56,812+0200 INFO  swift STARTCOMPOUND thread=0-5
name=mycat_map
2013-04-30 10:17:56,830+0200 INFO  RuntimeStats$ProgressTicker
2013-04-30 10:17:56,833+0200 DEBUG swift FOREACH_IT_START line=9
thread=0-5-1-0
2013-04-30 10:17:56,836+0200 DEBUG swift SCOPE thread=0-5-1-0
2013-04-30 10:17:56,837+0200 DEBUG swift INTERNALPROC_START
thread=0-5-1-0-1 name=trace
2013-04-30 10:17:56,840+0200 WARN  trace SwiftScript trace:
2013-04-30 10:17:56,840+0200 DEBUG swift INTERNALPROC_END
2013-04-30 10:17:56,836+0200 DEBUG swift FOREACH_IT_START line=9
thread=0-5-1-1
2013-04-30 10:17:56,841+0200 DEBUG swift SCOPE thread=0-5-1-1
2013-04-30 10:17:56,841+0200 DEBUG swift INTERNALPROC_START
thread=0-5-1-1-1 name=trace
2013-04-30 10:17:56,842+0200 INFO  TRACE APPCALL, line 3, thread
0-5-1-1-0, mycat(input = ?p[1])
2013-04-30 10:17:56,842+0200 DEBUG swift PROCEDURE line=3
thread=0-5-1-1-0 name=mycat
2013-04-30 10:17:56,843+0200 WARN  trace SwiftScript trace:
2013-04-30 10:17:56,838+0200 INFO  TRACE APPCALL, line 3, thread
0-5-1-0-0, mycat(input = ?p[0])
2013-04-30 10:17:56,835+0200 INFO  swift START thread=0-6 tr=cat
2013-04-30 10:17:56,849+0200 DEBUG swift PROCEDURE line=3
thread=0-5-1-0-0 name=mycat
2013-04-30 10:17:56,851+0200 INFO  swift START thread=0-5-1-1-0 tr=cat
2013-04-30 10:17:56,859+0200 DEBUG swift INTERNALPROC_END
2013-04-30 10:17:56,855+0200 INFO  swift START thread=0-5-1-0-0 tr=cat
2013-04-30 10:17:56,882+0200 INFO  WeightedHostScoreScheduler Sorted:
[localhost:0.000(1.000):0/1 overload: 0]
CONTACT_SELECTED host=localhost, score=1.000
2013-04-30 10:17:56,887+0200 INFO  GlobalSubmitQueue No global submit
throttle set. Using default (1024)
2013-04-30 10:17:56,891+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,893+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,896+0200 INFO  swift START host=localhost -
Initializing shared directory
2013-04-30 10:17:56,909+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,931+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,935+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,936+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,940+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,943+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,945+0200 INFO  swift END host=localhost - Done
initializing shared directory
2013-04-30 10:17:56,947+0200 DEBUG swift THREAD_ASSOCIATION
jobid=cat-beb95s8l thread=0-5-1-0-0-1 host=localhost
replicationGroup=aeb95s8l
2013-04-30 10:17:56,961+0200 INFO  swift START jobid=cat-beb95s8l
host=localhost - Initializing directory structure
2013-04-30 10:17:56,964+0200 INFO  swift START path=infileset
dir=test_simple-20130430-1017-sfans555/shared - Creating directory structure
2013-04-30 10:17:56,965+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,966+0200 INFO  swift START
path=outfileset/_concurrent/map_output--array/
2013-04-30 10:17:56,967+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,968+0200 INFO  swift END jobid=cat-beb95s8l - Done
initializing directory structure
2013-04-30 10:17:56,969+0200 INFO  swift START jobid=cat-beb95s8l -
Staging in files
2013-04-30 10:17:56,981+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:56,986+0200 DEBUG swift CDM:
file://localhost/infileset/a.txt : DEFAULT
2013-04-30 10:17:56,997+0200 DEBUG swift FILE_STAGE_IN_START file=a.txt
srchost=localhost srcdir=infileset srcname=a.txt desthost=localhost
destdir=test_simple-20130430-1017-sfans555/shared/infileset
provider=file policy=DEFAULT
2013-04-30 10:17:57,013+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:57,014+0200 DEBUG swift FILE_STAGE_IN_END file=a.txt
destdir=test_simple-20130430-1017-sfans555/shared/infileset provider=file
2013-04-30 10:17:57,015+0200 INFO  swift END jobid=cat-beb95s8l -
Staging in finished
2013-04-30 10:17:57,017+0200 DEBUG swift JOB_START jobid=cat-beb95s8l
tr=cat arguments=[infileset/a.txt]
tmpdir=test_simple-20130430-1017-sfans555/jobs/b/cat-beb95s8l host=localhost
2013-04-30 10:17:57,022+0200 DEBUG textfiles BEGIN TC:
#This is the transformation catalog.
#It comes pre-configured with a number of simple transformations with
#paths that are likely to work on a linux box. However, on some systems,
#the paths to these executables will be different (for example, sometimes
#some of these programs are found in /usr/bin rather than in /bin)
#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
#there must be no trailing whitespace at the end of each line.
# sitename  transformation  path   INSTALLED  platform  profiles
localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
localhost 	cp 		/bin/cp         INSTALLED	INTEL32::LINUX	null
localhost 	touch 		/bin/touch      INSTALLED	INTEL32::LINUX	null
localhost	wc		/usr/bin/wc	INSTALLED	INTEL32::LINUX	null
localhost	sleep		/bin/sleep	null	null 	null
2013-04-30 10:17:57,022+0200 DEBUG textfiles END TC:
2013-04-30 10:17:57,048+0200 INFO  GridExec TASK_DEFINITION:
Task(type=JOB_SUBMISSION, identity=urn:0-5-1-0-0-1-1367309875676) is
/bin/bash /var/tmp/test_simple-20130430-1017-sfans555/shared/_swiftwrap
cat-beb95s8l -jobdir b -scratch  -e /bin/cat -out
outfileset/_concurrent/map_output--array//elt-0.txt -err stderr.txt -i
-d infileset|outfileset/_concurrent/map_output--array/ -if
infileset/a.txt -of outfileset/_concurrent/map_output--array//elt-0.txt
-k  -cdmfile  -status files -a infileset/a.txt
2013-04-30 10:17:57,054+0200 INFO  JobSubmissionTaskHandler Submit: in:
/var/tmp/test_simple-20130430-1017-sfans555 command: /bin/bash
2013-04-30 10:17:57,165+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:57,168+0200 DEBUG swift START jobid=cat-beb95s8l
2013-04-30 10:17:57,170+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:57,171+0200 INFO  swift SUCCESS jobid=cat-beb95s8l -
Success file found
2013-04-30 10:17:57,172+0200 DEBUG swift STAGING_OUT jobid=cat-beb95s8l
2013-04-30 10:17:57,174+0200 INFO  swift START jobid=cat-beb95s8l -
Staging out files
2013-04-30 10:17:57,175+0200 DEBUG swift stageouts: [[$, q[0]:Text - Open]]
2013-04-30 10:17:57,183+0200 DEBUG swift FILE_STAGE_OUT_START
srcname=elt-0.txt
srcdir=test_simple-20130430-1017-sfans555/shared/outfileset/_concurrent/map_output--array/
srchost=localhost destdir=outfileset/_concurrent/map_output--array/
desthost=localhost provider=file
2013-04-30 10:17:57,187+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:57,189+0200 DEBUG swift CDM:
file://localhost/outfileset/_concurrent/map_output--array//elt-0.txt :
DEFAULT
2013-04-30 10:17:57,193+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:57,195+0200 DEBUG swift FILE_STAGE_OUT_END
srcname=elt-0.txt
2013-04-30 10:17:57,197+0200 INFO  LateBindingScheduler jobs queued: 2
2013-04-30 10:17:57,201+0200 INFO  swift END jobid=cat-beb95s8l -
Staging out finished
2013-04-30 10:17:57,206+0200 DEBUG swift JOB_END jobid=cat-beb95s8l
2013-04-30 10:17:57,207+0200 INFO  swift END_SUCCESS thread=0-5-1-0-0 tr=cat
2013-04-30 10:17:57,209+0200 DEBUG swift PROCEDURE_END line=3
2013-04-30 10:17:57,210+0200 DEBUG swift FOREACH_IT_END line=9
thread=0-5-1-0
2013-04-30 10:17:57,698+0200 INFO  WeightedHostScoreScheduler Sorted:
[localhost:1.300(2.109):0/1 overload: 0]
CONTACT_SELECTED host=localhost, score=2.109
2013-04-30 10:17:57,704+0200 DEBUG swift THREAD_ASSOCIATION
jobid=cat-ceb95s8l thread=0-6-1 host=localhost replicationGroup=8eb95s8l
2013-04-30 10:17:57,712+0200 INFO  swift START jobid=cat-ceb95s8l
2013-04-30 10:17:57,716+0200 INFO  swift START path=outfileset
2013-04-30 10:17:57,717+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,719+0200 INFO  swift END jobid=cat-ceb95s8l - Done
2013-04-30 10:17:57,720+0200 INFO  swift START jobid=cat-ceb95s8l -
Staging in files
2013-04-30 10:17:57,725+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,726+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,728+0200 DEBUG swift CDM:
file://localhost/infileset/b.txt : DEFAULT
2013-04-30 10:17:57,730+0200 DEBUG swift FILE_STAGE_IN_START file=b.txt
srchost=localhost srcdir=infileset srcname=b.txt desthost=localhost
2013-04-30 10:17:57,734+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,735+0200 DEBUG swift FILE_STAGE_IN_END file=b.txt
2013-04-30 10:17:57,736+0200 INFO  swift END jobid=cat-ceb95s8l -
Staging in finished
2013-04-30 10:17:57,737+0200 DEBUG swift JOB_START jobid=cat-ceb95s8l
tr=cat arguments=[infileset/a.txt infileset/b.txt]
tmpdir=test_simple-20130430-1017-sfans555/jobs/c/cat-ceb95s8l host=localhost
2013-04-30 10:17:57,742+0200 INFO  GridExec TASK_DEFINITION:
Task(type=JOB_SUBMISSION, identity=urn:0-6-1-1367309875696) is /bin/bash
shared/_swiftwrap cat-ceb95s8l -jobdir c -scratch  -e /bin/cat -out
outfileset/reduce_output.txt -err stderr.txt -i -d infileset|outfileset
-if infileset/a.txt|infileset/b.txt -of outfileset/reduce_output.txt -k
 -cdmfile  -status files -a infileset/a.txt infileset/b.txt
2013-04-30 10:17:57,743+0200 INFO  JobSubmissionTaskHandler Submit: in:
2013-04-30 10:17:57,865+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,867+0200 INFO  RuntimeStats$ProgressTicker
Selecting site:1  Checking status:1  Finished successfully:1
2013-04-30 10:17:57,870+0200 DEBUG swift START jobid=cat-ceb95s8l
2013-04-30 10:17:57,879+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,880+0200 INFO  swift FAILURE jobid=cat-ceb95s8l -
Failure file found
2013-04-30 10:17:57,884+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,889+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,892+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,895+0200 DEBUG swift STAGING_OUT jobid=cat-ceb95s8l
2013-04-30 10:17:57,896+0200 INFO  swift START jobid=cat-ceb95s8l -
Staging out files
2013-04-30 10:17:57,897+0200 DEBUG swift stageouts: [[$, r:Text - Open]]
2013-04-30 10:17:57,907+0200 DEBUG swift FILE_STAGE_OUT_START
srcname=reduce_output.txt
srchost=localhost destdir=outfileset desthost=localhost provider=file
2013-04-30 10:17:57,909+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,910+0200 DEBUG swift CDM:
file://localhost/outfileset/reduce_output.txt : DEFAULT
2013-04-30 10:17:57,927+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,928+0200 INFO  swift NO_STATUS_FILE
jobid=cat-ceb95s8l - Error file missing
2013-04-30 10:17:57,929+0200 DEBUG swift APPLICATION_EXCEPTION
jobid=cat-ceb95s8l - Application exception: Caused by: File not found:
2013-04-30 10:17:57,941+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,948+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,952+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,955+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,958+0200 INFO  LateBindingScheduler jobs queued: 1
2013-04-30 10:17:57,962+0200 INFO  swift END_FAILURE thread=0-6 tr=cat
2013-04-30 10:17:57,965+0200 DEBUG VDL2ExecutionContext Karajan level
error: Exception in cat:
    Host: localhost
or directory
    stdout.txt:  at
	sys:exception @ vdl-int.k, line: 599
	sys:throw @ vdl-int.k, line: 598
	sys:catch @ vdl-int.k, line: 565
	sys:try @ vdl-int.k, line: 467
	task:allocatehost @ vdl-int.k, line: 417
	vdl:execute2 @ execute-default.k, line: 23
	sys:ignoreerrors @ execute-default.k, line: 21
	sys:parallelfor @ execute-default.k, line: 20
	sys:restartonerror @ execute-default.k, line: 16
	vdl:throttled @ execute-default.k, line: 14
	sys:try @ execute-default.k, line: 13
	sys:if @ execute-default.k, line: 12
	sys:then @ execute-default.k, line: 11
	sys:if @ execute-default.k, line: 10
	vdl:execute @ test_simple.kml, line: 109
	mycat_reduce @ test_simple.kml, line: 223
	sys:uparallel @ test_simple.kml, line: 179
	vdl:mainp @ test_simple.kml, line: 178
	mainp @ vdl.k, line: 118
	vdl:mains @ test_simple.kml, line: 176
	rlog:restartlog @ test_simple.kml, line: 175
	kernel:project @ test_simple.kml, line: 2
caused by: null at
	task:transfer @ vdl-int.k, line: 310
	sys:restartonerror @ vdl-int.k, line: 309
	sys:then @ vdl-int.k, line: 309
	sys:if @ vdl-int.k, line: 307
	sys:uparallelfor @ vdl-int.k, line: 290
	list:list @ vdl-int.k, line: 290
	sys:set @ vdl-int.k, line: 289
	vdl:dostageout @ vdl-int.k, line: 545
	sys:sequential @ vdl-int.k, line: 468
2013-04-30 10:17:58,207+0200 INFO  ExecutionContext Detailed exception:
Exception in cat:
    Host: localhost
or directory
    stdout.txt:
	at
org.globus.cog.karajan.workflow.nodes.functions.KException.function(KException.java:29)
	at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:27)
	at
org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
	at
org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
	at
org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
	at
org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
	at
org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
	at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
	at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
	at
org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
	at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:98)
	at
org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
	at java.util.concurrent.FutureTask.run(FutureTask.java:166)
	at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
	at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:679)
Caused by: Caused by: File not found:
	at
org.globus.cog.karajan.workflow.nodes.FlowNode.failImmediately(FlowNode.java:101)
	at
org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode$1.run(AbstractGridNode.java:308)
	... 6 more
Caused by: org.globus.cog.abstraction.impl.file.FileNotFoundException:
File not found:
	at
org.globus.cog.abstraction.impl.file.local.FileResourceImpl.getFile(FileResourceImpl.java:225)
	at
org.globus.cog.abstraction.impl.file.local.FileResourceImpl.putFile(FileResourceImpl.java:286)
	at
org.globus.cog.abstraction.impl.file.AbstractFileResource.putFile(AbstractFileResource.java:210)
	at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:307)
	at
org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:46)
	at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:482)
	... 1 more
2013-04-30 10:17:58,211+0200 INFO  Loader Swift finished with errors
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20130430/41b14646/attachment.pgp>
More information about the Swift-user mailing list
