[Swift-user] Custom/External Mappers
Robin Weiss
robinweiss at uchicago.edu
Mon Sep 10 16:56:45 CDT 2012
Howdy swifters,
I am having some issues getting external mappers to work. In particular, swift appears to hang when you use a custom mapper that takes in one or more command line arguments.
Attached is a tar ball with a basic example of the issue. You can uncomment each line in the mapper.swift script to see the behavior. I have included 4 versions of my external mapper, two work and two do not (see mapper.swift). Also included are the config, sites (using localhost), and tc files I'm using.
I noticed this issue after moving from version 0.93 to trunk (Swift trunk swift-r5917 cog-r3463) when some scripts I had been using started to hang.
Thanks in advance,
Robin
Robin M. Weiss
Research Programmer
Research Computing Center
The University of Chicago
6030 S. Ellis Ave., Suite 289C
Chicago, IL 60637
robinweiss at uchicago.edu<mailto:labello at uchicago.edu>
773.702.9030
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120910/c42b672d/attachment.html>
Type: application/x-tar
Desc: customMapper.tar
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120910/c42b672d/attachment.tar>
More information about the Swift-user
