[Swift-user] Output Files, ReadData and Order of Execution
Carolyn Phillips
cphillips at mcs.anl.gov
Sat Sep 1 15:23:56 CDT 2012
Sure
There are a lot of extra stuff running around in the script, fyi
# Types
type file;
type unlabeleddata;
type labeleddata;
type errorlog;
# Structured Types
type pointfile {
unlabeleddata points;
errorlog error;
type simulationfile {
file output;
# Apps
app (file o) cat (file i)
cat @i stdout=@o;
app (file o) cat2 (file i)
systeminfo stdout=@o;
app (pointfile o) generatepoints (file c, labeleddata f, string mode, int Npoints)
matlab_callgeneratepoints @c @f mode Npoints @o.points @o.error;
#app (simulationfile o) runSimulation(string p)
# launchjob p @o.output;
#Files (using single file mapper)
file config <"designspace.config">;
labeleddata labeledpoints <"emptypoints.dat">;
type pointlog;
# Loop
iterate passes {
# Generate Parameters
pointfile np <simple_mapper;prefix="mypoints.",suffix=".dat">;
np = generatepoints(config,labeledpoints, "uniform", 50);
int checkforerror = readData(np.error);
tracef("%s: %i\n", "Generate Parameters Error Value", checkforerror);
# Issue Jobs
#simulationfile simfiles[] <simple_mapper;location="/scratch/midway/phillicl/SwiftJobs/",prefix=@strcat("output.",passes,"."),suffix=".job">;
if(checkforerror==0) {
unlabeleddata pl = np.points;
string parameters[] =readData(pl);
foreach p,pindex in parameters {
tracef("Launch Job for Parameters: %s\n", p);
#simfiles[pindex] = runSimulation(p);
# Analyze Jobs
# Generate Prediction
# creates an array of datafiles named swifttest.<passes>.out to write to
file out[]<simple_mapper; location=".", prefix=@strcat("swifttest.",passes,"."),suffix=".out">;
# creates a default of 10 files
foreach j in [1:@toInt(@arg("n","10"))] {
file data<"data.txt">;
out[j] = cat2(data);
# try writing the iteration to a log file
file passlog <"passes.log">;
passlog = writeData(passes);
# try reading from another log file
int readpasses = readData(passlog);
# Write to the Output Log
tracef("%s: %i\n", "Iteration :", passes);
tracef("%s: %i\n", "Iteration Read :", readpasses);
#} until (readpasses == 2); # Determine if Done
} until (passes == 1); # Determine if Done
On Sep 1, 2012, at 1:57 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Can you post the entire script?
> On Sat, 2012-09-01 at 12:29 -0500, Carolyn Phillips wrote:
>> Yes, I tried that
>> and I got
>> Execution failed:
>> mypoints..dat (No such file or directory)
>> On Aug 31, 2012, at 8:27 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>> On Fri, 2012-08-31 at 20:11 -0500, Carolyn Phillips wrote:
>>>> How would this line work for what I have below?
>>>>>> string parameters[] =readData(np.points);
>>> unlabeleddata tmp = np.points;
>>> string parameters[] = readData(tmp);
>>>> On Aug 31, 2012, at 7:49 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>>>> Another bug.
>>>>> I committed a fix. In the mean time, the solution is:
>>>>> errorlog fe = np.errorlog;
>>>>> int error = readData(fe);
>>>>> On Fri, 2012-08-31 at 19:29 -0500, Carolyn Phillips wrote:
>>>>>> Hi Mihael,
>>>>>> the reason I added the "@" was because
>>>>>> now this (similar) line
>>>>>> gives me this:
>>>>>> Execution failed:
>>>>>> as in now its not getting the name of the file correct
>>>>>> On Aug 31, 2012, at 7:17 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>>>>>> @np.error means the file name of np.error which is known statically. So
>>>>>>> readData(@np.error) can run as soon as the script starts.
>>>>>>> You probably want to say readData(np.error).
>>>>>>> Mihael
>>>>>>> On Fri, 2012-08-31 at 18:55 -0500, Carolyn Phillips wrote:
>>>>>>>> So I execute an atomic procedure to generate a datafile, and then next
>>>>>>>> I want to do something with that data file. However, my program is
>>>>>>>> trying to do something with the datafile before it has been written
>>>>>>>> to. So something with order of execution is not working. I think the
>>>>>>>> problem is that the name of my file exists, but the file itself does
>>>>>>>> not yet, but execution proceeds anyway!
>>>>>>>> Here are my lines
>>>>>>>> type pointfile {
>>>>>>>> errorlog error;
>>>>>>>> int checkforerror = readData(@np.error);
>>>>>>>> This gives an error :
>>>>>>>> mypoints.error.dat (No such file or directory)
>>>>>>>> If I comment out the last line.. all the files show up in the directory. (e.g. mypoints.points.dat and mypoints.error.dat) ) and if forget to remove the .dat files from a prior run, it also runs fine!
>>>>>>>> How do you fix a problem like that?
>>>>>>>> _______________________________________________
>>>>>>>> Swift-user mailing list
>>>>>>>> Swift-user at ci.uchicago.edu
>>>>>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
