[Swift-user] assign temporary file to mapper
    Hao Yang
    yanghao0614 at gmail.com
    Tue Nov 20 19:22:45 CST 2012
Hi, all:
I have some problem assigning temporary file to some mapper variable
(explained in the code below).
type RSFile;
string output_name;
output_name = @arg("out","out.rsf");
RSFile output_data <single_file_mapper; file=output_name>;
RSFile output_chunks[];
// some calculation to compute output_chunks[0], output_chunks[1],
output_chunks[2]
// at the end
output_data = output_chunks[2];
When I try this script, swift reports "File output_chunks[2] not found "
error and failed. But the output_chunks[2] is still available in the
directory generated by swift (_concurrent/output_chunks-
ae9bd0b3-ad88-45b0-95f4-f036d2d70e58--array). Should this error message be
expected?
Thank you.
Best Regards,
Hao Yang
The University of British Columbia
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20121120/3c138cee/attachment.html>
More information about the Swift-user
