[Swift-user] coaster service doesn't work properly.
Iman Sadooghi
isadoogh at iit.edu
Thu Nov 8 20:34:38 CST 2012
I'm having problem trying to run swift on multiple nodes.
I 'm using coaster service.
here is the contents of my coaster service:
# Keep all interesting settings in one place
# User should modify this to fit environment
# Location of SWIFT. If empty, PATH is searched
export SWIFT=
# Where to copy worker.pl on the remote machine for sites.xml
export WORKER_LOCATION=$HOME/swiftwork
# How to launch workers: local, ssh, cobalt, or futuregrid
export WORKER_MODE=ssh
# SSH hosts to start workers on (ssh mode only)
export WORKER_HOSTS="216.47.142.127"
# Do all the worker nodes you're using have a shared filesystem? (yes/no)
export SHARED_FILESYSTEM=no
# Username to use on worker nodes
export WORKER_USERNAME=$iman
# Enable SSH tunneling? (yes/no)
export SSH_TUNNELING=yes
# Directory to keep log files, relative to working directory when launching
start-coaster-service
export LOG_DIR=$HOME/logs
# Manually define ports. If not specified, an available port will be used
export LOCAL_PORT=
export SERVICE_PORT=
# This is the IP address to which the workers will connect
# If not given, start-coaster-service tries to automatically detect
# the IP address of this system via ifconfig
# Specify this if you have multiple network interfaces
export IPADDR=
# Location of the swift-vm-boot scripts
export SWIFTVMBOOT_DIR=$HOME/swift-vm-boot
# Swift information for creating sites.xml
export WORK=/tmp
export QUEUE=prod-devel
export MAXTIME=20
export NODE=64
export JOBS_PER_NODE=1
export JOB_THROTTLE=0.799
when I start my coaster service this is the output which is very strange:
Start-coaster-service...
Configuration: /home/iman/te/coaster-service.conf
Service address: localhost
Starting coaster-service
Service port: 57175
Local port: 37589
Generating sites.xml
*usage: ssh [-1246AaCfgKkMNnqsTtVvXxYy] [-b bind_address] [-c cipher_spec]*
* [-D [bind_address:]port] [-e escape_char] [-F configfile]*
* [-I pkcs11] [-i identity_file]*
* [-L [bind_address:]port:host:hostport]*
* [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port]
* [-R [bind_address:]port:host:hostport] [-S ctl_path]*
* [-W host:port] [-w local_tun[:remote_tun]]*
* [user@]hostname [command]*
*Starting worker on 216.47.142.127*
*Generating config file*
*iman at iman-ThinkPad-T420:~/te$ usage: ssh [-1246AaCfgKkMNnqsTtVvXxYy] [-b
and it never terminates until I type something on terminal. the output
doesnt look right.
after this step when I try running a swift simple swift code like this:
iman at iman-ThinkPad-T420:~/te$ swift -sites.file sites.xml -tc.file tc
catsn.swift
Warning: Function toint is deprecated, at line 9
Swift trunk swift-r6010 cog-r3498
RunID: 20121108-2031-hhz64hqe
Progress: time: Thu, 08 Nov 2012 20:31:23 -0600
Passive queue processor initialized. Callback URI is http://127.0.1.1:41681
Progress: time: Thu, 08 Nov 2012 20:31:53 -0600 Submitted:10
Progress: time: Thu, 08 Nov 2012 20:32:23 -0600 Submitted:10
and it never terminates,
does anyone have an idea about it? I appreciate any comments or thoughts.
Thanks
Iman
Iman Sadooghi
Illinois Institute of Technology (IIT)
Data-Intensive Distributed Systems Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20121108/4b9a83e9/attachment.html>
More information about the Swift-user
