[Swift-user] Deep recursion on subroutine "main::stageout" at /home/ketan/work/worker.pl line 1349
Michael Wilde
wilde at mcs.anl.gov
Tue May 22 12:24:55 CDT 2012
If that path home/ketan/ketan_mars/MARS-LIC is being correctly copied to the workdir (and I stand corrected: thats exactly what should happen) then another possibility is that the program doesnt like getting a symlink for the license file? Can you test that case externally (outside of Swift) before we go further?
You reported the problem as "...the executable still gets into error as if the licence file is not present."
The license file will appear to the MARS executable (and the wrapper script) as a symlink (from the jobdir to the workdir, to use the terminology f the Swift User Guide).
If that is indeed the problem, your wrapper script might be able to get around this with:
cp MARS-LIC tmplic
rm MARS-LIC
mv tmplic MARS-LIC
Exactly what error is MARS generating for this problem?
- Mike
----- Original Message -----
> From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Swift User" <swift-user at ci.uchicago.edu>
> Sent: Tuesday, May 22, 2012 12:01:49 PM
> Subject: Re: [Swift-user] Deep recursion on subroutine "main::stageout" at /home/ketan/work/worker.pl line 1349
> The line works fine because Swift creates the dir tree starting at
> /home but in the swift.workdir. With -v, I could see the file gets
> copied to the cwd and is present there.
> So, I assume that the wrapper script is not cd'ing me anywhere. So, it
> still is a mystery why the app complaint about the file not present
> when run from wrapper and it works when run manually in the same dir.
> On Tue, May 22, 2012 at 11:34 AM, Michael Wilde < wilde at mcs.anl.gov >
> wrote:
> Isnt this line problematic if you dont know where the wrapper script
> has you cd'ed to:
> cp -v home/ketan/ketan_mars/MARS-LIC .
> The relative path doesnt seem safe.
> - Mike
> > From: "Ketan Maheshwari" < ketancmaheshwari at gmail.com >
> > To: "Michael Wilde" < wilde at mcs.anl.gov >
> > Cc: "Swift User" < swift-user at ci.uchicago.edu >
> > Sent: Tuesday, May 22, 2012 10:18:11 AM
> > "main::stageout" at /home/ketan/work/ worker.pl line 1349
> > Looking this further, I now have a wrapper in place which copies the
> > licence file in the cwd before running the executable. However, the
> > present.
> > When I cd into this dir (swift.workdir/mars-20120519-1203-3l....)
> > and
> > manually run the executable, it works.
> > So, the question is does the _swiftwrap.staging does some internal
> > cd'ing before calling the executable? I will take a look inside, but
> > would be useful if someone knows this.
> > The wrapper script is simply the following two lines:
> > /home/ketan/ketan_mars/marsMain $1
> > Regards,
> > Ketan
> > On Mon, May 21, 2012 at 7:51 PM, Michael Wilde < wilde at mcs.anl.gov >
> > wrote:
> > Im surprised that Swift isn't setting the current working dir (cwd)
> > to
> > be the job dir, but perhaps that's controlled by this property:
> > # Determines if Swift remote wrappers will be executed by specifying
> > an
> > # absolute path, or a path relative to the job initial working
> > directory
> > # valid values: absolute, relative
> > # wrapper.invocation.mode=absolute
> > Can you try your script with this property set to "relative"?
> > ...but looking at this further: I see that if youre using coasters
> > with provider staging, the logic for job launch is quite different.
> > We
> > need to study this and get back to you. For now, best to force the
> > right cd's with a wrapper. You might be able to remove the wrapper
> > later, once we resolve how the job dir management should work in
> > these
> > various cases.
> > - Mike
> > > Sent: Monday, May 21, 2012 4:28:02 PM
> > > Thanks Mike. Indeed the recursion was a warning.
> > > I found the problem was that the binary could not find the licence
> > > in
> > > the cwd from where it was being called. This is an application
> > > requirement that the licence file must be present in the cwd from
> > > where the call is made.
> > > However, Swift makes a dirtree in the workdir, stages the files
> > > and
> > > calls the binary from *outside* of this tree. Is it possible to
> > > make
> > > swift stage the licence file and put it on the top level without
> > > writing a wrapper to do a cp. Again, the point of not wrapping the
> > > binary into a script is to mimic the Hadoop setup as close as
> > > possible.
> > > On Mon, May 21, 2012 at 3:35 PM, Michael Wilde < wilde at mcs.anl.gov
> > > wrote:
> > > Ketan, as far as I can tell, that message, coming from worker.pl ,
> > > is
> > > just a warning.
> > > Programing Perl sec 33, Diagnostic Messages: "Deep recursion on
> > > subroutine "%s"
> > > (W recursion) This subroutine has called itself (directly or
> > > indirectly) 100 times more than it has returned. This probably
> > > indicates an infinite recursion, unless you're writing strange
> > > benchmark programs, in which case it indicates something else."
> > > The stageout code in worker.pl is indeed recursive, and the
> > > warning
> > > could be suppressed:
> > > "Try placing
> > > no warnings 'recursion';
> > > within the same scope as that code ..."
> > > Can you try a simple mod to catsn, using your ext mapper, to see
> > > if
> > > it
> > > is indeed failing due to the deeply recursive stageout?
> > > If you could dig a bit deeper into this, and see whether its
> > > really
> > > failing when staging back so many files or failing for some other,
> > > or
> > > related, reason, that would be great.
> > > Thanks,
> > > - Mike
> > > > To: "Swift User" < swift-user at ci.uchicago.edu >
> > > > Sent: Monday, May 21, 2012 1:54:34 PM
> > > > Subject: [Swift-user] Deep recursion on subroutine
> > > > "main::stageout"
> > > > Hi,
> > > > I am trying to run the GE mars script on a bag of workstations.
> > > > I
> > > > tested the script for a sufficient number of tasks and seems to
> > > > be
> > > > working fine on localhost.
> > > > However, it fails in this setup. I get the error message as
> > > > follows
> > > > after seemingly right invocation:
> > > > Find: keepalive(120), reconnect - http://128.84.97.46:41287
> > > > Progress: time: Mon, 21 May 2012 14:43:18 -0400 Stage in:7
> > > > Submitted:3
> > > > Progress: time: Mon, 21 May 2012 14:43:19 -0400 Stage in:8
> > > > Active:2
> > > > /home/ketan/work/
> > > > worker.pl line 1349.
> > > > /home/ketan/work/
> > > > Progress: time: Mon, 21 May 2012 14:43:20 -0400 Active:3 Stage
> > > > out:7
> > > > Obviously the staging out of results fails and seems that the
> > > > number
> > > > of files in the stageout stage is causing the error. The
> > > > application
> > > > needs to stage out about 120 files.
> > > > One solution I could quickly think of is to wrap the app in a
> > > > shell
> > > > and zip the outputs making it just one staged out file.
> > > > However, the current setup would still be useful since we are
> > > > trying
> > > > to compare the existing Hadoop solution with the Swift one.
> > > > Is there any possible workaround, some env setting or so that I
> > > > could
> > > > try and get the stageout going?
> > > > The logs are:
> > > > http://www.mcs.anl.gov/~ketan/mars-20120521-1443-d6q9lr0a.log
> > > > and http://www.mcs.anl.gov/~ketan/workerlogs.tgz
> > > > Regards, --
> > > > Ketan
> > > > _______________________________________________
> > > > Swift-user mailing list
> > > > Swift-user at ci.uchicago.edu
> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> > > Ketan
> > Michael Wilde
> > Ketan
> Michael Wilde
> Ketan
Michael Wilde
More information about the Swift-user
