[Swift-user] Timing Swift runs
Justin M Wozniak wozniak at mcs.anl.gov
Mon May 21 11:16:44 CDT 2012
Hello
     The log processing tools are in swift/libexec/log-processing .
README.txt is an overview of the tools.  It contains a section about a
"job run time distribution plot" which might be what you're looking
for.  You can simply extract the data or use the plotter in:
https://svn.ci.uchicago.edu/svn/vdl2/usertools/plotter
     Justin
On 05/21/2012 09:37 AM, Michael Wilde wrote:
> Hi Carsen,
> The "info" files that are produced by each application invocation include (I think) the run time stats. These are returned in a ".d" directory for successful app invocations when you specify this option in the swift.properties file (-config option):
> wrapperlog.always.transfer=false
> In addition you can glean a lot of info about run times from the Swift .log file.
> There are tools to plot information from the log, but Im not sure how up to date these are in the 0.93 and trunk releases. Can anyone with log plotting/analysis expertise provide more info?
> Thanks,
> - Mike
>> From: "Carsen Berger"<clberger at uchicago.edu>
>> To: swift-user at ci.uchicago.edu
>> Sent: Sunday, May 20, 2012 11:38:11 PM
>> Subject: [Swift-user] Timing Swift runs
>> Hello again,
>> I need to get performance numbers to benchmark various Swift jobs on a
>> generic bag of workstations. Is there some easy way to do this, e.g.
>> perhaps a mechanism built into Swift that allows it to report how long
>> an execution took? Or would I need to come up with a site-specific
>> solution?
>> Thank you,
>> Carsen Berger
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Justin M Wozniak
More information about the Swift-user mailing list
