[Swift-user] swift hangs on local
Ketan Maheshwari
ketancmaheshwari at gmail.com
Wed May 16 22:06:09 CDT 2012
Thanks Mike! Replaced the output mapper with ext mapper and it works now.
On Wed, May 16, 2012 at 4:01 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Its possibly hanging because Swift cant determine the size of the
> resulting res[] array:
> app (file o, file _res[]) mars (file _ctl, file lic, file _inp[])
> mars @_ctl stdout=@o;
> foreach ctlfile, i in ctl {
> file res[]<simple_mapper; location="result", prefix="mars.",
> suffix=".ot*">;
> (out[i], res) = mars(ctlfile, licence, inp);
> You mapped it with a "dynamic" output mapper (vs. a static output mapper
> like the ext mapper). A dynamic mapper will map each element of an array on
> demand, as its added to an array. In your script, however, the array would
> get set by the app() function mares(), but Swift has no way of knowing how
> many elements mars() is placing in that array. Is that a number you can
> know up-front, and set it in an ext mapper? There is no way I know of in
> Swift to have an app function return a dynamically-determined number of
> elements in an output array. Im not even certain that returning an output
> array works. If it truly needs to be dynamic, can you return a single file
> of filenames, and then use readData or other mappers to map that to a new
> array of output files?
> In any case, try for a first step just removing the res[] argument and
> array, and see if the rest of your data flow works.
> - Mike
> > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > To: "Swift User" <swift-user at ci.uchicago.edu>
> > Sent: Wednesday, May 16, 2012 2:41:58 PM
> > Subject: [Swift-user] swift hangs on local
> > I am trying to run the GE Energy stuff through Swift but seems like
> > Swift hangs without progress. Details below:
> > Inputs: a control file
> > Binary: marsMain
> > expected outputs: mars.ot* files and a .bin file
> > Needs : LIC and 3 .in files to be present in the pwd.
> > The directory is on mcs workstations: ~ketan/ketan_mars.
> > Standalone, it runs as follows:
> > ./marsMain ctlfiles/mars.ctl
> > The swift file is mars.swift
> > log for a hanged run is in the directory:
> > mars-20120516-1434-1xfq9zuc.log
> > stdout looks like this:
> > [steamroller:ketan_mars]$ swift -config cf -tc.file tc -sites.file
> > sites.xml mars.swift
> > Swift 0.93 swift-r5520 cog-r3338 (cog modified locally)
> > RunID: 20120516-1440-u3srmzyd
> > Progress: time: Wed, 16 May 2012 14:40:30 -0500
> > (input): found 1 files
> > (input): found 3 files
> > No events in 10s.
> > Registered futures:
> > file[] res Open, 0 elements, 1 listeners
> > Waiting threads:
> > 0-7-0-3
> > swift.workdir is not created.
> > Clues? --
> > Ketan
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120516/8c8cd1a0/attachment.html>
More information about the Swift-user
