[Swift-user] Question about mappers
Lorenzo Pesce lpesce at uchicago.edu
Fri Mar 30 08:56:35 CDT 2012
> file result <single_file_mapper; file=@strcat("result_neuron_", chn, "_ht_",s,".mat")>;
> file LogDemoReal <single_file_mapper; file=@strcat("demo_real", chn, "_ht_",s,".log")>;
> If you want these files to get created in one of the WinDirs directories, you should prepend win,"/" in front:
> file result <single_file_mapper; file=@strcat(win,"/"."result_neuron_",...
> Was that what you intended?
It would be, but if I add it, it does this
Exception in runDemoReal:
Arguments: [/soft/matlab/7.13, 1.0, 3.0, /lustre/beagle/GCNet/grasping/200ms_5windows_new/Win7/X.mat]
Host: pbs
Directory: demo_real-20120330-1352-71yp4ivb/jobs/x/runDemoReal-xe0j37pk
stderr.txt:
stdout.txt:
Caused by: The following output files were not created by the application: Win7/result_neuron_1_ht_3.mat
because (I think) the script generates the files in its own run directory.
Originally the script has a cd to Win# and then ran the code.
> Also, there should be no need to generate the Swift script with shell variable substitution. You can pass in values from the shell script via swift command line and access them from the Swift script with the @arg() function.
> You can make htvec and chnvec string vectors instead of ints, and pass them like so:
> swift -tc.file etc etc myscript.swift -htvec=1,3,5 -chnvec=a,b,c -currdir=$PWD
> and in the script do:
> string htvec[]=@strsplit(@arg("htvec"));
> You can use the strng htvec[] in your later @strcat() call in the same way you used the int version of that vector.
Thanks.
> - Mike
>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> To: swift-user at ci.uchicago.edu
>> Sent: Thursday, March 29, 2012 9:03:48 PM
>> Subject: [Swift-user] Question about mappers
>> Hi all--
>> Thanks a lot for your help. I have another question.
>> This is what my problem looks like. There is a set of input files, all
>> with the same name (say X.mat), in a set of subdirectories of say
>> <root_dir>:
>> Win1
>> Win2
>> Win3
>> WinN
>> The applications takes the input file as *filename* (string) and not a
>> handle, then some other parameters and produces a couple of output
>> files (see below for app demoreal).
>> For each directory, say Win1, each file X.mat is mapped to many output
>> files result_neuron_<i>_ht_<j>.mat, where i and j are a parameter
>> sweep (same for all windows, but the X.mat files are different).
>> My script pokes around, takes some input and then spews up a swift
>> script. My mapping misfires and all the output files end up in
>> <root_dir>, which doesn't work because many should have the same name.
>> If the input file were a handle, I would use a file type and map input
>> and output and I think that I would know how to do that. Here I have
>> no idea.
>> // file to run the Margic square example from the matlab web site
>> type file;
>> string MCRPath = "/soft/matlab/7.13";
>> string spikefilename = "$infile";
>> app (file outdata,file result) demoreal (string mcr, int chn, int
>> htin, string datafile)
>> runDemoReal mcr chn htin datafile stdout=@outdata;
>> string WinDirs[] = ${swiftWinDirs};
>> int htvec[] = ${htvec};
>> int chnvec[] = ${chnvec};
>> foreach win in WinDirs {
>> string spikefile = @strcat("${currdir}/",win,spikefilename);
>> foreach chn in chnvec {
>> foreach s, i in htvec {
>> "_ht_",s,".mat")>;
>> "_ht_",s,".log")>;
>> (LogDemoReal,result) = demoreal (MCRPath, chn, s, spikefile);
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user mailing list
