[Swift-user] [Swift-devel] ram disk with swift
Kazutaka Takahashi kazutaka at gmail.com
Sat Jun 9 23:53:28 CDT 2012
Sorry for a late reply and thank you for all!
Lorenzo and I will go over modifications on monday and will test out those
codes.
Thanks and enjoy the rest of the weekend!
Taka
On Fri, Jun 8, 2012 at 4:34 PM, David Kelly <davidk at ci.uchicago.edu> wrote:
> Here is a portion of a script that that copies some frequently used data
> to a node's shared memory. I think it is pretty similar to the script that
> Glen sent earlier.
> dssatdir=/dev/shm/dssat
> dssattmp=/dev/shm/dssat.tmp
> if [ ! -d $dssatdir ]; then
>  if mkdir $dssattmp 2>/dev/null; then
>    echo $$ copying
>    savewd=$PWD
>    cd $dssattmp
>    mkdir -p refdata
>    cp $refdata/* refdata/
>    mkdir -p campaign
>    cp $campaign/*.MZX campaign/
>    mkdir -p binpath
>    cp $binpath/*.EXE binpath/
>    cd $savewd
>    mv $dssattmp $dssatdir
>  else
>    while [ ! -d $dssatdir ]; do
>     # echo $$ sleeping
>      sleep 1;
>    done
>  fi
> fi
> > From: "Lorenzo Pesce" <lpesce at uchicago.edu>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>, "Swift Devel" <
> swift-devel at ci.uchicago.edu>, swift-user at ci.uchicago.edu
> > Cc: "Kazutaka Takahashi" <kazutaka at gmail.com>
> > Sent: Friday, June 8, 2012 2:39:19 PM
> > Subject: [Swift-devel] ram disk with swift
> > Mike,
> > We were talking about putting the input files for Taka's calculations
> > (the X.mat files), which are rather small ~ 60Kb or so, in ram disk
> > and try to use them for all the apps (that use the same file). giving
> > the size, we could even load up all of them for each node
> > (7*3*60=1.2MB, that is zero) to reduce traffic towards /lustre and
> > thus avoid the meta-data slow downs that Beagle seems to have.
> > If we copy files in /tmp (as far as I understand it would be ramdisk)
> > on the each node through swift, would it be there for all the apps?
> > Thanks,
> > Lorenzo
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
What is essential is invisible to the eye
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120610/1701d93c/attachment.html>
More information about the Swift-user mailing list
