[Swift-user] Question about swiftR temporary and work directories
Michael Wilde wilde at mcs.anl.gov
Sun Jun 24 21:47:10 CDT 2012
The use of /tmp might be set in the R code of the SwiftR package; will need to check and get back to you.
- Mike
----- Original Message -----
> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
> To: swift-user at ci.uchicago.edu
> Sent: Wednesday, June 13, 2012 10:51:32 AM
> Subject: [Swift-user] Question about swiftR temporary and work directories
> We are using swift R. Since we are working on a machine where the
> compute nodes see only the /lustre file system, we need to be able to
> set all the temporary directories there.
> We know how to do that with swift, but swiftR doesn't seem to work
> that way.
> This is the command:
> > library(Swift)
> > swiftInit(server="custom", tc.file="ROC.tc", cf.file="ROC.cf",
> > sites.file="ROCSites.xml")
> Working in /tmp/lpesce/SwiftR/swift.ZKHU
> Running in /tmp/lpesce/SwiftR/swift.ZKHU (linked to
> /tmp/lpesce/SwiftR/swift.custom)
> Started worker manager with pid 10153
> I would like both of those to point to /lustre/beagle/`whoami`/<some
> path>
> where I can decide where to send them or at least that the place is
> under my /lustre folder.
> Any ideas?
> We set these variables before running R:
> module load swift
> export SWIFT_HEAP_MAX=1024M
> export USER_HOME=/lustre/beagle/GCNet
> export SWIFT_HOME=/soft/swift/0.93/
> # set temporary directory references for R, currdir is
> export TMP=$currdir/tmp
> export TMPDIR=$TMP
> export TEMP=$TMP
> mkdir -p $TMP
> This is the sites file:
> less ROCSites.xml
> <config>
> <pool handle="pbs">
> <execution provider="coaster" jobmanager="local:pbs"/>
> <profile namespace="globus" key="project">CI-CCR000070</profile>
> key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
> <profile namespace="globus" key="jobsPerNode">24</profile>
> <profile namespace="globus" key="maxTime">1800</profile>
> <profile namespace="globus" key="maxwalltime">0:2:00</profile>
> <profile namespace="globus" key="lowOverallocation">100</profile>
> <profile namespace="globus" key="highOverallocation">100</profile>
> <profile namespace="globus" key="slots">1</profile>
> <profile namespace="globus" key="nodeGranularity">1</profile>
> <profile namespace="globus" key="maxNodes">1</profile>
> <profile namespace="karajan" key="jobThrottle">.63</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <filesystem provider="local"/>
> <workdirectory>/lustre/beagle/lpesce/ROCSwift/swift.workdir</workdirectory>
> </pool>
> </config>
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user mailing list
