[Swift-user] using dual filesys_mappers
Robin Weiss robinweiss at uchicago.edu
Mon Jul 16 10:43:28 CDT 2012
Hello Swifters,
I have a question about using two filesys_mappers and the foreach construct.  I have attached the offending .swift script I am working with for reference.  Here's the gist of what i'm trying to do and what appears to be happening instead:
I have a program called 'boot' that takes as command line arguments 4 file paths (log, out, data, and meta), and a number of other params (all numerical and seem to be getting passed in correctly, so no worries there).  'log' and 'out' are output files and 'data' and 'mata' are input files (located in directories called 'out' and 'in' respectively).  The problem i'm having is with getting the correct values for 'data' and 'meta' passed in to my app call.  I have an app section called processData that invokes boot.  I will be assuming the the directory 'in' contains identically named data and meta files that differ only in their suffix ('.dat' or '.meta', respectively).  This may or may not be safe, but for now it is fine and I'll cross that bridge when I come to it.  Here's the relevant snippet from my script:
app (clusFile out) processData (dataFile data, metaFile meta, logFile log){
        boot "-log" @log "-results" @out "-meta" @meta "-data" @data "-kmin" kmin "-kmax" kmax "-eps" eps "-bootpct" bootpct "-maxiterations" maxiterations "-maxtries" maxtries;
dataFile dataFiles[] <filesys_mapper;location="in",sufix="dat">;
metaFile metaFiles[] <filesys_mapper;location="in",sufix="meta">;
foreach f,i in dataFiles {
        clusFile o<single_file_mapper; location="out", file=@strcat("out/clusFile.",i,".clus")>;
        logFile l<single_file_mapper; location="out", file=@strcat("out/logFile.",i,".log")>;
        o = processData(f, metaFiles[i], l);
this configuration causes processData to be invoked as:
out/clusFile.0.clus = processData(dataFile0.dat, dataFile0.dat, out/logFile.0.log);
if i switch around the oder of the filesys_mappers so that the snippet reads:
the app invocation is called as:
out/clusFile.o.clus = processData(dataFile0.meta, dataFile0.meta, out/logFile.0.log);
I guess the real question is this: what is the most appropriate way in swift to pass into a app invocation two corresponding input files?  Ideally, it would be something like 'foreach file1,file2,i in inputFiles[][] { … } but that doesn't really make too much sense either.
Anyway, any ideas would be appreciated.
Cheers,
Robin
Robin M. Weiss
Research Programmer
Research Computing Center
The University of Chicago
6030 S. Ellis Ave., Suite 289C
Chicago, IL 60637
robinweiss at uchicago.edu<mailto:labello at uchicago.edu>
773.702.9030
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120716/612c1986/attachment.html>
More information about the Swift-user mailing list
