[Swift-user] How does swift mapping to files that do not yet exist work?
Jonathan Margoliash
jmargolpeople at gmail.com
Tue Jul 3 17:24:19 CDT 2012
Sorry, I should have specified this earlier, but I do not believe my cce_ua
function was ever called. The first line of my cce_ua function is a
statement that prints to stdout. The second and third lines open a file
(via absolute path) and write to it. I have not observed either of those
being executed. Furthermore, the following (matlab) code process the output
argument:
output_point_location = argv(){3};
new_point = ....
save(output_point_location, 'new_point');
There is no other code that modifies the output_point_location variable. So
shouldn't this work, given how swift passes files as command line arguments?
I think something else is the problem, but of course any solution would be
great. Thanks!
Jonathan
On Tue, Jul 3, 2012 at 5:11 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Jonathan, from a cursory read of your script, I suspect that the Swift
> runtime is complaining that the app cce_ua did not produce the file
> new_point1_1.mat, which your output file mapping specified.
> Given your output mapping, Swift is expecting new_point1_1.mat to exist in
> the temporary job directory in which your app was launched. I suspect your
> app (matlab script) did not create a file of this exact name.
> You can specify the property "sitedir.keep=true" in your config file
> (e.g., -config cf on the command line) to tell Swift to retain these job
> directories on failure. They should be below the "workdirectory" that you
> specified in your sites.xml file.
> (I think...)
> - Mike
> > From: "Jonathan Margoliash" <jmargolpeople at gmail.com>
> > To: swift-user at ci.uchicago.edu
> > Sent: Tuesday, July 3, 2012 4:48:16 PM
> > Subject: [Swift-user] How does swift mapping to files that do not yet
> exist work?
> > Hello swift user base,
> > I have been having trouble with a bit of swift code for a while now,
> > and despite my hesitancy to ask other people to debug my code, I
> > believe my issue may be more of a lack of understanding of swift than
> > a simple syntax error, so I have decided to send out this email.
> > Specifically, I have a single_file_mapper mapping to a file which does
> > not yet exist when my code is run, in hopes that the file being mapped
> > to will be written to by a an app call. However, when I try running my
> > code, I get the error back from swift
> > Execution failed:
> > File not found: filename (in this case new_point1_1.mat)
> > This paradigm of referencing files that do not yet exist has worked
> > before in swift, so I do not know what the problem is here. Hopefully
> > it is not a simple syntax bug. Anyway, thank you for your help,
> > Jonathan
> > ----- My Code: ----------
> > #cce_ua.swift
> > type file;
> > int num_complexes = @toint(@arg("num_complexes"));
> > int num_simplexes_per_complex =
> > @toint(@arg("num_simplexes_per_complex"));
> > app (file output, file log) cce_ua (file input1, file input2, int
> > number, file input3)
> > cce_ua @input1 @input2 @output number @input3 stdout=@filename(log)
> > stderr=@filename(log);
> > #located at _RUNDIR_/swat/cce_ua.sh
> > file inSCE<single_file_mapper;file="SCE_Par.mat">;
> > file inrunswat<single_file_mapper;file="RunSwat.m">;
> > foreach i in [1:num_complexes]
> > foreach j in [1:num_simplexes_per_complex]
> > # These files already exist in the local directory
> > file input<single_file_mapper; file=@strcat("simplex", i, "_", j,
> > ".mat")>;
> > # These files do not exist in the local directory at runtime
> > file output<single_file_mapper; file=@strcat("new_point", i, "_", j,
> > ".mat")>;
> > file log<single_file_mapper; file=@strcat("cce_ua", i, "_", j,
> > "_log.txt")>;
> > (output, log) = cce_ua(inSCE, input, i*num_simplexes_per_complex + j,
> > inrunswat);
> > ---- The command line call to swift (broken up over multiple lines)
> > swift -tc.file swift_files/executable_locations -sites.file
> > swift_files/sites.xml cce_ua.swift -num_complexes=2
> > -num_simplexes_per_complex=1
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120703/0c958524/attachment.html>
More information about the Swift-user
