[Swift-user] Montage+Swift+Coasters
Emalayan Vairavanathan svemalayan at yahoo.com
Mon Jan 23 14:25:50 CST 2012
I am using swift-0.93. I started only the coaster-service manually using following command (workers were started automatically).
coaster-service -port 1984 -localport 35753 -nosec
Then application prints following output and terminates. (I have attached the log file with this mail. Please discard the previous log file because system was not configured properly)
Please let me know if you need more information.
Thank you
Emalayan
Swift 0.93 swift-r5501 (swift modified locally) cog-r3350
RunID: 20120123-1219-zj95uaye
 (input): found 10 files
Progress:  time: Mon, 23 Jan 2012 12:19:39 -0800
Find: http://localhost:1984
Find:  keepalive(120), reconnect - http://localhost:1984
Progress:  time: Mon, 23 Jan 2012 12:19:41 -0800  Stage in:1  Submitted:9
Progress:  time: Mon, 23 Jan 2012 12:19:45 -0800  Active:9  Stage out:1
Progress:  time: Mon, 23 Jan 2012 12:19:46 -0800  Active:6  Stage out:2  Finished successfully:2
Progress:  time: Mon, 23 Jan 2012 12:19:47 -0800  Submitted:1  Finished successfully:10
Progress:  time: Mon, 23 Jan 2012 12:19:49 -0800  Active:1  Finished successfully:10
Progress:  time: Mon, 23 Jan 2012 12:19:50 -0800  Submitted:1  Finished successfully:12
Progress:  time: Mon, 23 Jan 2012 12:19:51 -0800  Stage in:12  Submitted:5  Finished successfully:13
Progress:  time: Mon, 23 Jan 2012 12:19:52 -0800  Stage in:1  Submitted:5  Active:9  Stage out:2  Finished successfully:13
Progress:  time: Mon, 23 Jan 2012 12:19:53 -0800  Active:5  Finished successfully:25
Exception in mConcatFit:
Arguments: [_concurrent/status_tbl-bf92dd4d-ecf0-490e-ab93-cf7863688950-5, fits.tbl, stat_dir]
Host: localhost
Directory: SwiftMontage-20120123-1219-zj95uaye/jobs/4/mConcatFit-4o2fb2mk
Caused by: null
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 520
Execution failed:
    back_list:Table = org.griphyn.vdl.mapping.DataDependentException - Closed not derived due to errors in data dependencies
[emalayan at node090 scripts]$
 From: Ketan Maheshwari <ketancmaheshwari at gmail.com>
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: Jonathan Monette <jonmon at mcs.anl.gov>; swift user <swift-user at ci.uchicago.edu>
Sent: Monday, 23 January 2012 11:55 AM
Subject: Re: [Swift-user] Montage+Swift+Coasters
How are you starting the service? Are you starting workers manually? if yes, could you paste commandlines for both?
On Mon, Jan 23, 2012 at 1:50 PM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
Thanks Ketan and Jon. I tried but it is still giving error. I have attached the log file.
>Thank you
>Emalayan
>________________________________
>Sent: Monday, 23 January 2012 11:36 AM
>Emalayan,
>Likely, /tmp is not readable/writable across the machines. Could you try changing workdir to your /home
>On Mon, Jan 23, 2012 at 1:25 PM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
>Jon,
>>Please find the detail below and let me know if you have any questions about my setup.
>>Thank you
>>Emalayan
>>site.xml
>><config>
>><pool handle="localhost">
>>    <execution provider="coaster-persistent" url="http://localhost:1984" jobmanager="local:local"/>
>>    <profile namespace="globus" key="workerManager">passive</profile>
 key="workersPerNode">4</profile>
>>    <profile namespace="globus" key="maxTime">100000</profile>
>>    <profile namespace="globus" key="lowOverAllocation">100</profile>
>>    <profile namespace="globus" key="highOverAllocation">100</profile>
>>    <profile namespace="globus" key="slots">100</profile>
>>    <profile namespace="globus" key="nodeGranularity">1</profile>
>>    <profile namespace="globus" key="maxNodes">10</profile>
>>    <profile namespace="karajan" key="jobThrottle">25.00</profile>
>>    <profile namespace="karajan" key="initialScore">10000</profile>
>>    <profile namespace="swift" key="stagingMethod">proxy</profile>
>>    <filesystem
 provider="local"/>
>>    <workdirectory>/tmp/swift.workdir</workdirectory>
>>  </pool>
>></config>
>>tc
>>localhost sh /bin/sh null null null
>>localhost cat /bin/cat null null null
>>localhost echo /bin/echo null null null
>>localhost do_merge /home/emalayan/App/forEmalayan/app/modmerge null null null
>>localhost mProjExec /home/emalayan/App/Montage_v3.3/bin/mProjExec null null null
>>localhost mImgtbl /home/emalayan/App/Montage_v3.3/bin/mImgtbl null null null
>>localhost mAdd /home/emalayan/App/Montage_v3.3/bin/mAdd null null null
>>localhost mOverlaps /home/emalayan/App/Montage_v3.3/bin/mOverlaps null null null
>>localhost mJPEG /home/emalayan/App/Montage_v3.3/bin/mJPEG null null null
>>localhost mDiffExec_wrap
 /home/emalayan/App/Montage_v3.3/bin/mDiffExec null null null
>>localhost mFitExec /home/emalayan/App/Montage_v3.3/bin/mFitExec null null null
>>localhost mBgModel /home/emalayan/App/Montage_v3.3/bin/mBgModel null null null
>>localhost mBgExec /home/emalayan/App/Montage_v3.3/bin/mBgExec null null null
>>localhost mConcatFit /home/emalayan/App/Montage_v3.3/bin/mConcatFit null null nul
>>localhost Background_list /home/emalayan/App/montage-swift/SwiftMontage/apps/Background_list.py null null null
>>localhost create_status_table /home/emalayan/App/montage-swift/SwiftMontage/apps/create_status_table.py null null null
>>localhost mProjectPP_wrap /home/emalayan/App/montage-swift/SwiftMontage/apps/mProjectPP_wrap.py null null null
>>localhost mProject_wrap /home/emalayan/App/montage-swift/SwiftMontage/apps/mProject_wrap.py null null null
>>localhost mBackground_wrap /home/emalayan/App/montage-swift/SwiftMontage/apps/mBackground_wrap.py null null
 null
>>localhost mDiffFit_wrap /home/emalayan/App/montage-swift/SwiftMontage/apps/mDiffFit_wrap.py null null null
>>cf
>>wrapperlog.always.transfer=true
>>sitedir.keep=true
>>execution.retries=1
>>lazy.errors=true
>>status.mode=provider
>>use.provider.staging=true
>>provider.staging.pin.swiftfiles=false
>>foreach.max.threads=100
>>provenance.log=false
>> From: Jonathan Monette <jonmon at mcs.anl.gov>
>>To: Ketan Maheshwari <ketancmaheshwari at gmail.com>
>>Cc: Emalayan Vairavanathan <svemalayan at yahoo.com>; swift user <swift-user at ci.uchicago.edu>
>>Sent: Monday, 23 January 2012 11:08 AM
>>Emalayan,
>>   So I have ran the scripts with some of my own test cases and do not see it failing.  Could you provide your config files?  Please provide the tc, sites, and config file(if you use a config file).
>>On Jan 20, 2012, at 9:39 AM, Ketan Maheshwari wrote:
>>Emalayan,
>>>I would check all the mappers and the resulting paths in the Swift source.
>>>Also try running the failed job something like this:
>>>cd <swift.workdir>/SwiftMontage-20120119-1749-rjshh1r9/jobs/b/mConcatFit-b1sa4vlk
>>>mConcatFit _concurrent/status_tbl-7a8340c2-045d-4039-a77c-00429b78d9c9-5 fits.tbl stat_dir
>>>error 520 indicates workers are not able to reach the data.
>>>Also check if swift.workdir is writable on the site by the worker nodes.
>>>On Thu, Jan 19, 2012 at 7:55 PM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
>>>Hi Ketan,
>>>>This was with swift-0.92.1.Now I have downloaded the latest swift 0.93 and getting totally different error messages with swift 0.93. I can ask Jon about these messages. (These scripts was working well with only Swift)
>>>>Please let me know if you have any idea.
>>>>Regards
>>>>Emalayan
>>>>Swift 0.93 swift-r5501 cog-r3350
>>>>RunID: 20120119-1749-rjshh1r9
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:20 -0800
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:22 -0800  Stage in:1  Submitted:9
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:25 -0800  Active:9  Stage out:1
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:26 -0800  Stage out:3  Finished successfully:7
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:28 -0800  Active:1  Finished successfully:10
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:29 -0800  Stage in:1  Submitting:11  Submitted:6  Finished successfully:12
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:30 -0800  Stage in:4  Submitted:1  Active:6  Stage out:2  Finished successfully:17
>>>>Progress:  time: Thu, 19 Jan 2012 17:49:31 -0800  Active:1  Finished successfully:30
>>>>Arguments: [_concurrent/status_tbl-7a8340c2-045d-4039-a77c-00429b78d9c9-5, fits.tbl, stat_dir]
>>>>Host: localhost
>>>>Directory: SwiftMontage-20120119-1749-rjshh1r9/jobs/b/mConcatFit-b1sa4vlk
>>>>Caused by: null
>>>>Execution failed:
>>>>Cc: swift user <swift-user at ci.uchicago.edu>
>>>>Sent: Thursday, 19 January 2012 4:49 PM
>>>>Emalayan,
>>>>From your symptoms, it seems you are facing the same issue as I've been. Could you tell more about the amount of data that needs to be staged to run the Montage stages during which these warnings turn up? How much time elapses since the start of your workflow after which you see these messages?
>>>>Also, what version of Swift is this?
>>>>Regards,
>>>>Ketan
>>>>On Thu, Jan 19, 2012 at 5:51 PM, Emalayan Vairavanathan <svemalayan at yahoo.com> wrote:
>>>>Dear All,
>>>>>I have a problem in running Montage with Coasters (in our local cluster - no batch schedulers). After few stages the swift run-time continuously prints the warnings below. Any ideas ? Should I increase the heartbeat count ?
>>>>>Everything works fine when I try to run the same montage-scripts with swift on a single machine.
>>>>>Thank you
>>>>>Emalayan
>>>>>2012-01-19 15:38:09,207-0800 WARN  Command Command(119, HEARTBEAT): handling reply timeout; sendReqTime=120119-153609.206, sendTime=120119-153609.206,
now=120119-153809.207
>>>>>2012-01-19 15:38:09,207-0800 INFO  Command Command(119, HEARTBEAT): re-sending
>>>>>2012-01-19 15:38:09,209-0800 WARN  Command Command(119, HEARTBEAT)fault was: Reply timeout
>>>>>org.globus.cog.karajan.workflow.service.ReplyTimeoutException
>>>>>        at org.globus.cog.karajan.workflow.service.commands.Command.handleReplyTimeout(Command.java:288)
>>>>>        at org.globus.cog.karajan.workflow.service.commands.Command$Timeout.run(Command.java:293)
>>>>>        at java.util.TimerThread.mainLoop(Timer.java:534)
>>>>>        at java.util.TimerThread.run(Timer.java:484)
>>>>>_______________________________________________
>>>>>Swift-user mailing list
>>>>>Swift-user at ci.uchicago.edu
>>>>>https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
>>>>Ketan
>>>Ketan
>Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120123/1ba41329/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120123/1ba41329/attachment.bin>
More information about the Swift-user mailing list
