[Swift-user] Question re: reliance on proxy cert
jonmon at mcs.anl.gov jonmon at mcs.anl.gov
Wed Jan 18 12:55:31 CST 2012
Is the proxy on the execution site necessary?  I thought it was just the client side. I don't think I create a proxy on the execution site...I only request one using my-proxy on the client side.
-----Original Message-----
Sender: swift-user-bounces at ci.uchicago.edu
Date: Wed, 18 Jan 2012 12:49:56
To: Mihael Hategan<hategan at mcs.anl.gov>; Thomas Uram<turam at mcs.anl.gov>
Cc: swift user<swift-user at ci.uchicago.edu>
Subject: Re: [Swift-user] Question re: reliance on proxy cert
Tom, for now, this means that when using automatic coasters over ssh, you need to (manually, out of band) create an x509 proxy on both sides. Either securely copy one, or run grid-proxy-init on both the client side (where you are running Swift) and on each site on which Swift will start a coaster service.
One can bypass the need for proxies when setting up manual coaster configurations with the -nosec argument to the coaster-service command.
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Thomas Uram" <turam at mcs.anl.gov>
> Cc: "swift user" <swift-user at ci.uchicago.edu>
> Sent: Wednesday, January 18, 2012 12:43:40 PM
> On Wed, 2012-01-18 at 12:33 -0600, Thomas Uram wrote:
> > I'm using coasters with ssh:pbs and have the proper bits in
> > ~/.ssh/auth.defaults to support authentication, but when I run the
> > script it fails due to a missing or expired proxy cert:
> > Why does it fail when an alternative authentication mechanism is
> > available that would succeed? Is there an option to control this?
> It fails because while ssh is used to start the coaster service
> executable, the connection between client and service is secured by
> GSI.
> This model was just peachy in the Globus scenario, where you would
> need
> a proxy anyway to start the service and delegation could be used to
> supply credentials to the coaster service.
> Not so much with ssh. I've been thinking about a way to deal with
> this,
> and I think I'm leaning towards some shared secret that could be used
> as
> a one-time authentication token by the service. The problem is making
> sure that whatever provider is used to communicate said secret to the
> service remains a secret (i.e. passing it on any command line is out
> of
> the question). But that seems to require the use of an encrypted file
> transfer provider, which breaks the abstraction we have a bit, so it
> might require more changes than I want to see.
> So suggestions are welcome.
> Mihael
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user mailing list
