[Swift-user] coaster-service.conf
Jonathan Monette
jonmon at mcs.anl.gov
Mon Feb 27 20:13:18 CST 2012
I assume you mean the "-k" option in the cqsub command. So currently this is hard coded into the start-coaster-service script, it always uses zeptoos. I have made a quick change that uses a KERNEL variable that needs to be set in the coaster-service.conf file. Are you using your own checkout of trunk or the one in Justin's home directory?
On Feb 27, 2012, at 7:33 PM, Emalayan Vairavanathan wrote:
> Hi All,
> When I launch coaster-service, it allocates job with default kernel profile "zeptoos". I want to change the profile to "zepto-vn-eval/mosatest".
> How can I do this ? Is there any configuration parameter available to change qsub command?
> If so how I can specify / pass this parameter? (via start-coaster-service 's command-line parameter or via a setting in coaster-service.conf)
> Also could you please tell me the exact format ? Please point to me a document if there is any.
> Thank you
> Emalayan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120227/e5bfe555/attachment.html>
More information about the Swift-user
