[Swift-user] gridftp error: Server refused MLST command
Thomas Uram
turam at mcs.anl.gov
Tue Feb 7 10:22:58 CST 2012
I have a sites file configured to use gridftp as follows:
<config>
<pool handle="Bugaboo">
<execution provider="coaster" jobmanager="ssh-cl:pbs" url="bugaboo.westgrid.ca:22" />
<gridftp url="gsiftp://bugaboo-fs.westgrid.ca/"/>
<workdirectory >/home/turam/tmp</workdirectory>
</pool>
</config>
When I run this, I routinely get errors like so:
2012-02-07 10:02:07,908-0600 WARN vdl:transferwrapperlog Failed to transfer wrapper log for job hostname-pmjqoqmk
2012-02-07 10:02:07,908-0600 DEBUG vdl:transferwrapperlog Exception for wrapper log failure from hostname-20120207-1001-sco9qsfa/info/p on Bugaboo: null
Caused by: org.globus.cog.abstraction.impl.file.IrrecoverableResourceException: Exception in getFile
Caused by: org.globus.cog.abstraction.impl.file.FileResourceException: Failed to retrieve file information about /home/turam/tmp/hostname-20120207-1001-sco9qsfa/info/p/hostname-pmjqoqmk-info
Caused by: org.globus.ftp.exception.ServerException: Server refused performing the request. Custom message: Server refused MLST command (error code 1) [Nested exception message: Custom message: Unexpected reply: 500-Command failed : System error in stat: No such file or directory
500-A system call failed: No such file or directory
500 End.] [Nested exception is org.globus.ftp.exception.UnexpectedReplyCodeException: Custom message: Unexpected reply: 500-Command failed : System error in stat: No such file or directory
500 End.]
Full log is here: http://www.mcs.anl.gov/~turam/20120207-1015/hostname-20120207-1001-sco9qsfa.log
I found some related discussion (http://lists.ci.uchicago.edu/pipermail/swift-devel/2011-September/009050.html), but no solution was identified.
Two questions:
- Is this a problem in my configuration, or need I take this up with the admins of the gridftp server?
- It's complaining about transferring wrapper logs, but the config file specifies "wrapperlog.always.transfer=false", so should it be even trying?
Tom
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120207/52d7e624/attachment.html>
More information about the Swift-user
