[Swift-user] Montage+Swift+Coasters
jonmon at mcs.anl.gov jonmon at mcs.anl.gov
Wed Feb 1 00:02:29 CST 2012
Let's try one more thing before we schedule a skype call to talk about more details(although one might still be necessary)
If you could please open up the python files that were in the tar ball I sent with the scripts. Everywhere you see a Montage function(it is prefixed with a lower case m) replace that with the fully qualified path to the binary.
Let me know if this works.
-----Original Message-----
From: Emalayan Vairavanathan <svemalayan at yahoo.com>
Date: Mon, 30 Jan 2012 11:53:33
To: Jonathan Monette<jonmon at mcs.anl.gov>
Reply-To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: swift user<swift-user at ci.uchicago.edu>
Subject: Re: [Swift-user] Montage+Swift+Coasters
Hi Jon, I added mBackground to tc file. But I am still getting the same error.
To answer your questions: Yes I am using only the local machine for now (No workers are started in remote nodes). By the way how we can debug the problem ? Do you think whether having a Skpye session is a good idea ?
Thank you
Emalayan
Cc: swift user <swift-user at ci.uchicago.edu>
Sent: Tuesday, 24 January 2012 1:11 PM
Ok.  Try adding it to your tc.  You are only using the local machine correct?  You aren't using some remote cluster are you?
On Jan 24, 2012, at 2:41 PM, Jonathan Monette wrote:
> Error code 127 means that the command wasn't found.
 This line was in the log
> stderr.txt: /bin/sh: mBackground: command not found
> So….do you have all the Montage binaries in your path?  What happens when you say mBackground in the terminal?
> On Jan 24, 2012, at 1:37 PM, Emalayan Vairavanathan wrote:
>> <SwiftMontage-20120124-1127-9a0xujy4.log.gz>
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120201/ed50ef6c/attachment.html>
More information about the Swift-user mailing list
