[Swift-user] many-to-one mapping
Mihael Hategan
hategan at mcs.anl.gov
Fri Dec 7 15:21:33 CST 2012
On Fri, 2012-12-07 at 15:08 -0600, Neil Best wrote:
> On Fri, Dec 7, 2012 at 2:35 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > foreach {
> > string m = @strcat(...);
> > file[] foo <...;..., match = m,...>;
> Shouldn't m also be an array?
It's the pattern, so I'm guessing no.
> Also, I don't recognize "file[] foo" in your notation.
Oh, I see. I'll add that you cannot declare variables inside invocation
argument lists. And I'm becoming a bit unsure about my previous
statement. You might be able to invoke stuff in mapper params. But let's
try what's more likely to work:
foreach year in [1979:2011] {
string m = @strcat( "^data/nc/",year, "../narr-a_221_", year,
"...._..00_000.single.nc$");
file[] foo <structured_regexp_mapper; source= nc1, match= m>;
ncList[year] = @filenames(foo);
or you could do ncList[year] = foo; and then apply @filenames in the app
call.
Mihael
> I tried this:
> m[ year] = @strcat( "^data/nc/", year, "../narr-a_221_", year,
> ncList[ year] = @filenames(
> file foo[]<structured_regexp_mapper;
> source= nc1,
> match= m[ year];>);
> annual[ year]= cdo( "-O mergetime", ncList[ year]);
> It still doesn't like that the mapper is an argument to @filenames(), I guess.
> Could not compile SwiftScript source: line 90:10: expecting ')', found 'foo'
> I hope it is clear what I am trying to do. Each member of ncList[]
> would be a long string enumerating the input files for the cdo command
> and must be different for each year.
More information about the Swift-user
