[Swift-user] Externally controlled loop
David Kelly
davidk at ci.uchicago.edu
Fri Aug 31 14:52:34 CDT 2012
This is what I get when trying with the latest trunk from SVN. I created a file called "errorlog" with a value of 1.
no sites file specified, setting to default: /home/davidk/swift-trunk/cog/modules/swift/dist/swift-svn/etc/sites.xml
Swift trunk swift-r5913 cog-r3459
RunID: 20120831-1448-q9y052k7
Progress: time: Fri, 31 Aug 2012 14:48:28 -0500
Iteration :: 0
the value is: 1
Iteration Read :: 0
Execution failed:
java.lang.NullPointerException
at org.griphyn.vdl.mapping.AbstractDataNode.getType(AbstractDataNode.java:95)
at org.griphyn.vdl.karajan.lib.SwiftArg.unwrap(SwiftArg.java:57)
at org.griphyn.vdl.karajan.lib.SwiftArg.getValue(SwiftArg.java:77)
at org.griphyn.vdl.karajan.lib.Operators.vdlop_eq(Operators.java:216)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.globus.cog.karajan.workflow.nodes.functions.FunctionsCollection.function(FunctionsCollection.java:82)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:27)
at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:194)
at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:98)
at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Carolyn Phillips" <cphillips at mcs.anl.gov>
> Cc: swift-user at ci.uchicago.edu
> Sent: Friday, August 31, 2012 2:35:12 PM
> Subject: Re: [Swift-user] Externally controlled loop
> That looks like a bug in swift.
> What version are you running this with (I see trunk, but how did you
> get
> it)?
> Mihael
> On Fri, 2012-08-31 at 14:24 -0500, Carolyn Phillips wrote:
> > Just to be certain I ran your exact script
> > cat b4.swift
> > type file;
> > iterate passes {
> > file passlog <"passes.log">;
> > passlog = writeData(passes);
> > int value = readData("errorlog");
> > int readpasses = readData(passlog);
> > tracef("%s: %i\n", "the value is", value);
> > tracef("%s: %i\n", "Iteration :", passes);
> > tracef("%s: %i\n", "Iteration Read :", readpasses);
> > } until (readpasses == 2); # Determine if Done
> > [phillicl at midway-login1 TestSwift]$ swift b4.swift
> > /software/swift-trunk-all/etc/sites.xml
> > Swift trunk swift-r5901 cog-r3451
> > RunID: 20120831-1923-58gjhdrd
> > Progress: time: Fri, 31 Aug 2012 19:23:29 +0000
> > Iteration :: 0
> > the value is: 0
> > Iteration Read :: 0
> > Execution failed:
> > at
> > at
> > at
> > sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
> > at
> > sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> > at java.lang.reflect.Method.invoke(Method.java:601)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
> > at
> > java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
> > at java.util.concurrent.FutureTask.run(FutureTask.java:166)
> > at
> > java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
> > at
> > java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
> > at java.lang.Thread.run(Thread.java:722)
> > On Aug 31, 2012, at 2:20 PM, Carolyn Phillips
> > <cphillips at mcs.anl.gov> wrote:
> > > Execution failed:
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > On Aug 31, 2012, at 2:17 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > > wrote:
> > >> Should work. What's the exact error you are getting?
> > >> $ swift b4.swift
> > >> default:
> > >> /home/mike/work/cog-svn/cogkit/trunk/current/src/cog/modules/swift/dist/swift-svn/etc/sites.xml
> > >> Swift trunk swift-r5739 (swift modified locally) cog-r3088 (cog
> > >> modified
> > >> locally)
> > >> RunID: 20120831-1215-i0n6v30e
> > >> Progress: time: Fri, 31 Aug 2012 12:15:09 -0700
> > >> Iteration :: 0
> > >> Iteration Read :: 0
> > >> the value is: 1
> > >> Iteration :: 1
> > >> the value is: 1
> > >> Iteration Read :: 1
> > >> Iteration :: 2
> > >> the value is: 1
> > >> Iteration Read :: 2
> > >> Final status: Fri, 31 Aug 2012 12:15:09 -0700
> > >> $ cat b4.swift
> > >> type file;
> > >> iterate passes {
> > >> On Fri, 2012-08-31 at 12:02 -0500, Carolyn Phillips wrote:
> > >>> Hello,
> > >>> So I want to create an externally controlled loop, meaning, the
> > >>> number of times the loop repeats is determined by the output of
> > >>> a executable called within the loop. That output is written to a
> > >>> file so it can be read and checked. I am experimenting with
> > >>> getting a very rudimentary set up. Below you can see that I have
> > >>> two lines that determine if the iteration is done, one based on
> > >>> the variable "passes" and the other based on the variable "read
> > >>> passes" that is read from a file. The second does not work and
> > >>> throws a execution failed exception. Any advice on how to make
> > >>> this kind of structure work?
> > >>> type file;
> > >>> iterate passes {
> > >>> # try writing the iteration to a log file
> > >>> # try reading from another log file
> > >>> # Write to the Output Log
> > >>> int i = 3;
> > >>> #} until (readpasses == 2); # Determine if Done
> > >>> } until (passes == 2); # Determine if Done
> > >>> _______________________________________________
> > >>> Swift-user mailing list
> > >>> Swift-user at ci.uchicago.edu
> > >>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
