[Swift-user] OS X dependencies [Resolved]
    Gustav Larsson
    larsson at uchicago.edu
    Sun Apr 15 18:55:10 CDT 2012
Thank you Mihael! When arranging the bash -x output file, I happened
to spot the error and fixed it.
So in the output, I noticed SWIFT_HOME, which I had completely
forgotten that I had ever set. I tried removing it from my .bashrc and
swift ran without a hitch. On closer inspection, I had set my
SWIFT_HOME to cog/modules/swift instead of
cog/modules/swift/dist/swift-svn.
The bin/swift bash file checks for the required jar files when it
tries to automatically set SWIFT_HOME. It might be worth doing this
when the user has specified the SWIFT_HOME manually as well. This way
this problem can be avoided. I would be happy to implement this change
by the way.
I'm sorry for all the confusion and thank you for your help!
Gustav
On Sun, Apr 15, 2012 at 4:12 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sun, 2012-04-15 at 13:13 -0500, Gustav Larsson wrote:
>> Thank you for your help Jonathan. After some attempts of upgrading
>> Java and installing xstream manually (every version I test gets a
>> different runtime error), I think I will have to abandon this problem
>> for now and accept that I can't use this computer for now.
> The xstream jar is already in the swift/cog sources. You should not need
> to download is separately.
> Can you run the following:
> bash -x swift inputFile 2>&1 >swiftout.txt
> and post swiftout.txt?
> Mihael
More information about the Swift-user
