[Swift-user] MODIS demo
    Jonathan Monette
    jonmon at mcs.anl.gov
    Sat Apr 14 00:17:05 CDT 2012
I echo David's suggestion but would like to add another. It looks like soft error handling is being used which may not be the best approach when exploring Swift. In the config file you should set the retry count to 0 and set lazy.errors=false. This will cause Swift to fail as soon as the first error is encountered and will provide an error message. This is useful for when you are exploring Swift behavior.
On Apr 13, 2012, at 23:17, David Kelly <davidk at ci.uchicago.edu> wrote:
> Heather,
> You might want to check the path names in the tc.local file. Since about half the tasks fail, I'm guessing either colormodis or getlanduse is pointing to the wrong place. You can verify this by looking at the directory called modis-2012<timestamp>.d. In there is a list of files that end with -info. Look at the "Wrapper" section of these files and you should find more information about what is causing the failures.
> David
>> From: "Heather Stoller" <heather.stoller at gmail.com>
>> To: swift-user at ci.uchicago.edu
>> Sent: Thursday, April 5, 2012 9:37:33 AM
>> Subject: [Swift-user] MODIS demo
>> Hello,
>> I'm a UC student working with Mike Wilde doing some Swift stuff - at
>> present, I'm trying to run the demo to see what can be seen. I get:
>> ^Cheather at ubuntu:~/modis$ ./demo.local urban 10
>> runid=modis-2012.0405.0704-urban-10-10
>> Swift 0.93 swift-r5483 cog-r3339
>> RunID: 20120405-0704-drh1g0ob
>> (input): found 0 files
>> Progress: time: Thu, 05 Apr 2012 07:04:48 -0700
>> Progress: time: Thu, 05 Apr 2012 07:04:49 -0700 Stage in:19
>> Submitting:1
>> Progress: time: Thu, 05 Apr 2012 07:04:50 -0700 Stage in:13
>> Submitting:1 Active:6
>> Progress: time: Thu, 05 Apr 2012 07:04:53 -0700 Stage in:10
>> Submitting:2 Submitted:2 Active:6
>> Progress: time: Thu, 05 Apr 2012 07:04:54 -0700 Stage in:6
>> Submitting:1 Submitted:2 Active:9 Checking status:2
>> Progress: time: Thu, 05 Apr 2012 07:04:55 -0700 Stage in:2
>> Submitting:2 Submitted:1 Active:9 Checking status:3 Stage out:3
>> Progress: time: Thu, 05 Apr 2012 07:04:57 -0700 Submitting:1
>> Submitted:2 Active:9 Checking status:1 Stage out:7
>> Progress: time: Thu, 05 Apr 2012 07:04:58 -0700 Active:3 Checking
>> status:2 Stage out:7 Finished successfully:7 Failed but can retry:1
>> Progress: time: Thu, 05 Apr 2012 07:04:59 -0700 Stage in:2
>> Submitting:2 Submitted:1 Active:3 Stage out:1 Finished successfully:10
>> Failed but can retry:2
>> Progress: time: Thu, 05 Apr 2012 07:05:00 -0700 Active:10 Stage out:1
>> Progress: time: Thu, 05 Apr 2012 07:05:01 -0700 Active:9 Checking
>> status:2 Finished successfully:11
>> Progress: time: Thu, 05 Apr 2012 07:05:02 -0700 Submitting:1 Active:3
>> Checking status:3 Stage out:2 Finished successfully:11 Failed but can
>> retry:2
>> Progress: time: Thu, 05 Apr 2012 07:05:03 -0700 Stage in:2 Active:6
>> Stage out:1 Finished successfully:11 Failed but can retry:2
>> Execution failed:
>> Progress: time: Thu, 05 Apr 2012 07:05:04 -0700 Active:7 Checking
>> status:2 Stage out:1 Failed:1 Finished successfully:11
>> Progress: time: Thu, 05 Apr 2012 07:05:05 -0700 Active:3 Checking
>> status:1 Stage out:3 Failed:4 Finished successfully:11
>> Progress: time: Thu, 05 Apr 2012 07:05:06 -0700 Failed:11 Finished
>> successfully:11
>> lots of "failed but can retry". Does this look right?
>> Heather Stoller
>> Computer Science MS Student
>> University of Chicago
>> Cell: 843-290-6711
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
