[Swift-user] Java out of memory error
Lorenzo Pesce
lpesce at uchicago.edu
Mon Apr 2 15:06:00 CDT 2012
Perfect. Let me try this.
On Apr 2, 2012, at 3:04 PM, Michael Wilde wrote:
> I think Lorenzo may be using "module load swift".
> Can this also be set with an env var:
> SWIFT_HEAP_MAX=1024M swift ...rest of swift args here
> - Mike
>> From: "David Kelly" <davidk at ci.uchicago.edu>
>> To: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> Cc: swift-user at ci.uchicago.edu
>> Sent: Monday, April 2, 2012 2:58:52 PM
>> Subject: Re: [Swift-user] Java out of memory error
>> Lorenzo,
>> You can edit the 'swift' shell script and modify this line:
>> HEAPMAX=256M
>> The default of 256M is probably too low.. I set it to a default of
>> 1024M in trunk.
>> David
>>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>>> To: swift-user at ci.uchicago.edu
>>> Sent: Monday, April 2, 2012 2:51:02 PM
>>> Subject: [Swift-user] Java out of memory error
>>> Any idea?
>>> Swift version 0.93 loaded
>>> Swift 0.93 swift-r5483 cog-r3339
>>> RunID: 20120402-1945-mix1mk13
>>> Progress: time: Mon, 02 Apr 2012 19:45:30 +0000
>>> Progress: time: Mon, 02 Apr 2012 19:45:54 +0000 Initializing:1
>>> Progress: time: Mon, 02 Apr 2012 19:45:57 +0000 Initializing:17215
>>> Selecting site:65
>>> Progress: time: Mon, 02 Apr 2012 19:46:01 +0000 Selecting site:17280
>>> Progress: time: Mon, 02 Apr 2012 19:46:31 +0000 Selecting site:17280
>>> Progress: time: Mon, 02 Apr 2012 19:47:04 +0000 Selecting site:17280
>>> Exception in thread "Progress ticker" java.lang.OutOfMemoryError: GC
>>> overhead limit exceeded
>>> at
>>> org.griphyn.vdl.karajan.lib.RuntimeStats$ProgressTicker.getSummary(RuntimeStats.java:170)
>>> at
>>> org.griphyn.vdl.karajan.lib.RuntimeStats$ProgressTicker.printStates(RuntimeStats.java:194)
>>> at
>>> org.griphyn.vdl.karajan.lib.RuntimeStats$ProgressTicker.dumpState(RuntimeStats.java:159)^C
>>> Exception in thread "Timer-0" java.lang.OutOfMemoryError: GC
>>> overhead
>>> limit exceeded
>>> ^CJava HotSpot(TM) 64-Bit Server VM warning: Exception
>>> java.lang.OutOfMemoryError occurred dispatching signal SIGINT to
>>> handler- the VM may need to be forcibly terminated
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user
