[Swift-user] Swift-MosaStore integration problem
Tim Armstrong
tim.g.armstrong at gmail.com
Thu Oct 27 17:12:29 CDT 2011
Nobody answered the part of the original question about building with debug
symbols. Looking at the ant build file, it seems like the options to javac
are controlled by a target in the file mbuild.xml. You can run ant with the
switch -Ddebug=on in order to build the java class with the default debug
info. If you want to control which debug info you include you might need to
modify mbuild.xml
- Tim
On Thu, Oct 27, 2011 at 5:01 PM, Ben Clifford <benc at hawaga.org.uk> wrote:
> On Oct 27, 2011, at 2:35 PM, Emalayan Vairavanathan wrote:
> > Dear All,
> > When I try to run the HelloWorld.swift with MosaStore (MosaStore is a
> distributed storage developed by us) it is terminating with an error.
> > Here HelloWorld.swift script is copied into the MosaStore filesystem.
> Also Swift has write permission in the file system. Because it can create
> some temporary files (swift.log and first-20111026-1848-hmo97vu7.log). But
> then it prints the error below and terminates (I have attached the log
> files. I am using swift 0.93).
> > Max heap: 259522560
> > Recompilation suppressed.
> Its saying reompilation suppressed - meaning that it thinks that some
> (though I don't remember which) intermediate files already exist, and so is
> not (re)generating them.
> Perhaps send ls -l of your directory to this list.
> Ben
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20111027/6e5dab97/attachment.html>
More information about the Swift-user
