[Swift-user] app argument int passed as float
Ketan Maheshwari ketancmaheshwari at gmail.com
Fri Oct 21 15:10:13 CDT 2011
Mike,
Indeed the output seems to be as expected. I just tried this and worked for
me. However, if you see the log, at the point where the arguments are passed
to the worker it gets converted to float. See this line in the log of this
run:
2011-10-21 15:05:03,291-0500 DEBUG vdl:execute2 JOB_START
jobid=echo-suhonmhk tr=echo arguments=[foo, 35.0]
tmpdir=km-20111021-1504-f4bc0xg4/jobs/s/echo-suhonmhk host=localhost
35 became 35.0 there.
Ketan
On Fri, Oct 21, 2011 at 2:38 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> I tried this with an example closer to what you wrote in the initial
> message, Ketan.
> It still seems to work OK under the trunk rev indicated:
> bri$ cat km1.swift
> type outfile;
> app (outfile o ) myapp(string a, int b ){
>  echo a b  stdout=@o;
> outfile out<"km1.out">;
> out = myapp("foo", 35 );
> bri$ swift km1.swift
> no sites file specified, setting to default:
> /home/wilde/swift/rev/trunk/etc/sites.xml
> Swift svn swift-r5234 cog-r3296
> RunID: 20111021-1436-z7s2z5rb
> Progress:  time: Fri, 21 Oct 2011 14:37:01 -0500
> Final status: Fri, 21 Oct 2011 14:37:01 -0500  Finished successfully:1
> bri$ cat km1.out
> foo 35
> bri$
> - Mike
> > From: "Michael Wilde" <wilde at mcs.anl.gov>
> > To: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > Cc: "Swift User" <swift-user at ci.uchicago.edu>
> > Sent: Friday, October 21, 2011 2:33:48 PM
> > Subject: Re: [Swift-user] app argument int passed as float
> > In at least some recent version of trunk, ints seem to get passed ok,
> > as below.
> > Now lets see where the difference is.
> > - Mike
> > bri$ cat args.swift
> > type file;
> > app (file o) echo(int i)
> > echo i stdout=@o;
> > file eo<"echo.out">;
> > eo=echo(123);
> > bri$ which swift
> > ~/swift/rev/trunk/bin/swift
> > bri$ swift -version
> > bri$ swift args.swift
> > RunID: 20111021-1431-8mzx0ya2
> > Progress: time: Fri, 21 Oct 2011 14:31:04 -0500
> > Final status: Fri, 21 Oct 2011 14:31:04 -0500 Finished successfully:1
> > bri$ cat echo.out
> > 123
> > bri$
> > > From: "Ketan Maheshwari" <ketancmaheshwari at gmail.com>
> > > To: "Swift User" <swift-user at ci.uchicago.edu>
> > > Sent: Wednesday, October 19, 2011 8:30:24 PM
> > > Subject: [Swift-user] app argument int passed as float
> > > Hi,
> > > In my app definition, I have an argument of type int that is
> > > expected
> > > by the executable.
> > > I define my app something like this:
> > > (outfile o ) app myapp(string a, int b, datafile c, ...){
> > > cmd a b c stdout @o;
> > > I call this as:
> > > <..mappers..>
> > > out = myapp("foo", 35, @afile, ...);
> > > However, it seems that at the time of the actual call, the value 35
> > > which is an int get replaced by the value 35.0, a float.
> > > I could see this from the arguments dumped by swift at the end of
> > > exception message:
> > > Exception in presgt:
> > > Arguments: [TEST, 35.0, .....
> > > The underlying app binary doesn't like because apparently the java
> > > is
> > > calling Integer.parseInt and getting a float formatted string.
> > > Any ideas?
> > > Regards, --
> > > Ketan
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
> Michael Wilde
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20111021/3ece73e3/attachment.html>
More information about the Swift-user mailing list
