[Swift-user] queue problem?
    Sheri Mickelson
    mickelso at mcs.anl.gov
    Thu May 19 12:13:22 CDT 2011
I hit the queue problem again in my latest attempt (queuedsize > 0 but no job dequeued. Queued: {})
Here's a summary of my attempts in the order I tried them:
-I used swift-0.92.1 on the mcs machines and everything worked fine.
-I used swift-0.92.1 on fusion and I hit the queue failure (used coasters).
-I used Justin's trunk branch on fusion and got the "mapper.existing() returned a path [3] that it
cannot     subsequently map" error
-I used Mike's older version (/home/wilde/swift/rev/0.92/bin/swift) on fusion and it worked after I
fixed the path problem.
-I tried using swift-0.92.1 again on fusion and got the queue error again.  This was using the same
code,directories,etc that I used while running with Mike's version.  I just changed the hard coded
path of which version of swift I was using.
I have the last attempt I tried in /fusion/gpfs/home/mickelso/amwg-swift/swift
Also, I piped the output to script.out.
-Sheri
Justin M Wozniak wrote:
> Yeah, I was about to suggest that the file might not be there.  Let me
> know what you find.
> On Thu, 19 May 2011, Sheri Mickelson wrote:
>> Hi Mike,
>> I was originally running 0.92.1, but I got the "mapper.existing()
>> returned a path [3] that it cannot subsequently map" error using
>> Justin's trunk version.
>> I went back to an older version of swift and I think I might have
>> found what was causing the initial error (an error in one of my csh
>> scripts that had the wrong path in it).  I'm still looking into it and
>> let you know how it goes.
>> Justin, the path to my working directory is
>> /home/climate1/mickelso/amwg-swift/test-swift.
>> -Sheri
>> Michael Wilde wrote:
>>> Also, SHeri - are you using Swift 0.92.1?  This looks a bit like the
>>> bug in 0.92 that was fixed in 0.92.1
>>> - Mike
>>> ----- Original Message -----
>>>> Is this a SwiftScript that ran successfully on the MCS machines but
>>>> fails
>>>> on Fusion? If so, can you point me to the working directory for this
>>>> run?
>>>> Justin
>>>> On Mon, 16 May 2011, Sheri Mickelson wrote:
>>>>> I'm seeing a different error now:
>>>>> mapper.existing() returned a path [3] that it cannot subsequently
>>>>> map
>>>>> It starts up, but dies shortly after that. I attached the log file.
>>>>> -Sheri
>>>>>> That's probably a perms thing, I just reapplied the permissions,
>>>>>> please try
>>>>>> again.
>>>>>>> Hi Justin,
>>>>>>> I'm getting this error when swift tries to run:
>>>>>>> Exception in thread "main" java.lang.NoClassDefFoundError:
>>>>>>> org/griphyn/vdl/karajan/Loader
>>>>>>> Caused by: java.lang.ClassNotFoundException:
>>>>>>> org.griphyn.vdl.karajan.Loader
>>>>>>>     at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
>>>>>>>     at java.security.AccessController.doPrivileged(Native Method)
>>>>>>>     at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
>>>>>>>     at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
>>>>>>>     at
>>>>>>>     sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
>>>>>>>     at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
>>>>>>> Could not find the main class: org.griphyn.vdl.karajan.Loader.
>>>>>>> Program
>>>>>>> will exit.
>>>>>>> -Sheri
>>>>>>>> Let's go with my trunk-based installation in the location below
>>>>>>>> for now.
>>>>>>>> I tried testing this again over the weekend but did not get
>>>>>>>> through the
>>>>>>>> queue. I have already set up the additional logging in this
>>>>>>>> installation.
>>>>>>>> /homes/wozniak/Public/cog/modules/swift/dist/swift-svn/bin/swift
>>>>>>>>     Justin
>>>>>>>> On Fri, 13 May 2011, Sheri Mickelson wrote:
>>>>>>>>> Here's the log file.
>>>>>>>>> This is the first time I'm running this version of swift on
>>>>>>>>> fusion. I
>>>>>>>>> had done my development work with this swift version on an mcs
>>>>>>>>> compute
>>>>>>>>> machine.
>>>>>>>>> -Sheri
>>>>>>>>>> Hello
>>>>>>>>>>     Can you send the log for this run?
>>>>>>>>>>     Is this a new issue that appeared after an update?
>>>>>>>>>>     Also, in any future runs regarding this issue, please add
>>>>>>>>>> log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor
>>>>>>>>>> = DEBUG
>>>>>>>>>> (one line) to your etc/log4j.properties file.
>>>>>>>>>>     Thanks
>>>>>>>>>>     Justin
>>>>>>>>>>> I'm running into a problem running swift version 0.92.1 on
>>>>>>>>>>> fusion with
>>>>>>>>>>> coasters.
>>>>>>>>>>> This is the error I'm seeing:
>>>>>>>>>>> Progress: Selecting site:168 Submitted:23 Active:2
>>>>>>>>>>> Progress: Selecting site:168 Submitted:23 Active:1 Checking
>>>>>>>>>>> status:1
>>>>>>>>>>> Progress: Selecting site:167 Stage in:1 Submitted:22 Active:2
>>>>>>>>>>> Finished successfully:1
>>>>>>>>>>> java.lang.Throwable
>>>>>>>>>>>     at
>>>>>>>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.requeueNonFitting(BlockQueueProcessor.java:252)
>>>>>>>>>>>     at
>>>>>>>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.updatePlan(BlockQueueProcessor.java:520)
>>>>>>>>>>>     at
>>>>>>>>>>> org.globus.cog.abstraction.coaster.service.job.manager.BlockQueueProcessor.run(BlockQueueProcessor.java:109)
>>>>>>>>>>> java.lang.Throwable
>>>>>>>>>>>     at
>>>>>>>>>>>     at
>>>>>>>>>>>     at
>>>>>>>>>>> Shutting down worker
>>>>>>>>>>> And here's my sites file:
>>>>>>>>>>> <config>
>>>>>>>>>>> <pool handle="fusion">
>>>>>>>>>>>  <execution jobmanager="local:pbs" provider="coaster"
>>>>>>>>>>>  url="none"/>
>>>>>>>>>>>  <profile namespace="globus" key="maxtime">3600</profile>
>>>>>>>>>>>  <profile namespace="globus" key="workersPerNode">1</profile>
>>>>>>>>>>>  <profile namespace="globus" key="slots">1</profile>
>>>>>>>>>>>  <profile namespace="globus" key="nodeGranularity">4</profile>
>>>>>>>>>>>  <profile namespace="globus" key="maxNodes">2</profile>
>>>>>>>>>>>  <profile namespace="globus" key="queue">batch</profile>
>>>>>>>>>>>  <profile namespace="karajan" key="jobThrottle">0.23</profile>
>>>>>>>>>>>  key="initialScore">10000</profile>
>>>>>>>>>>>  <profile namespace="globus" key="project">parvis</profile>
>>>>>>>>>>>  key="lowOverAllocation">100</profile>
>>>>>>>>>>>  key="highOverAllocation">100</profile>
>>>>>>>>>>>  <filesystem provider="local"/>
>>>>>>>>>>>  <workdirectory>/fusion/gpfs/home/mickelso/amwg-swift/swift/</workdirectory>
>>>>>>>>>>> </pool>
>>>>>>>>>>> </config>
>>>>>>>>>>> Do you know what might be causing this?
>>>>>>>>>>> Thanks, Sheri
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Swift-user mailing list
>>>>>>>>>>> Swift-user at ci.uchicago.edu
>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
>>>> Justin M Wozniak
More information about the Swift-user
