[Swift-user] badness
Allan Espinosa
aespinosa at cs.uchicago.edu
Fri May 13 15:28:08 CDT 2011
Here's the tarball. It contains postproc.kml and all the files
accessed by all the readData callls.
2011/5/13 Mihael Hategan <hategan at mcs.anl.gov>:
> Seems like it pops up early in the run, so I might be able to reproduce
> this.
> Can you attach the file so that I can save it and run it. Also, there
> are a few readDatas there. Can you send me the contents of those files?
> Also a ls in the run directory, so that I know what files should be
> there.
> And, of course, whether this happens on every run or occasionally.
> Mihael
> On Fri, 2011-05-13 at 00:01 -0500, Allan Espinosa wrote:
>> Here's the kml code generated by the trunk build:
>> <project><!-- CACHE ID 9da6434d-5b79-4076-ad0b-77e09abaa5fd -->
>> <import file="sys.xml"/>
>> <import file="scheduler.xml"/>
>> <import file="rlog.xml"/>
>> <import file="vdl.k"/>
>> <types>
>> <xs:schema
>> targetNamespace="http://ci.uchicago.edu/swift/2009/02/swiftscript"
>> xmlns="http://ci.uchicago.edu/swift/2009/02/swiftscript"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xs="http://www.w3.org/2001/XMLSchema">
>> <xs:simpleType name="SgtDim">
>> <xs:restriction base="string"/>
>> </xs:simpleType>
>> <xs:simpleType name="Variation">
>> </xs:simpleType>
>> <xs:simpleType name="Seismogram">
>> </xs:simpleType>
>> <xs:simpleType name="PeakValue">
>> </xs:simpleType>
>> <xs:complexType name="Station">
>> <xs:sequence>
>> <xs:element name="name" type="string"/>
>> <xs:element name="lat" type="float"/>
>> <xs:element name="lon" type="float"/>
>> <xs:element name="erf" type="int"/>
>> <xs:element name="variation_scenario" type="int"/>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:complexType name="Sgt">
>> <xs:sequence>
>> <xs:element name="x" type="SgtDim"/>
>> <xs:element name="y" type="SgtDim"/>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:complexType name="Rupture">
>> <xs:sequence>
>> <xs:element name="source" type="int"/>
>> <xs:element name="index" type="int"/>
>> <xs:element name="size" type="int"/>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:simpleType name="StationFile">
>> </xs:simpleType>
>> <xs:simpleType name="RuptureFile">
>> </xs:simpleType>
>> <xs:simpleType name="VariationFile">
>> </xs:simpleType>
>> <xs:complexType name="offset">
>> <xs:sequence>
>> <xs:element name="off" type="int"/>
>> </xs:sequence>
>> </xs:complexType>
>> <xs:simpleType name="offset_file">
>> </xs:simpleType>
>> </xs:schema>
>> </types>
>> <global name="swift#string#17056">
>> <vdl:new type="string" value="" />
>> </global>
>> <global name="swift#string#17025">
>> <vdl:new type="string" value="out=" />
>> </global>
>> <global name="swift#string#17014">
>> <vdl:new type="string" value="simulation_out_pointsX=2" />
>> </global>
>> <global name="swift#string#17030">
>> <vdl:new type="string" value="-l" />
>> </global>
>> <global name="swift#string#17012">
>> <vdl:new type="string" value="ntout=" />
>> </global>
>> <global name="swift#string#17028">
>> <vdl:new type="string" value="-e" />
>> </global>
>> <global name="swift#string#17037">
>> <vdl:new type="string" value=".txt" />
>> </global>
>> <global name="swift#string#17044">
>> value="gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results"
>> </global>
>> <global name="swift#string#17015">
>> <vdl:new type="string" value="simulation_out_pointsY=1" />
>> </global>
>> <global name="swift#string#17010">
>> <vdl:new type="string" value="outputBinary=1" />
>> </global>
>> <global name="swift#string#17049">
>> value="gsiftp://gridftp.ranger.tacc.teragrid.org//work/01035/tg802895/science/cybershake/data/SgtFiles"
>> </global>
>> <global name="swift#string#17060">
>> <vdl:new type="string" value=".bsa, " />
>> </global>
>> <global name="swift#string#17036">
>> <vdl:new type="string" value="/" />
>> </global>
>> <global name="swift#string#17006">
>> <vdl:new type="string" value="sgt_yfile=" />
>> </global>
>> <global name="swift#string#17032">
>> <vdl:new type="string" value="-r" />
>> </global>
>> <global name="swift#string#17039">
>> <vdl:new type="string" value="LGU/offset-" />
>> </global>
>> <global name="swift#string#17031">
>> <vdl:new type="string" value="-s" />
>> </global>
>> <global name="swift#string#17059">
>> <vdl:new type="string" value="/PeakVals_" />
>> </global>
>> <global name="swift#string#17017">
>> <vdl:new type="string" value="surfseis_rspectra_output_units=cmpersec2" />
>> </global>
>> <global name="swift#string#17022">
>> <vdl:new type="string" value="surfseis_rspectra_period=" />
>> </global>
>> <global name="swift#string#17029">
>> <vdl:new type="string" value="-v" />
>> </global>
>> <global name="swift#string#17007">
>> <vdl:new type="string" value="extract_sgt_xfile=" />
>> </global>
>> <global name="swift#string#17000">
>> <vdl:new type="string" value="stat=" />
>> </global>
>> <global name="swift#string#17013">
>> <vdl:new type="string" value="seis_file=" />
>> </global>
>> <global name="swift#string#17027">
>> <vdl:new type="string" value="/rup_tmp" />
>> </global>
>> <global name="swift#string#17004">
>> <vdl:new type="string" value="rupmodfile=" />
>> </global>
>> <global name="swift#string#17011">
>> <vdl:new type="string" value="mergeOutput=1" />
>> </global>
>> <global name="swift#string#17005">
>> <vdl:new type="string" value="sgt_xfile=" />
>> </global>
>> <global name="swift#string#17043">
>> value="gsiftp://gridftp.ranger.tacc.teragrid.org//scratch/01035/tg802895/science/cybershake/Results"
>> </global>
>> <global name="swift#string#17020">
>> <vdl:new type="string" value="simulation_out_timesamples=" />
>> </global>
>> <global name="swift#string#17051">
>> <vdl:new type="string" value="getsub.rb" />
>> </global>
>> <global name="swift#string#17057">
>> <vdl:new type="string" value="/Seismogram_" />
>> </global>
>> <global name="swift#string#17058">
>> <vdl:new type="string" value=".grm, " />
>> </global>
>> <global name="swift#string#17008">
>> <vdl:new type="string" value="extract_sgt_yfile=" />
>> </global>
>> <global name="swift#string#17021">
>> <vdl:new type="string" value="simulation_out_timeskip=" />
>> </global>
>> <global name="swift#string#17033">
>> <vdl:new type="string" value="_" />
>> </global>
>> <global name="swift#string#17040">
>> <vdl:new type="string" value="all" />
>> </global>
>> <global name="swift#string#17018">
>> <vdl:new type="string" value="surfseis_rspectra_output_type=aa" />
>> </global>
>> <global name="swift#string#17009">
>> <vdl:new type="string" value="extract_sgt=0" />
>> </global>
>> <global name="swift#string#17055">
>> value="gsiftp://gridftp.ranger.tacc.teragrid.org//scratch/projects/tg/tera3d/CyberShake2007/ruptures/RuptureVariations_35_V2_3"
>> </global>
>> <global name="swift#string#17001">
>> <vdl:new type="string" value="extract_sgt=1" />
>> </global>
>> <global name="swift#string#17003">
>> <vdl:new type="string" value="slat=" />
>> </global>
>> <global name="swift#string#17046">
>> <vdl:new type="string" value="getsgtvar.rb" />
>> </global>
>> <global name="swift#string#17035">
>> <vdl:new type="string" value="/varlist/" />
>> </global>
>> <global name="swift#string#17024">
>> <vdl:new type="string" value="in=" />
>> </global>
>> <global name="swift#string#17002">
>> <vdl:new type="string" value="slon=" />
>> </global>
>> <global name="swift#string#17019">
>> <vdl:new type="string" value="surfseis_rspectra_apply_byteswap=no" />
>> </global>
>> <global name="swift#string#17016">
>> value="surfseis_rspectra_seismogram_units=cmpersec" />
>> </global>
>> <global name="swift#string#17023">
>> <vdl:new type="string" value=" surfseis_rspectra_apply_filter_highHZ=" />
>> </global>
>> <global name="swift#int#1">
>> <vdl:new type="int" value="1" />
>> </global>
>> <global name="swift#int#664">
>> <vdl:new type="int" value="664" />
>> </global>
>> <global name="swift#int#3000">
>> <vdl:new type="int" value="3000" />
>> </global>
>> <global name="swift#int#20">
>> <vdl:new type="int" value="20" />
>> </global>
>> <global name="swift#int#60">
>> <vdl:new type="int" value="60" />
>> </global>
>> <global name="swift#float#17041">
>> <vdl:new type="float" value="5.0" />
>> </global>
>> <global name="swift#float#17042">
>> <vdl:new type="float" value="0.1" />
>> </global>
>> <element name="extract" arguments="_ext,_sgt,_stat,_var">
>> <parameterlog>
>> <string>input</string>
>> <string>_sgt</string>
>> <vdl:getdatasetprovenanceid var="{_sgt}" />
>> <string>{#thread}</string>
>> </parameterlog>
>> <parameterlog>
>> <string>_stat</string>
>> <vdl:getdatasetprovenanceid var="{_stat}" />
>> </parameterlog>
>> <parameterlog>
>> <string>_var</string>
>> <vdl:getdatasetprovenanceid var="{_var}" />
>> </parameterlog>
>> <parameterlog>
>> <string>output</string>
>> <string>_ext</string>
>> <vdl:getdatasetprovenanceid var="{_ext}" />
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=31 thread={#thread}
>> name=extract"/>
>> <vdl:execute>
>> <vdl:tr>extract</vdl:tr>
>> <vdl:stagein var="{_sgt}"/>
>> <vdl:stagein var="{_stat}"/>
>> <vdl:stagein var="{_var}"/>
>> <vdl:stageout var="{_ext}"/>
>> <vdl:arguments>
>> <swiftscript:strcat>
>> <variable>swift#string#17000</variable><getfield>
>> <argument name="var"><variable>_stat</variable></argument>
>> <argument name="path">name</argument>
>> </getfield>
>> </swiftscript:strcat>
>> <variable>swift#string#17001</variable>
>> <variable>swift#string#17002</variable><getfield>
>> <argument name="path">lon</argument>
>> </getfield>
>> <variable>swift#string#17003</variable><getfield>
>> <argument name="path">lat</argument>
>> </getfield>
>> <variable>swift#string#17004</variable><swiftscript:filename>
>> <variable>_var</variable>
>> </swiftscript:filename>
>> <variable>swift#string#17005</variable><swiftscript:filename>
>> <getfield>
>> <argument name="var"><variable>_sgt</variable></argument>
>> <argument name="path">x</argument>
>> </getfield>
>> <variable>swift#string#17006</variable><swiftscript:filename>
>> <getfield>
>> <argument name="path">y</argument>
>> </getfield>
>> <variable>swift#string#17007</variable><swiftscript:filename>
>> <getfield>
>> <argument name="var"><variable>_ext</variable></argument>
>> </getfield>
>> <variable>swift#string#17008</variable><swiftscript:filename>
>> <getfield>
>> </getfield>
>> </vdl:arguments>
>> </vdl:execute>
>> <vdl:closedataset var="{_ext}"/>
>> <log level="debug" message="PROCEDURE_END line=31"/></element>
>> <element name="seispeak" arguments="_seis,_peak,_sgt,_var,_stat">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> <string>_seis</string>
>> <vdl:getdatasetprovenanceid var="{_seis}" />
>> </parameterlog>
>> <parameterlog>
>> <string>_peak</string>
>> <vdl:getdatasetprovenanceid var="{_peak}" />
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=42 thread={#thread}
>> name=seispeak"/>
>> <vdl:execute>
>> <vdl:tr>seispeak</vdl:tr>
>> <vdl:stageout var="{_seis}"/>
>> <vdl:stageout var="{_peak}"/>
>> <vdl:arguments>
>> </getfield>
>> <variable>swift#string#17009</variable>
>> </getfield>
>> </getfield>
>> <variable>swift#string#17010</variable>
>> <variable>swift#string#17011</variable>
>> <variable>swift#string#17012</variable><variable>num_time_steps</variable>
>> <getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> <variable>swift#string#17013</variable><swiftscript:filename>
>> <variable>_seis</variable>
>> <variable>swift#string#17014</variable>
>> <variable>swift#string#17015</variable>
>> <variable>swift#string#17016</variable>
>> <variable>swift#string#17017</variable>
>> <variable>swift#string#17018</variable>
>> <variable>swift#string#17019</variable>
>> <variable>swift#string#17020</variable><variable>num_time_steps</variable>
>> <variable>swift#string#17021</variable><variable>simulation_timeskip</variable>
>> <variable>swift#string#17022</variable><variable>spectra_period1</variable>
>> <variable>swift#string#17023</variable><variable>filter_highhz</variable>
>> <variable>swift#string#17024</variable><swiftscript:filename>
>> <variable>swift#string#17025</variable><swiftscript:filename>
>> <variable>_peak</variable>
>> </vdl:arguments>
>> </vdl:execute>
>> <vdl:closedataset var="{_seis}"/>
>> <vdl:closedataset var="{_peak}"/>
>> <log level="debug" message="PROCEDURE_END line=42"/></element>
>> <element name="seispeak_local" arguments="_seis,_peak,_sgt,_var,_stat">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=70 thread={#thread}
>> name=seispeak_local"/>
>> <vdl:execute>
>> <vdl:tr>seispeak_local</vdl:tr>
>> <vdl:arguments>
>> </getfield>
>> </getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> </vdl:arguments>
>> </vdl:execute>
>> <log level="debug" message="PROCEDURE_END line=70"/></element>
>> <element name="seispeak_agg" arguments="_seis,_peak,_sgt,_var,_stat,n">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> <string>n</string>
>> <vdl:getdatasetprovenanceid var="{n}" />
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=98 thread={#thread}
>> name=seispeak_agg"/>
>> <vdl:execute>
>> <vdl:tr>fake</vdl:tr>
>> <vdl:stagein var="{n}"/>
>> <vdl:arguments>
>> <getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> <getfield>
>> </getfield>
>> <variable>n</variable>
>> <swiftscript:filenames>
>> </swiftscript:filenames>
>> </vdl:arguments>
>> </vdl:execute>
>> <log level="debug" message="PROCEDURE_END line=98"/></element>
>> <element name="getsite_file" arguments="_stat,_run_id">
>> <parameterlog>
>> <string>_run_id</string>
>> <vdl:getdatasetprovenanceid var="{_run_id}" />
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=112 thread={#thread}
>> name=getsite_file"/>
>> <vdl:execute>
>> <vdl:tr>getsite</vdl:tr>
>> <vdl:stagein var="{_run_id}"/>
>> <vdl:stageout var="{_stat}"/>
>> <vdl:arguments>
>> <variable>_run_id</variable>
>> </vdl:arguments>
>> <vdl:stdout>
>> </vdl:stdout>
>> </vdl:execute>
>> <vdl:closedataset var="{_stat}"/>
>> <log level="debug" message="PROCEDURE_END line=112"/></element>
>> <element name="get_site" arguments="_stat,_run_id">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <log level="info"><string>STARTCOMPOUND thread={#thread}
>> name=get_site</string></log>
>> <set name="file">
>> <vdl:new type="StationFile" dbgname="file">
>> <vdl:mapping descriptor="single_file_mapper">
>> <vdl:parameter name="file" value="/var/tmp/site_tmp"/>
>> <vdl:parameter name="input" value="true" />
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>intermediate</string>
>> <string>file</string>
>> <vdl:getdatasetprovenanceid var="{file}" />
>> </parameterlog>
>> <sequentialWithID>
>> <sequential>
>> <sequential>
>> <log level="debug" message="INTERNALPROC_START
>> thread={#thread} name=readData"/>
>> <set name="swift#cs"><variable>#thread</variable></set>
>> <readData>
>> <parallel>
>> <sequential>
>> <set
>> name="swift#callInternalValue"><variable>_stat</variable></set>
>> <parameterlog>
>> <string>TODO_name_or_pos</string>
>> <vdl:getdatasetprovenanceid var="{swift#callInternalValue}" />
>> <string>{swift#cs}</string>
>> </parameterlog>
>> <variable>swift#callInternalValue</variable>
>> </sequential>
>> <sequential>
>> <set
>> name="swift#callInternalValue"><variable>file</variable></set>
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> </parallel>
>> </readData>
>> <log level="debug" message="INTERNALPROC_END thread={#thread}"/>
>> </sequential>
>> </sequential>
>> </sequentialWithID><vdl:closedataset var="{_stat}"/>
>> <log level="info"><string>ENDCOMPOUND
>> thread={#thread}</string></log></element>
>> <element name="getrupture_file" arguments="_rup,_run_id">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> <string>_rup</string>
>> <vdl:getdatasetprovenanceid var="{_rup}" />
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=122 thread={#thread}
>> name=getrupture_file"/>
>> <vdl:execute>
>> <vdl:tr>getrupture</vdl:tr>
>> <vdl:stageout var="{_rup}"/>
>> <vdl:arguments>
>> </vdl:arguments>
>> <vdl:stdout>
>> <variable>_rup</variable>
>> </vdl:stdout>
>> </vdl:execute>
>> <vdl:closedataset var="{_rup}"/>
>> <log level="debug" message="PROCEDURE_END line=122"/></element>
>> <element name="get_ruptures" arguments="_rup,_run_id,_site">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> <string>_site</string>
>> <vdl:getdatasetprovenanceid var="{_site}" />
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> name=get_ruptures</string></log>
>> <set name="swift#mapper#17026">
>> <vdl:new type="string" dbgname="swift#mapper#17026" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17026</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17026}" />
>> </parameterlog>
>> <set name="file">
>> <vdl:new type="RuptureFile" dbgname="file">
>> <vdl:parameter
>> name="file"><variable>swift#mapper#17026</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> </parameterlog>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <argument name="value">
>> <getfield>
>> <argument name="var"><variable>_site</variable></argument>
>> </getfield><variable>swift#string#17027</variable>
>> </argument>
>> </vdl:setfieldvalue>
>> </sequential>
>> <sequential>
>> <sequential>
>> <readData>
>> <parallel>
>> <sequential>
>> <set
>> name="swift#callInternalValue"><variable>_rup</variable></set>
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> <sequential>
>> <set
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> </parallel>
>> </readData>
>> </sequential>
>> </sequential>
>> </parallel><vdl:closedataset var="{_rup}"/>
>> <element name="getvariation_file" arguments="_var,_site,_rup,_loc">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> <string>_loc</string>
>> <vdl:getdatasetprovenanceid var="{_loc}" />
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=132 thread={#thread}
>> name=getvariation_file"/>
>> <vdl:execute>
>> <vdl:tr>variation_mapper</vdl:tr>
>> <vdl:stagein var="{_site}"/>
>> <vdl:stagein var="{_rup}"/>
>> <vdl:stagein var="{_loc}"/>
>> <vdl:stageout var="{_var}"/>
>> <vdl:arguments>
>> <variable>swift#string#17028</variable>
>> <getfield>
>> <argument name="path">erf</argument>
>> </getfield>
>> <variable>swift#string#17029</variable>
>> <getfield>
>> <argument name="path">variation_scenario</argument>
>> </getfield>
>> <variable>swift#string#17030</variable>
>> <variable>_loc</variable>
>> <variable>swift#string#17031</variable>
>> <getfield>
>> <argument name="var"><variable>_rup</variable></argument>
>> <argument name="path">source</argument>
>> </getfield>
>> <variable>swift#string#17032</variable>
>> <getfield>
>> <argument name="path">index</argument>
>> </getfield>
>> </vdl:arguments>
>> <vdl:stdout>
>> </vdl:stdout>
>> </vdl:execute>
>> <vdl:closedataset var="{_var}"/>
>> <log level="debug" message="PROCEDURE_END line=132"/></element>
>> <element name="get_variations" arguments="_vars,_site,_rup,_loc">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> <string>_vars</string>
>> <vdl:getdatasetprovenanceid var="{_vars}" />
>> </parameterlog>
>> name=get_variations</string></log>
>> <set name="fname">
>> <vdl:new type="string" dbgname="fname" waitfor="88002" />
>> </set>
>> <parameterlog>
>> <string>fname</string>
>> <vdl:getdatasetprovenanceid var="{fname}" />
>> </parameterlog>
>> <set name="swift#mapper#17034">
>> <vdl:new type="string" dbgname="swift#mapper#17034" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17034</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17034}" />
>> </parameterlog>
>> <set name="file">
>> <vdl:new type="VariationFile" dbgname="file">
>> <vdl:parameter
>> name="file"><variable>swift#mapper#17034</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> </parameterlog>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>fname</variable>
>> </argument>
>> <getfield>
>> </getfield><variable>swift#string#17033</variable><getfield>
>> </getfield>
>> </argument>
>> <partialCloseDataset var="{fname}" closeID="88002" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <getfield>
>> </getfield><variable>swift#string#17035</variable><getfield>
>> </getfield><variable>swift#string#17036</variable><variable>fname</variable><variable>swift#string#17037</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <sequential>
>> <readData>
>> <parallel>
>> <sequential>
>> <set
>> name="swift#callInternalValue"><variable>_vars</variable></set>
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> <sequential>
>> <set
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> </parallel>
>> </readData>
>> </sequential>
>> </sequential>
>> </parallel><vdl:closedataset var="{_vars}"/>
>> <element name="mkoffset" arguments="_off,_size,_group_size">
>> <parameterlog>
>> <string>_size</string>
>> <vdl:getdatasetprovenanceid var="{_size}" />
>> </parameterlog>
>> <parameterlog>
>> <string>_group_size</string>
>> <vdl:getdatasetprovenanceid var="{_group_size}" />
>> </parameterlog>
>> <parameterlog>
>> <string>_off</string>
>> <vdl:getdatasetprovenanceid var="{_off}" />
>> </parameterlog>
>> name=mkoffset</string></log>
>> <set name="swift#mapper#17038">
>> <vdl:new type="string" dbgname="swift#mapper#17038" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17038</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17038}" />
>> </parameterlog>
>> <set name="file">
>> <vdl:new type="offset_file" dbgname="file">
>> <vdl:parameter
>> name="file"><variable>swift#mapper#17038</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> </parameterlog>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>swift#string#17039</variable><variable>_size</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <sequential>
>> <readData>
>> <parallel>
>> <sequential>
>> <set
>> name="swift#callInternalValue"><variable>_off</variable></set>
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> <sequential>
>> <set
>> <parameterlog>
>> </parameterlog>
>> </sequential>
>> </parallel>
>> </readData>
>> </sequential>
>> </sequential>
>> </parallel><vdl:closedataset var="{_off}"/>
>> <element name="mkoffset_file" arguments="_off,_size,_group_size">
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <parameterlog>
>> </parameterlog>
>> <log level="debug" message="PROCEDURE line=155 thread={#thread}
>> name=mkoffset_file"/>
>> <vdl:execute>
>> <vdl:tr>mkoffset</vdl:tr>
>> <vdl:stagein var="{_size}"/>
>> <vdl:stagein var="{_group_size}"/>
>> <vdl:stageout var="{_off}"/>
>> <vdl:arguments>
>> <variable>_group_size</variable>
>> </vdl:arguments>
>> <vdl:stdout>
>> </vdl:stdout>
>> </vdl:execute>
>> <log level="debug" message="PROCEDURE_END line=155"/></element>
>> <global name="num_time_steps">
>> <vdl:new type="int" dbgname="num_time_steps" waitfor="88005" />
>> </global>
>> <parameterlog>
>> <string>num_time_steps</string>
>> <vdl:getdatasetprovenanceid var="{num_time_steps}" />
>> </parameterlog>
>> <global name="spectra_period1">
>> <vdl:new type="string" dbgname="spectra_period1" waitfor="88006" />
>> </global>
>> <parameterlog>
>> <string>spectra_period1</string>
>> <vdl:getdatasetprovenanceid var="{spectra_period1}" />
>> </parameterlog>
>> <global name="filter_highhz">
>> <vdl:new type="float" dbgname="filter_highhz" waitfor="88007" />
>> </global>
>> <parameterlog>
>> <string>filter_highhz</string>
>> <vdl:getdatasetprovenanceid var="{filter_highhz}" />
>> </parameterlog>
>> <global name="simulation_timeskip">
>> <vdl:new type="float" dbgname="simulation_timeskip" waitfor="88008" />
>> </global>
>> <parameterlog>
>> <string>simulation_timeskip</string>
>> <vdl:getdatasetprovenanceid var="{simulation_timeskip}" />
>> </parameterlog>
>> <set name="run_id">
>> <vdl:new type="int" dbgname="run_id" waitfor="88009" />
>> </set>
>> <parameterlog>
>> <string>run_id</string>
>> <vdl:getdatasetprovenanceid var="{run_id}" />
>> </parameterlog>
>> <set name="agg_size">
>> <vdl:new type="int" dbgname="agg_size" waitfor="88010" />
>> </set>
>> <parameterlog>
>> <string>agg_size</string>
>> <vdl:getdatasetprovenanceid var="{agg_size}" />
>> </parameterlog>
>> <set name="loc_size">
>> <vdl:new type="int" dbgname="loc_size" waitfor="88011" />
>> </set>
>> <parameterlog>
>> <string>loc_size</string>
>> <vdl:getdatasetprovenanceid var="{loc_size}" />
>> </parameterlog>
>> <set name="datadir">
>> <vdl:new type="string" dbgname="datadir" waitfor="88012" />
>> </set>
>> <parameterlog>
>> <string>datadir</string>
>> <vdl:getdatasetprovenanceid var="{datadir}" />
>> </parameterlog>
>> <set name="datadir2">
>> <vdl:new type="string" dbgname="datadir2" waitfor="88013" />
>> </set>
>> <parameterlog>
>> <string>datadir2</string>
>> <vdl:getdatasetprovenanceid var="{datadir2}" />
>> </parameterlog>
>> <set name="site">
>> <vdl:new type="Station" dbgname="site" waitfor="88014">
>> <vdl:mapping descriptor="concurrent_mapper">
>> <vdl:parameter
>> name="prefix">site-bd2b4daf-5bee-4765-850c-78277783b4a7</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>site</string>
>> <vdl:getdatasetprovenanceid var="{site}" />
>> </parameterlog>
>> <set name="swift#mapper#17045">
>> <vdl:new type="string" dbgname="swift#mapper#17045" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17045</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17045}" />
>> </parameterlog>
>> <set name="swift#mapper#17047">
>> <vdl:new type="string" dbgname="swift#mapper#17047" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17047</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17047}" />
>> </parameterlog>
>> <set name="swift#mapper#17048">
>> <vdl:new type="string" dbgname="swift#mapper#17048" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17048</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17048}" />
>> </parameterlog>
>> <set name="sgt_var">
>> <vdl:new type="Sgt" dbgname="sgt_var">
>> <vdl:mapping descriptor="ext">
>> <vdl:parameter name="exec"><vdl:new type="string"
>> value="getsgtvar.rb" /></vdl:parameter>
>> <vdl:parameter name="r"><variable>run_id</variable></vdl:parameter>
>> <vdl:parameter
>> name="s"><variable>swift#mapper#17047</variable></vdl:parameter>
>> <vdl:parameter name="l"><vdl:new type="string"
>> /></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>sgt_var</string>
>> <vdl:getdatasetprovenanceid var="{sgt_var}" />
>> </parameterlog>
>> <set name="rups">
>> <vdl:new type="Rupture[]" dbgname="rups" waitfor="88015">
>> <vdl:parameter
>> name="prefix">rups-5337caea-ae3a-4282-9907-fba959b1c801</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>rups</string>
>> <vdl:getdatasetprovenanceid var="{rups}" />
>> </parameterlog>
>> <restartLog>
>> <vdl:mains>
>> <vdl:startprogressticker />
>> <vdl:mainp>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>swift#int#3000</variable>
>> </argument>
>> <partialCloseDataset var="{num_time_steps}" closeID="88005" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>swift#string#17040</variable>
>> </argument>
>> <partialCloseDataset var="{spectra_period1}" closeID="88006" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>swift#float#17041</variable>
>> </argument>
>> <partialCloseDataset var="{filter_highhz}" closeID="88007" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>swift#float#17042</variable>
>> </argument>
>> <partialCloseDataset var="{simulation_timeskip}"
>> closeID="88008" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>swift#int#664</variable>
>> </argument>
>> <partialCloseDataset var="{run_id}" closeID="88009" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>agg_size</variable>
>> </argument>
>> <variable>swift#int#60</variable>
>> </argument>
>> <partialCloseDataset var="{agg_size}" closeID="88010" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>loc_size</variable>
>> </argument>
>> <variable>swift#int#20</variable>
>> </argument>
>> <partialCloseDataset var="{loc_size}" closeID="88011" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>datadir</variable>
>> </argument>
>> <variable>swift#string#17043</variable>
>> </argument>
>> <partialCloseDataset var="{datadir}" closeID="88012" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>datadir2</variable>
>> </argument>
>> <variable>swift#string#17044</variable>
>> </argument>
>> <partialCloseDataset var="{datadir2}" closeID="88013" />
>> </sequential>
>> <sequential>
>> <get_site>
>> <parallel>
>> <variable>site</variable>
>> </parallel>
>> </get_site>
>> <partialCloseDataset var="{site}" closeID="88014" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>swift#mapper#17045</variable>
>> </argument>
>> <variable>swift#string#17046</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <getfield>
>> <argument name="var"><variable>site</variable></argument>
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>swift#mapper#17048</variable>
>> </argument>
>> <variable>swift#string#17049</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <get_ruptures>
>> <parallel>
>> <variable>rups</variable>
>> </parallel>
>> </get_ruptures>
>> <partialCloseDataset var="{rups}" closeID="88015" />
>> </sequential>
>> <sequential>
>> <vdl:tparallelFor name="$">
>> <getarrayiterator><variable>rups</variable></getarrayiterator>
>> <set names="$$, rup">
>> <each items="{$}"/>
>> </set>
>> <log level="debug" message="FOREACH_IT_START line=176
>> thread={#thread}"/>
>> <log level="debug"><string>SCOPE thread={#thread}</string></log>
>> <set name="loc_sub">
>> <vdl:new type="string" dbgname="loc_sub"
>> waitfor="88016" />
>> </set>
>> <parameterlog>
>> <string>loc_sub</string>
>> <vdl:getdatasetprovenanceid var="{loc_sub}" />
>> </parameterlog>
>> <set name="swift#mapper#17050">
>> dbgname="swift#mapper#17050" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17050</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17050}" />
>> </parameterlog>
>> <set name="swift#mapper#17052">
>> dbgname="swift#mapper#17052" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17052</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17052}" />
>> </parameterlog>
>> <set name="swift#mapper#17053">
>> <vdl:new type="int" dbgname="swift#mapper#17053"
>> waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17053</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17053}" />
>> </parameterlog>
>> <set name="swift#mapper#17054">
>> <vdl:new type="int" dbgname="swift#mapper#17054"
>> waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17054</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17054}" />
>> </parameterlog>
>> <set name="sub">
>> <vdl:new type="Sgt" dbgname="sub">
>> type="string" value="getsub.rb" /></vdl:parameter>
>> <vdl:parameter
>> name="l"><variable>loc_sub</variable></vdl:parameter>
>> <vdl:parameter
>> name="n"><variable>swift#mapper#17052</variable></vdl:parameter>
>> <vdl:parameter
>> name="s"><variable>swift#mapper#17053</variable></vdl:parameter>
>> <vdl:parameter
>> name="r"><variable>swift#mapper#17054</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>sub</string>
>> <vdl:getdatasetprovenanceid var="{sub}" />
>> </parameterlog>
>> <set name="var_str">
>> <vdl:new type="string[]" dbgname="var_str" waitfor="88017">
>> <vdl:parameter
>> name="prefix">var_str-0be56efa-17ab-4185-bdfd-00a384289008</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>var_str</string>
>> <vdl:getdatasetprovenanceid var="{var_str}" />
>> </parameterlog>
>> <set name="vars">
>> <vdl:new type="Variation[]" dbgname="vars">
>> <vdl:mapping descriptor="array_mapper">
>> <vdl:parameter
>> name="files"><variable>var_str</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>vars</string>
>> <vdl:getdatasetprovenanceid var="{vars}" />
>> </parameterlog>
>> <set name="seis_str">
>> <vdl:new type="string[]" dbgname="seis_str"
>> waitfor="88018 88022">
>> <vdl:parameter
>> name="prefix">seis_str-6937efe3-c3df-416f-b7d3-0e47ea3a3eb8</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>seis_str</string>
>> <vdl:getdatasetprovenanceid var="{seis_str}" />
>> </parameterlog>
>> <set name="peak_str">
>> <vdl:new type="string[]" dbgname="peak_str"
>> waitfor="88019 88022">
>> <vdl:parameter
>> name="prefix">peak_str-020c6ebf-2cba-4ac2-9eef-213d675682cc</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>peak_str</string>
>> <vdl:getdatasetprovenanceid var="{peak_str}" />
>> </parameterlog>
>> <set name="swift#mapper#17061">
>> dbgname="swift#mapper#17061" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17061</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17061}" />
>> </parameterlog>
>> <set name="seis">
>> <vdl:new type="Seismogram[]" dbgname="seis" waitfor="88023">
>> <vdl:mapping descriptor="fixed_array_mapper">
>> <vdl:parameter
>> name="files"><variable>swift#mapper#17061</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>seis</string>
>> <vdl:getdatasetprovenanceid var="{seis}" />
>> </parameterlog>
>> <set name="swift#mapper#17062">
>> dbgname="swift#mapper#17062" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17062</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17062}" />
>> </parameterlog>
>> <set name="peak">
>> <vdl:new type="PeakValue[]" dbgname="peak" waitfor="88023">
>> <vdl:parameter
>> name="files"><variable>swift#mapper#17062</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>peak</string>
>> <vdl:getdatasetprovenanceid var="{peak}" />
>> </parameterlog>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <variable>datadir2</variable><variable>swift#string#17036</variable><getfield>
>> <argument
>> </getfield><variable>swift#string#17036</variable><getfield>
>> <argument
>> name="var"><variable>rup</variable></argument>
>> <argument
>> </getfield>
>> </argument>
>> <partialCloseDataset var="{loc_sub}"
>> closeID="88016" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <variable>swift#mapper#17050</variable>
>> </argument>
>> <variable>swift#string#17051</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <getfield>
>> <argument
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <getfield>
>> <argument
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <getfield>
>> <argument
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <get_variations>
>> <parallel>
>> <variable>swift#string#17055</variable>
>> </parallel>
>> </get_variations>
>> <partialCloseDataset var="{var_str}"
>> closeID="88017" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <vdl:getfieldsubscript>
>> <argument
>> name="var"><variable>seis_str</variable></argument>
>> <argument name="subscript"><vdlop:product>
>> <vdl:new type="int" value="-1" />
>> <variable>swift#int#1</variable>
>> </vdlop:product></argument>
>> </vdl:getfieldsubscript>
>> </argument>
>> <variable>swift#string#17056</variable>
>> </argument>
>> <partialCloseDataset var="{seis_str}"
>> closeID="88018" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> name="var"><variable>peak_str</variable></argument>
>> </argument>
>> </argument>
>> <partialCloseDataset var="{peak_str}"
>> closeID="88019" />
>> </sequential>
>> <sequential>
>> <getarrayiterator><variable>vars</variable></getarrayiterator>
>> <set names="$$, var">
>> <each items="{$}"/>
>> </set>
>> <set name="i">
>> <vdl:new type="int" value="{$$}"/>
>> </set> <log level="debug"
>> message="FOREACH_IT_START line=191 thread={#thread}"/>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> <argument
>> name="subscript"><variable>i</variable></argument>
>> </argument>
>> <argument
>> <argument
>> name="subscript"><vdlop:subtraction>
>> </vdlop:subtraction></argument>
>> </vdl:getfieldsubscript><variable>loc_sub</variable><variable>swift#string#17057</variable><getfield>
>> <argument
>> <argument
>> <argument
>> <argument
>> <argument
>> <argument
>> </getfield><variable>swift#string#17033</variable><variable>i</variable><variable>swift#string#17058</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> <argument
>> </argument>
>> <argument
>> <argument
>> </vdl:getfieldsubscript><variable>loc_sub</variable><variable>swift#string#17059</variable><getfield>
>> <argument
>> <argument
>> <argument
>> <argument
>> <argument
>> <argument
>> </getfield><variable>swift#string#17033</variable><variable>i</variable><variable>swift#string#17060</variable>
>> </argument>
>> </sequential>
>> </parallel>
>> <log level="debug" message="FOREACH_IT_END
>> </vdl:tparallelFor>
>> closeID="88022" />
>> closeID="88022" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <argument
>> <argument name="subscript"><vdlop:subtraction>
>> <getfield>
>> <argument
>> <argument name="path">size</argument>
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> </argument>
>> <argument
>> <getfield>
>> <argument
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <if>
>> <vdl:getfieldvalue><vdlop:le>
>> <getfield>
>> <argument
>> </getfield>
>> </vdlop:le></vdl:getfieldvalue>
>> <then>
>> </then>
>> <else>
>> <sequentialWithID>
>> <sequential>
>> <if>
>> <getfield>
>> <argument
>> </getfield>
>> <then>
>> <sequentialWithID>
>> <sequential>
>> <seispeak_agg>
>> <parallel>
>> <variable>seis</variable>
>> <variable>peak</variable>
>> <variable>sub</variable>
>> <getfield>
>> <argument
>> <argument
>> </getfield>
>> </parallel>
>> </seispeak_agg>
>> </sequential>
>> </sequentialWithID>
>> </then>
>> <else>
>> <set name="offs">
>> <vdl:new type="offset[]"
>> dbgname="offs" waitfor="88027">
>> <vdl:mapping
>> <vdl:parameter
>> name="prefix">offs-43c154db-5039-4460-9eed-9e83d05326a6</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>offs</string>
>> var="{offs}" />
>> </parameterlog>
>> <parallel>
>> <sequential>
>> <mkoffset>
>> <parallel>
>> <variable>offs</variable>
>> <getfield>
>> <argument
>> <argument
>> </getfield>
>> </parallel>
>> </mkoffset>
>> var="{offs}" closeID="88027" />
>> </sequential>
>> <sequential>
>> <getarrayiterator><variable>offs</variable></getarrayiterator>
>> <set names="$$, i">
>> <each items="{$}"/>
>> </set>
>> <log level="debug"
>> message="FOREACH_IT_START line=216 thread={#thread}"/>
>> <log
>> <set name="var_offset">
>> <vdl:new
>> type="Variation[]" dbgname="var_offset" waitfor="88033">
>> <vdl:mapping
>> <vdl:parameter
>> name="prefix">var_offset-a9ae00b0-1d92-4754-a13a-8d580fb03cc4</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>var_offset</string>
>> <vdl:getdatasetprovenanceid var="{var_offset}" />
>> </parameterlog>
>> <set name="seis_str_off">
>> <vdl:new
>> type="string[]" dbgname="seis_str_off" waitfor="88028 88033">
>> <vdl:mapping
>> <vdl:parameter
>> name="prefix">seis_str_off-5fa23a9b-9c02-4bba-b092-aa64606ee081</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>seis_str_off</string>
>> <vdl:getdatasetprovenanceid var="{seis_str_off}" />
>> </parameterlog>
>> <set name="peak_str_off">
>> <vdl:new
>> type="string[]" dbgname="peak_str_off" waitfor="88029 88033">
>> <vdl:mapping
>> <vdl:parameter
>> name="prefix">peak_str_off-8ec116fa-6b1a-4677-ae14-7927be4ee988</vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>peak_str_off</string>
>> <vdl:getdatasetprovenanceid var="{peak_str_off}" />
>> </parameterlog>
>> <set name="swift#mapper#17063">
>> <vdl:new
>> type="string" dbgname="swift#mapper#17063" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17063</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17063}" />
>> </parameterlog>
>> <set name="seis_off">
>> <vdl:new
>> type="Seismogram[]" dbgname="seis_off" waitfor="88034">
>> <vdl:mapping
>> <vdl:parameter
>> name="files"><variable>swift#mapper#17063</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>seis_off</string>
>> <vdl:getdatasetprovenanceid var="{seis_off}" />
>> </parameterlog>
>> <set name="swift#mapper#17064">
>> <vdl:new
>> type="string" dbgname="swift#mapper#17064" waitfor="" />
>> </set>
>> <parameterlog>
>> <string>swift#mapper#17064</string>
>> <vdl:getdatasetprovenanceid var="{swift#mapper#17064}" />
>> </parameterlog>
>> <set name="peak_off">
>> <vdl:new
>> type="PeakValue[]" dbgname="peak_off" waitfor="88035">
>> <vdl:mapping
>> <vdl:parameter
>> name="files"><variable>swift#mapper#17064</variable></vdl:parameter>
>> </vdl:mapping>
>> </vdl:new>
>> </set>
>> <parameterlog>
>> <string>peak_off</string>
>> <vdl:getdatasetprovenanceid var="{peak_off}" />
>> </parameterlog>
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> name="var">
>> <argument name="var"><variable>seis_str_off</variable></argument>
>> </argument>
>> <argument
>> name="value">
>> </argument>
>> <partialCloseDataset var="{seis_str_off}" closeID="88028" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> name="var">
>> <argument name="var"><variable>peak_str_off</variable></argument>
>> </argument>
>> <argument
>> name="value">
>> </argument>
>> <partialCloseDataset var="{peak_str_off}" closeID="88029" />
>> </sequential>
>> <sequential>
>> <getarrayiterator><sequential>
>> <set
>> name="swift#from"><getfield>
>> <argument
>> name="var"><variable>i</variable></argument>
>> <argument
>> name="path">off</argument>
>> </getfield></set>
>> <set
>> name="swift#to"><vdlop:subtraction>
>> <vdlop:sum>
>> <getfield>
>> <argument name="var"><variable>i</variable></argument>
>> <argument name="path">off</argument>
>> </getfield>
>> <getfield>
>> </getfield>
>> </vdlop:sum>
>> </vdlop:subtraction></set>
>> <set
>> name="swift#rangeout">
>> <vdl:range>
>> <argument
>> name="from"><variable>swift#from</variable></argument>
>> <argument
>> name="to"><variable>swift#to</variable></argument>
>> </vdl:range>
>> </set>
>> <if><equals><vdl:configProperty><string>provenance.log</string></vdl:configProperty><string>true</string></equals>
>> <then>
>> <log
>> level="info"><concat>
>> <string>ARRAYRANGE thread={#thread} array=</string>
>> <vdl:getdatasetprovenanceid var="{swift#rangeout}" />
>> <string>
>> from=</string> <vdl:getdatasetprovenanceid var="{swift#from}" />
>> <string>
>> to=</string> <vdl:getdatasetprovenanceid var="{swift#to}" />
>> <string>
>> step=none</string>
>> </concat></log>
>> </then>
>> </if>
>> <variable>swift#rangeout</variable>
>> </sequential></getarrayiterator>
>> <set names="$$, j">
>> <each items="{$}"/>
>> </set>
>> <log
>> level="debug" message="FOREACH_IT_START line=222 thread={#thread}"/>
>> <log
>> <parallel>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument name="var"><variable>var_offset</variable></argument>
>> <argument name="subscript"><variable>j</variable></argument>
>> </argument>
>> <argument name="var"><variable>vars</variable></argument>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> <getfield>
>> </getfield>
>> </argument>
>> <argument
>> <vdlop:subtraction>
>> <getfield>
>> </getfield>
>> <argument name="var"><variable>rup</variable></argument>
>> </getfield><variable>swift#string#17033</variable><variable>j</variable><variable>swift#string#17058</variable>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> <getfield>
>> </getfield>
>> </argument>
>> <argument
>> <vdlop:subtraction>
>> <getfield>
>> </getfield>
>> </getfield><variable>swift#string#17033</variable><variable>j</variable><variable>swift#string#17060</variable>
>> </argument>
>> </sequential>
>> </parallel>
>> <log
>> level="debug" message="FOREACH_IT_END line=222 thread={#thread}"/>
>> </vdl:tparallelFor>
>> <partialCloseDataset var="{var_offset}" closeID="88033" />
>> <partialCloseDataset var="{peak_str_off}" closeID="88033" />
>> <partialCloseDataset var="{seis_str_off}" closeID="88033" />
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> name="var">
>> </argument>
>> <argument
>> name="value">
>> <getfield>
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <vdl:setfieldvalue>
>> <argument
>> name="var">
>> </argument>
>> <argument
>> name="value">
>> <getfield>
>> </getfield>
>> </argument>
>> </sequential>
>> <sequential>
>> <seispeak_agg>
>> <parallel>
>> <variable>seis_off</variable>
>> <variable>peak_off</variable>
>> <getfield>
>> </getfield>
>> </parallel>
>> </seispeak_agg>
>> <partialCloseDataset var="{seis_off}" closeID="88034" />
>> <partialCloseDataset var="{peak_off}" closeID="88035" />
>> </sequential>
>> </parallel>
>> <log level="debug"
>> message="FOREACH_IT_END line=216 thread={#thread}"/>
>> </vdl:tparallelFor>
>> </sequential>
>> </parallel>
>> </else>
>> </if>
>> </sequential>
>> </sequentialWithID>
>> </else>
>> </if>
>> <partialCloseDataset var="{seis}" closeID="88023" />
>> <partialCloseDataset var="{peak}" closeID="88023" />
>> </sequential>
>> </parallel>
>> <log level="debug" message="FOREACH_IT_END line=176
>> thread={#thread}"/>
>> </vdl:tparallelFor>
>> </sequential>
>> </parallel>
>> </vdl:mainp>
>> <vdl:stopprogressticker />
>> </vdl:mains>
>> </restartLog>
>> </project>
>> 2011/5/12 Mihael Hategan <hategan at mcs.anl.gov>:
>> > And now the script please. Better yet, the .kml.
>> > On Thu, 2011-05-12 at 23:44 -0500, Allan Espinosa wrote:
>> >> Oops. Here you go:
>> >> 2011-05-12 23:43:39,269-0500 DEBUG Loader Max heap: 3817799680
>> >> 2011-05-12 23:43:39,270-0500 DEBUG Loader kmlversion is
>> >> > Me want log. Or a full stack trace otherwise.
>> >> > On Thu, 2011-05-12 at 23:35 -0500, Allan Espinosa wrote:
>> >> >> I now get this on my workflow. This does not happen in the current
>> >> >> stable branch. Maybe it really was bad
>> >> >> $ ~/swift/trunk/bin/swift -config swift.properties -sites.file
>> >> >> condor_osg.xml postproc.swift
>> >> >> Swift svn swift-r4468 cog-r3096
>> >> >> RunID: 20110512-2330-vjqo3je6
>> >> >> Progress: time: Thu, 12 May 2011 23:30:23 -0500
>> >> >> Unexpected VDL2FutureException checking inputs for dataset
>> >> >> org.griphyn.vdl.mapping.RootDataNode identifier
>> >> >> dataset:20110512-2330-cutxe93f:720000000077 type RuptureFile with no
>> >> >> value at dataset=file (closed)
>> >> >> Execution failed:
>> >> >> Got a VDL2FutureException but all parameters should have their values
>> >> >> > On Thu, 2011-05-12 at 14:06 -0700, Mihael Hategan wrote:
>> >> >> >> And it doesn't except that the toString() method may get an inconsistent
>> >> >> >> view of the listeners.
>> >> >> >> I'm updating the code there and will commit a tentative fix in a bit.
>> >> >> > Done. swift r4467.
>> >> >> > Btw, are we running nightly tests?
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110513/55bef102/attachment.bin>
More information about the Swift-user
