[Swift-user] badness
Allan Espinosa
aespinosa at cs.uchicago.edu
Thu May 12 23:44:38 CDT 2011
Oops. Here you go:
2011-05-12 23:43:39,269-0500 DEBUG Loader Max heap: 3817799680
2011-05-12 23:43:39,270-0500 DEBUG Loader kmlversion is
>9da6434d-5b79-4076-ad0b-77e09abaa5fd<
2011-05-12 23:43:39,271-0500 DEBUG Loader build version is
2011-05-12 23:43:39,271-0500 DEBUG Loader Recompilation suppressed.
2011-05-12 23:43:39,531-0500 INFO VDL2ExecutionContext Stack dump:
Level 1
[iA = 0, iB = 0, bA = false, bB = false]
vdl:instanceconfigfile = swift.properties
vdl:instanceconfig = Swift configuration [swift.properties]
vdl:operation = run
PATH_SEPARATOR = /
swift.home = /home/aespinosa/swift/trunk/bin/..
#vdl:futureWrapperMap = org.griphyn.vdl.karajan.WrapperMap at 7f2ad19e
2011-05-12 23:43:40,045-0500 INFO unknown Using sites file: condor_osg.xml
2011-05-12 23:43:40,074-0500 INFO unknown Using tc.data: tc.data
2011-05-12 23:43:40,196-0500 INFO AbstractScheduler Setting resources
to: {LIGO_UWM_NEMO__osg-nemo-ce.phys.uwm.edu=LIGO_UWM_NEMO__osg-nemo-ce.phys.uwm.edu,
Purdue-Rossmann__rossmann-osg.rcac.purdue.edu=Purdue-Rossmann__rossmann-osg.rcac.purdue.edu,
UFlorida-HPC__osg.hpc.ufl.edu=UFlorida-HPC__osg.hpc.ufl.edu,
PADS=PADS, Firefly__ff-grid3.unl.edu=Firefly__ff-grid3.unl.edu,
Clemson-Palmetto__osg-gw.clemson.edu=Clemson-Palmetto__osg-gw.clemson.edu,
FNAL_FERMIGRID__fermigridosg1.fnal.gov=FNAL_FERMIGRID__fermigridosg1.fnal.gov,
Purdue-Steele__lepton.rcac.purdue.edu=Purdue-Steele__lepton.rcac.purdue.edu,
localhost=localhost}
2011-05-12 23:43:40,623-0500 INFO unknown Swift svn swift-r4468 cog-r3096
2011-05-12 23:43:40,624-0500 INFO unknown RUNID id=run:20110512-2343-hsp3kdyf
2011-05-12 23:43:40,716-0500 INFO SetFieldValue Set:
swift#mapper#17045=getsgtvar.rb
swift#mapper#17048=gsiftp://gridftp.ranger.tacc.teragrid.org//work/01035/tg802895/science/cybershake/data/SgtFiles
2011-05-12 23:43:40,717-0500 INFO SetFieldValue Set: filter_highhz=5.0
2011-05-12 23:43:40,717-0500 INFO SetFieldValue Set: simulation_timeskip=0.1
datadir=gsiftp://gridftp.ranger.tacc.teragrid.org//scratch/01035/tg802895/science/cybershake/Results
2011-05-12 23:43:40,718-0500 INFO SetFieldValue Set:
datadir2=gsiftp://gridftp.pads.ci.uchicago.edu//gpfs/pads/swift/aespinosa/science/cybershake/Results
2011-05-12 23:43:40,718-0500 INFO SetFieldValue Set: spectra_period1=all
2011-05-12 23:43:40,718-0500 INFO SetFieldValue Set: loc_size=20
2011-05-12 23:43:40,719-0500 INFO SetFieldValue Set:
swift#mapper#17047=org.griphyn.vdl.mapping.DataNode identifier
dataset:20110512-2343-5rl3b7x5:720000000074 type string with no value
at dataset=site path=.name (not closed)
2011-05-12 23:43:40,719-0500 INFO SetFieldValue Set: agg_size=60
2011-05-12 23:43:40,720-0500 INFO get_site STARTCOMPOUND thread=0-9
name=get_site
2011-05-12 23:43:40,720-0500 INFO SetFieldValue Set: num_time_steps=3000
2011-05-12 23:43:40,720-0500 INFO get_ruptures STARTCOMPOUND
thread=0-13 name=get_ruptures
2011-05-12 23:43:40,722-0500 INFO SetFieldValue Set: run_id=664
2011-05-12 23:43:40,723-0500 INFO AbstractDataNode Found data
org.griphyn.vdl.mapping.RootDataNode identifier
dataset:20110512-2343-5rl3b7x5:720000000076 type StationFile with no
value at dataset=file (closed).$
2011-05-12 23:43:40,723-0500 DEBUG get_ruptures INTERNALPROC_START
thread=0-13-1 name=readData
2011-05-12 23:43:40,724-0500 DEBUG get_site INTERNALPROC_START
thread=0-9-1 name=readData
2011-05-12 23:43:40,726-0500 INFO SetFieldValue Set: swift#mapper#17047=LGU
2011-05-12 23:43:40,794-0500 INFO AbstractDataNode Found data
dataset:20110512-2343-5rl3b7x5:720000000072 type Sgt with no value at
dataset=sgt_var (not closed)..y
dataset=sgt_var (not closed)..x
2011-05-12 23:43:40,794-0500 INFO SetFieldValue Set:
swift#mapper#17026=LGU/rup_tmp
2011-05-12 23:43:40,795-0500 WARN AbstractDataNode Unexpected
VDL2FutureException checking inputs for dataset
dataset:20110512-2343-5rl3b7x5:720000000077 type RuptureFile with no
2011-05-12 23:43:40,798-0500 DEBUG VDL2ExecutionContext
java.lang.RuntimeException: Got a VDL2FutureException but all
parameters should have their values
Caused by: java.lang.RuntimeException: Got a VDL2FutureException but
all parameters should have their values
at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:79)
at org.griphyn.vdl.mapping.RootDataNode.innerInit(RootDataNode.java:61)
at org.griphyn.vdl.mapping.RootDataNode.handleClosed(RootDataNode.java:90)
at org.griphyn.vdl.mapping.AbstractDataNode.notifyListeners(AbstractDataNode.java:588)
at org.griphyn.vdl.mapping.AbstractDataNode.closeShallow(AbstractDataNode.java:391)
at org.griphyn.vdl.mapping.AbstractDataNode.setValue(AbstractDataNode.java:341)
at org.griphyn.vdl.mapping.RootDataNode.setValue(RootDataNode.java:218)
at org.griphyn.vdl.karajan.lib.SetFieldValue.deepCopy(SetFieldValue.java:85)
at org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:47)
at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:66)
at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.completed(AbstractSequentialWithArguments.java:196)
at org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java:214)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java:58)
at org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:48)
at org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:28)
at org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.futureModified(AbstractSequentialWithArguments.java:210)
at org.griphyn.vdl.karajan.DSHandleFutureWrapper.notifyListeners(DSHandleFutureWrapper.java:78)
at org.griphyn.vdl.karajan.DSHandleFutureWrapper.handleClosed(DSHandleFutureWrapper.java:122)
at org.griphyn.vdl.karajan.lib.swiftscript.ReadData.setValue(ReadData.java:222)
at org.griphyn.vdl.karajan.lib.swiftscript.ReadData.readStruct(ReadData.java:188)
at org.griphyn.vdl.karajan.lib.swiftscript.ReadData.readStruct(ReadData.java:205)
at org.griphyn.vdl.karajan.lib.swiftscript.ReadData.readData(ReadData.java:76)
at org.griphyn.vdl.karajan.lib.swiftscript.ReadData.function(ReadData.java:53)
at org.globus.cog.karajan.workflow.nodes.Parallel.completed(Parallel.java:87)
at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
at org.globus.cog.karajan.workflow.nodes.Sequential.completed(Sequential.java:24)
at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
at org.globus.cog.karajan.workflow.FlowElementWrapper.start(FlowElementWrapper.java:227)
at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.griphyn.vdl.karajan.VDL2FutureException
at org.griphyn.vdl.mapping.RootDataNode.getMapper(RootDataNode.java:209)
at org.griphyn.vdl.karajan.lib.swiftscript.ReadData.function(ReadData.java:47)
at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:102)
at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:75)
... 54 more
at org.griphyn.vdl.karajan.lib.SetFieldValue.function(SetFieldValue.java:60)
... 46 more
... 54 more
2011-05-12 23:43:40,810-0500 INFO ExecutionContext Detailed exception:
... 54 more
... 46 more
... 54 more
2011-05-12 23:43:40,812-0500 INFO Loader Swift finished with errors
2011-05-12 23:43:40,812-0500 DEBUG get_site INTERNALPROC_END thread=0-9-1
2011-05-12 23:43:40,813-0500 INFO get_site ENDCOMPOUND thread=0-9
2011/5/12 Mihael Hategan <hategan at mcs.anl.gov>:
> Me want log. Or a full stack trace otherwise.
> On Thu, 2011-05-12 at 23:35 -0500, Allan Espinosa wrote:
>> I now get this on my workflow. This does not happen in the current
>> stable branch. Maybe it really was bad
>> $ ~/swift/trunk/bin/swift -config swift.properties -sites.file
>> condor_osg.xml postproc.swift
>> RunID: 20110512-2330-vjqo3je6
>> Progress: time: Thu, 12 May 2011 23:30:23 -0500
>> Unexpected VDL2FutureException checking inputs for dataset
>> dataset:20110512-2330-cutxe93f:720000000077 type RuptureFile with no
>> Execution failed:
>> Got a VDL2FutureException but all parameters should have their values
>> > On Thu, 2011-05-12 at 14:06 -0700, Mihael Hategan wrote:
>> >> And it doesn't except that the toString() method may get an inconsistent
>> >> view of the listeners.
>> >> I'm updating the code there and will commit a tentative fix in a bit.
>> > Done. swift r4467.
>> > Btw, are we running nightly tests?
More information about the Swift-user
