[Swift-user] badness
Mihael Hategan hategan at mcs.anl.gov
Thu May 12 16:06:25 CDT 2011
On Thu, 2011-05-12 at 13:51 -0700, Mihael Hategan wrote:
> On Thu, 2011-05-12 at 15:29 -0500, Allan Espinosa wrote:
> > hi,
> > I used trunk again today after mostly running under the stable branch.
> >  Then my workflow give this 'Badness' message on the console.  What
> > does this mean?  There are no corresponding entries in the log that I
> > can correspond these events to.
> It corresponds to <variable> Closed, <x> elements, <y > 0> listeners.
> That is some closed variable with a listener, which I think should not
> happen.
And it doesn't except that the toString() method may get an inconsistent
view of the listeners.
I'm updating the code there and will commit a tentative fix in a bit.
More information about the Swift-user mailing list
