[Swift-user] 3rd party transfer optimization
Mihael Hategan
hategan at mcs.anl.gov
Mon Mar 14 14:04:17 CDT 2011
This should be in in trunk swift r4176 cog r3062.
What you need to mess with is a file in etc called bpd.conf. It's lines
are in the form:
source, destination -> bufferSize
This file was (and may still be) in the standard format used by TGCP, so
presumably you can fetch it from an existing TGCP installation. However,
it is already provided in swift, but may not be up to date.
Please test and let me know if it works.
Mihael
On Sun, 2011-03-13 at 11:24 -0700, Mihael Hategan wrote:
> A long time ago I added into Karajan the ability to set gridftp buffer
> options using a file that was used at the time by TGCP. That feature
> should still be available and can probably be integrated transparently.
> I can probably take a shot at it today.
> Mihael
> On Sun, 2011-03-13 at 11:22 -0500, Michael Wilde wrote:
> > Allan, this ability does not exist to my knowledge, but sounds useful.
> > (Its similar in nature to Sheri's request for adding qsub attributes).
> > Have you verified (ie by hardcoding the desired value) that it will improve the data transfer rates?
> > If so, and if you can add it, that would be great.
> > Are you running off of trunk or a branch?
> > Lets move discussion to swift-devel to discuss how this would work and where to make the change.
> > - Mike
> > ----- Original Message -----
> > > Hi,
> > > I know you can pass 3rd party optimizations like tcp buffer size to
> > > low-level Karajan provider definitions. Does anyone have examples on
> > > applying these to Swift's sites.xml definitions?
> > > Thanks,
> > > -Allan
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
