[Swift-user] mapping a 2 dim array to a directory
Ketan Maheshwari ketancmaheshwari at gmail.com
Tue Jun 21 16:59:39 CDT 2011
Hello,
I am trying to get a 2 dim array to map to a directory with a given pattern
as follows:
The directory contains files with names as follows:
a_00
a_01
a_99
b_00
b_01
z_99
The mapped variable amap[i][j] should be mapped in such a way that i should
map to the prefix and j should map to the suffix part of the file.
For example: amap[2][10] should return the file c_10.
In addition the said directory is an output directory and does not exist
yet.
A one dimensional array mapping exists for this which is as follows:
file  dat_files[] < simple_mapper;
                              padding = 3,
                              location = "output",
                              prefix  = @strcat( str_root, "_" ),
                              suffix  = ".dat" >;
I looked into external mappers but could not figure out how exactly to go
for it.
Any clues?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110621/6e1b3f59/attachment.html>
More information about the Swift-user mailing list
