[Swift-user] [Swift-devel] swift on ranger
Mihael Hategan
hategan at mcs.anl.gov
Wed Dec 21 17:53:53 CST 2011
On Wed, 2011-12-21 at 14:50 -0800, Sarah Kenny wrote:
> yr right ketan, if i change it to: <profile namespace="globus"
> key="jobsPerNode">16</profile> the warning message goes away. however,
> there are times i don't want to run 16 jobs per node...e.g. bcs a
> single job needs all the available memory so even though the node has
> 16 processors i can't actually use them all. so perhaps this is just a
> scheduling issue with ranger/sge in that they don't want you to submit
> a job that's going to leave processors idle? that seems a bit
> restrictive though...
Hmmm. I think that one should be able to request 16 cores and run only
two jobs at a time on them. Have you tried pe=2way?
More information about the Swift-user
