[Swift-user] swift on ranger
Sarah Kenny
skenny at uci.edu
Wed Dec 21 06:57:32 CST 2011
getting this when submitting to ranger with both the latest and our
previous version of swift (swift-r5259 cog-r3313)
Final status: time: Wed, 21 Dec 2011 04:49:15 -0800 Finished
successfully:100
The following warnings have occurred:
1. org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
Cannot submit job: Could not submit job (qsub reported an exit code of 1).
Welcome to TACC's Ranger System, an NSF XD Resource
Checking that you specified -V...--> Checking that you specified a time
limit...--> Checking that you specified a queue...--> Setting project...-->
Checking that you specified a parallel environment...--> Checking that you
specified a valid parallel environment name...--> Checking that the minimum
and maximum PE counts are the same...--> Checking that the number of PEs
requested is valid...------------------> Rejecting job
<------------------Your slot (or core) request is not a multiple of
16.Syntax: -pe <pe_name> <n>where <n> is a multiple of
16.-----------------------------------------------------
Unable to run job: JSV rejected job.Exiting.
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
at
org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
at
org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:57)
at
org.globus.cog.abstraction.coaster.service.job.manager.LocalQueueProcessor.run(LocalQueueProcessor.java:40)
Caused by:
org.globus.cog.abstraction.impl.scheduler.common.ProcessException: Could
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:108)
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
... 3 more
################### sites file
<config>
<pool handle="RANGER">
<execution provider="coaster" jobManager="gt2:SGE" url="
gatekeeper.ranger.tacc.teragrid.org"/>
<filesystem provider="gsiftp" url="gsiftp://
gridftp.ranger.tacc.teragrid.org"/>
<profile namespace="globus" key="maxtime">86400</profile>
<profile namespace="globus" key="maxWallTime">02:00:00</profile>
<profile namespace="globus" key="jobsPerNode">1</profile>
<profile namespace="globus" key="nodeGranularity">64</profile>
<profile namespace="globus" key="maxNodes">4096</profile>
<profile namespace="globus" key="queue">normal</profile>
<profile namespace="karajan" key="jobThrottle">1.28</profile>
<profile namespace="globus" key="project">TG-DBS080004N</profile>
<profile namespace="globus" key="pe">16way</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<workdirectory>/work/00043/tg457040/swiftwork</workdirectory>
</pool>
</config>
same settings we've been using for a while, i'm not sure why this seems to
be popping up now, but it's rather consistent. all jobs are finishing
successfully, so it's rather confusing...any idea what i might be missing
here?
thanks
~sk
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20111221/f7182417/attachment.html>
More information about the Swift-user
