[Swift-user] Is there a way to set env variables in swift
Lorenzo Pesce
lpesce at uchicago.edu
Wed Aug 31 10:57:43 CDT 2011
Sometimes one had to ask stupid questions, so I will go ahead and do it.
This is the script
// file to run the Margic square example from the matlab web site
type file;
string MCRPath = "/soft/mcr/v714";
app (file outdata) magicsq (string mcr, int size)
runMagicSquare mcr size stdout=@outdata;
int matsize[] = [0:23];
file MagicSquares[] <simple_mapper; prefix="magicmat.",suffix=".dat">;
foreach s, i in matsize {
MagicSquares[i] = magicsq (MCRPath, s);
this is tc
# sitename transformation path
pbs echo /bin/echo
pbs cat /bin/cat
pbs ls /bin/ls
pbs grep /bin/grep
pbs sort /bin/sort
pbs paste /bin/paste
pbs cp /bin/cp
pbs touch /bin/touch
pbs wc /usr/bin/wc
# custom entries
pbs convert /home/ketan/ImageMagick-install/bin/convert
pbs script1 /lustre/beagle/ketan/beagle-swift-training-examples/script1.sh
pbs script2 /lustre/beagle/ketan/beagle-swift-training-examples/script2.sh
pbs annotate /lustre/beagle/ketan/beagle-swift-training-examples/annotate.sh
pbs runMagicSquare /home/lpesce/matlab/bin/run_magicsquare.sh INSTALLED AMD64 ENV::TMP="/lustre/beagle/lpesce/tmp"
this is the call:
swift -config cf -sites.file sites.xml -tc.file tc script.swift
This is what I get:
011-08-31 15:49:25,816+0000 INFO vdl:execute The application "runMagicSquare" is not available in your tc.data catalog
Caused by: org.globus.cog.karajan.scheduler.NoSuchResourceException
2011-08-31 15:49:25,825+0000 DEBUG magicsq PROCEDURE_END line=6
What am I doing stupidly here?
Thanks!
On Aug 30, 2011, at 4:22 PM, Michael Wilde wrote:
> Lorenzo,
> You can set env vars for an application in the tc.data file. Use the "env namespace profile" as described at:
> http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_env_namespace
> Like this:
> beagle myapp /home/joe/bin/myapp INSTALLED INTEL32::LINUX ENV::TMP="/lustre/beagle/joe/tmp"
> If you need "joe" substituted into the "TMP" env var in the tc file dynamically (as with your example below), you need to do that with your own wrapper script on the client host (before you run the swift command).
> Alternatively, if you are running locally on Beagle, there may also be an option you can specify in your sites file that will get passed down to the PBS qsub command, to pass the environment vars of the submitting job down to the submitted job, in which case you dont need the ENV::TMP profile in your tc.data file. David or Justin may be able to clarify whats possible there. (And this should go into the new 0.93 Site Configuration Guide).
> - Mike
>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> To: swift-user at ci.uchicago.edu
>> Sent: Tuesday, August 30, 2011 2:59:57 PM
>> Subject: [Swift-user] Is there a way to set env variables in swift
>> Specifically something like
>> export TMP=/lustre/beagle/`whoami`/tmp
>> Thanks
>> Lorenzo
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user
