[Swift-user] Do you have any resource for learning about SwiftR?
Michael Wilde
wilde at mcs.anl.gov
Tue Aug 30 11:05:33 CDT 2011
Lorenzo,
The SwiftR documentation is currently at:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/SwiftR
which also provides a quick start guide at:
http://www.ci.uchicago.edu/wiki/bin/view/SWFT/SwiftRQuickstart
Further examples and some performance measurements are at:
http://people.cs.uchicago.edu/~tga/swiftR/
And more examples are available with ?SwiftR help once you load the package:
> source("http://people.cs.uchicago.edu/~tga/swiftR/getSwift.R")
I just built an R-2.13.1 release on Beagle with plain gcc, which I think *should* be runnable in parallel on worker nodes. (Not yet tested though). This R should be capable of running SwiftR. Im hoping that Tim cam verify this soon. We'll likely need an additional SwiftR server name and config for Beagle and other Cray systems.
We'll try to consolidate the SwiftR documentation in a user guide on the Swift in the future. Tim, can you do a quick check of the documentation to make sure its still correct and that it points to the latest SwiftR package?
- Mike
----- Original Message -----
> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
> To: swift-user at ci.uchicago.edu
> Sent: Tuesday, August 30, 2011 9:22:51 AM
> Subject: [Swift-user] Do you have any resource for learning about SwiftR?
> Hi -
> I want to run relatively small sized simulations (say at most 50 cores
> or so, probably mostly one or two) but many many times over. The
> simulations will be coded in R.
> Thanks a lot!
> Lorenzo
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user
