[Swift-user] meaning of foreach.max.threads
Ketan Maheshwari
ketancmaheshwari at gmail.com
Mon Aug 1 13:58:34 CDT 2011
Lorenzo,
foreach.max.threads is kind of a throttle parameter that will control the
number of threads spawned when a foreach loop is encountered. For example:
foreach i in [0:10000]{
do_something();
can potentially lead to 10,000 concurrent threads being spawned
simultaneously which can lead to a jam in the system. The
foreach.max.threads param will limit it to the number specified. I normally
set it to less than 1000 or even less if I have nested foreach loops.
Hope that will help.
Ketan
On Mon, Aug 1, 2011 at 1:52 PM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
> foreach.max.threads. When I read the explanation I left somewhat
> perplexed.
> Do you mean threads in the sense of shared memory parallel processes here
> (then 1024 is very large number to me) or something else?
> Do you really mean saving memory, or I am not understand it?
> Thanks!
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110801/6bee2366/attachment.html>
More information about the Swift-user
