[Swift-user] Re: [beagle-users] [SWIFT on Beagle]Cannot Execute Correctly After Submitting Job
Weiyang Wang
frank.wang04 at gmail.com
Tue Apr 26 16:02:21 CDT 2011
OK Thanks.
I'm working on the makefile now, shall we meet tomorrow afternoon?
On Wed, Apr 27, 2011 at 5:00 AM, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
> Weiyang,
> Can you wait until tomorrow morning? I have to run off campus right now and
> I do not have the time to give you a complete reply.
> I should be able to look into your problem before noon or so.
> Lorenzo
> On Apr 26, 2011, at 2:14 PM, Weiyang Wang wrote:
> OK, I've "make clean" them and ow I switched to PrgEnv-cray, and going to
> use ftn to compile some .for files, although they are currently not
> recognizable by ftn. I want them to be compiled as F90 files (maybe I have
> to rename them first? )
> Could you kindly check out what's going on here within the makefile?
> ======= the first several lines====
> OBJDIR = objCSMINPUT
> FC = ftn
> FFLAGS = -O 3 -g
> INC = -I.
> MKDIR = mkdir -p
> DIRS = ../Common ../Input
> RM = rm -rf
> ===somewhere it starts compiling===
> # Create a list of all source files including folder name
> FSRC = $(foreach dir,$(DIRS),$(wildcard $(dir)/*.for))
> ## Create the list of all object files
> TOBJ = $(foreach dir, $(DIRS), $(subst .for,.o,$(notdir $(wildcard
> $(dir)/*.for))))
> # Create the path to store the object files
> FOBJ = $(foreach obj,$(TOBJ),$(OBJDIR)/$(obj))
> # Define the subfolders to look for source files
> vpath %.for ../Common ../Input
> $(OBJDIR)/%.o $(OBJDIR)/%.mod: %.for | $(OBJDIR)
> $(FC) $(FFLAGS) $(INC) -o $@ -c $<
> ../MINPT040.EXE : $(FOBJ)
> $(FC) $^ -o $@
> On Wed, Apr 27, 2011 at 2:43 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> Hello,
>> This indicates that the executable is not running on beagle compute nodes.
>> Could you kindly send the commandline and the path to your exe, data etc,
>> and I can try to do some testing using aprun and qsub.
>> Ketan
>> On Apr 26, 2011, at 1:26 PM, Weiyang Wang wrote:
>> In fact I switched to PrgEnv-gnu to compile it again on Beagle, and it
>> works if I run it plainly on login.beagle
>> On Tue, Apr 26, 2011 at 10:53 PM, Ti Leggett <leggett at ci.uchicago.edu>wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Was the code you're trying to run compiled on Beagle. IT looks to me like
>>> it was compiled on PADS. You must recompile your code on Beagle using the
>>> Cray compiler wrappers. Please refer to the Beagle FAQ on how to do this:
>>> http://www.ci.uchicago.edu/wiki/bin/view/Beagle/DevelopOnBeagle
>>> On Apr 26, 2011, at 9:34 AM, Weiyang Wang wrote:
>>> > Hello,
>>> > I've meet problems when submitting jobs using Swift.
>>> > My Command Line is like:
>>> > swift -sites.file ./mysites.xml -tc.file ./tc.data largescale.swift
>>> > My mysites.xml is like
>>> > <config>
>>> > <pool handle="pbs">
>>> > <execution provider="pbs" url="none" jobManager="local:pbs"/>
>>> > <profile namespace="globus" key="maxwalltime">0:20:00</profile>
>>> > <profile namespace="globus" key="workersPerNode">8</profile>
>>> > <profile namespace="globus" key="ppn">8</profile>
>>> > <!-- <profile namespace="globus"
>>> key="internalHostname">172.5.86.6</profile>-->
>>> > <profile namespace="globus" key="nodeGranularity">1</profile>
>>> > <profile namespace="globus" key="maxNodes">5</profile>
>>> > <profile namespace="karajan" key="jobThrottle">1.99</profile>
>>> > <profile namespace="karajan" key="initialScore">10000</profile>
>>> > <profile namespace="globus" key="project">CI-SES000031</profile>
>>> > <!--gridftp url="local://localhost" />-->
>>> > <filesystem provider="local"/>
>>> > <!--scratch>/home/frankwang/tmp</scratch>-->
>>> <workdirectory>/gpfs/pads/projects/CI-SES000031/csm/tempswiftwork</workdirectory>
>>> > </pool>
>>> > </config>
>>> > My tc.data is like,
>>> > pbs echo /bin/echo INSTALLED INTEL32::LINUX
>>> null
>>> > pbs sh /bin/bash INSTALLED INTEL32::LINUX
>>> null
>>> > In my swift script I'm running some gfortran compiled programs(I wrap
>>> my fortran programs in sh files), and in my error log file, it shows that
>>> > /gpfs/pads/projects/CI-SES000031/csm/DSSAT040.EXE: error while loading
>>> shared libraries: libgfortran.so.3: cannot open shared object file: No such
>>> file or directory
>>> > I didn't meet the same problem when I run these on PADS, and after I
>>> swap the module to PrgEnv-gnu when logging onto Beagle I can also run this
>>> DSSAT040.EXE.
>>> > My guess is, I submit the jobs to a Non-GNU Environment in Beagle.
>>> > How can I correct this?
>>> > Thank you.
>>> > Weiyang
>>> > _______________________________________________
>>> > beagle-users mailing list
>>> > beagle-users at ci.uchicago.edu
>>> > http://mail.ci.uchicago.edu/mailman/listinfo/beagle-users
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG/MacGPG2 v2.0.14 (Darwin)
>>> iEYEARECAAYFAk223FkACgkQ4RgdOxQVi0AVxgCeNmnQ0e2xgmIZjQ3vkot1SpWf
>>> H5MAnjS/VbEaH7vWSJFcSK+2hs1VHo4d
>>> =8FUi
>>> -----END PGP SIGNATURE-----
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110427/2e813ee1/attachment.html>
More information about the Swift-user
