[Swift-user] Re: [beagle-users] [SWIFT on Beagle]Cannot Execute Correctly After Submitting Job
Weiyang Wang frank.wang04 at gmail.com
Tue Apr 26 13:26:52 CDT 2011
In fact I switched to PrgEnv-gnu to compile it again on Beagle, and it works
if I run it plainly on login.beagle
On Tue, Apr 26, 2011 at 10:53 PM, Ti Leggett <leggett at ci.uchicago.edu>wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Was the code you're trying to run compiled on Beagle. IT looks to me like
> it was compiled on PADS. You must recompile your code on Beagle using the
> Cray compiler wrappers. Please refer to the Beagle FAQ on how to do this:
> http://www.ci.uchicago.edu/wiki/bin/view/Beagle/DevelopOnBeagle
> On Apr 26, 2011, at 9:34 AM, Weiyang Wang wrote:
> > Hello,
> > I've meet problems when submitting jobs using Swift.
> > My Command Line is like:
> > swift -sites.file ./mysites.xml  -tc.file ./tc.data largescale.swift
> > My mysites.xml is like
> > <config>
> > <pool handle="pbs">
> >     <execution provider="pbs" url="none" jobManager="local:pbs"/>
> >     <profile namespace="globus" key="maxwalltime">0:20:00</profile>
> >     <profile namespace="globus" key="workersPerNode">8</profile>
> >     <profile namespace="globus" key="ppn">8</profile>
> >     <!-- <profile namespace="globus"
> key="internalHostname">172.5.86.6</profile>-->
> >     <profile namespace="globus" key="nodeGranularity">1</profile>
> >     <profile namespace="globus" key="maxNodes">5</profile>
> >     <profile namespace="karajan" key="jobThrottle">1.99</profile>
> >     <profile namespace="karajan" key="initialScore">10000</profile>
> >     <profile namespace="globus" key="project">CI-SES000031</profile>
> >     <!--gridftp  url="local://localhost" />-->
> >     <filesystem provider="local"/>
> >     <!--scratch>/home/frankwang/tmp</scratch>-->
> <workdirectory>/gpfs/pads/projects/CI-SES000031/csm/tempswiftwork</workdirectory>
> > </pool>
> > </config>
> > My tc.data is like,
> > pbs             echo    /bin/echo       INSTALLED       INTEL32::LINUX
>  null
> > pbs             sh      /bin/bash       INSTALLED       INTEL32::LINUX
>  null
> > In my swift script I'm running some gfortran compiled programs(I wrap my
> fortran programs in sh files), and in my error log file, it shows that
> > /gpfs/pads/projects/CI-SES000031/csm/DSSAT040.EXE: error while loading
> shared libraries: libgfortran.so.3: cannot open shared object file: No such
> file or directory
> > I didn't meet the same problem when I run these on PADS, and after I swap
> the module to PrgEnv-gnu when logging onto Beagle I can also run this
> DSSAT040.EXE.
> > My guess is,  I submit the jobs to a Non-GNU Environment in Beagle.
> > How can I correct this?
> > Thank you.
> > Weiyang
> > _______________________________________________
> > beagle-users mailing list
> > beagle-users at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/beagle-users
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG/MacGPG2 v2.0.14 (Darwin)
> iEYEARECAAYFAk223FkACgkQ4RgdOxQVi0AVxgCeNmnQ0e2xgmIZjQ3vkot1SpWf
> H5MAnjS/VbEaH7vWSJFcSK+2hs1VHo4d
> =8FUi
> -----END PGP SIGNATURE-----
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110427/6ef50349/attachment.html>
More information about the Swift-user mailing list
