[Swift-user] swift understanding/tutorial
Daniel S. Katz
dsk at ci.uchicago.edu
Thu Oct 14 10:19:01 CDT 2010
I'm just working through the swift examples in the tutorial (http://www.ci.uchicago.edu/swift/guides/tutorial.php). Some thoughts/comments follow...
This is confusing to me. If the "file to use" is t, it feels to me that t should be an input parameter, as it tells greeting where to write its output.
It seems that the following should work:
type messagefile;
app () greeting(messagefile t) {
echo "Hello, world!" stdout=@filename(t);
messagefile outfile <"hello.txt">;
greeting(outfile );
but it doesn't, as it appears procedures require a return value.
So I next tried the following, which seemed like it should work:
type messagefile;
int useless;
app (int x) greeting(messagefile t) {
useless = greeting(outfile );
but it also didn't, at least not when hello.txt doesn't already exist. The command and output are:
tmp:swift dsk$ swift check.swift
Swift 0.9 swift-r2860 cog-r2388
RunID: 20101014-1003-tq1hn851
Progress:
Failed to transfer wrapper log from check-20101014-1003-tq1hn851/info/4 on localhost
Progress: Stage in:1
Failed to transfer wrapper log from check-20101014-1003-tq1hn851/info/6 on localhost
Failed to transfer wrapper log from check-20101014-1003-tq1hn851/info/8 on localhost
Execution failed:
Exception in echo:
Arguments: [Hello, world!]
Host: localhost
Directory: check-20101014-1003-tq1hn851/jobs/8/echo-8dycd50k
stderr.txt:
stdout.txt:
Caused by:
File not found: /Users/dsk/Desktop/swift-0.9/examples/swift/./hello.txt
So, clearly there is something about Swift that I'm missing, and that I'm not gathering from the tutorial web page.
I'm writing this with two goals - first, to figure out what basic concept I'm missing, and second, to perhaps expand the tutorial web page so that others don't have this issue.
Thanks.
Dan
Daniel S. Katz
University of Chicago
(773) 834-7186 (voice)
(773) 834-3700 (fax)
d.katz at ieee.org or dsk at ci.uchicago.edu
http://www.ci.uchicago.edu/~dsk/
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20101014/b419661f/attachment.html>
Name: Screen shot 2010-10-14 at 9.51.27 AM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20101014/b419661f/attachment.png>
More information about the Swift-user
