[Swift-user] foreach dilemma (was Re: Heap space being exhausted)
Allan Espinosa aespinosa at cs.uchicago.edu
Fri Oct 22 16:59:19 CDT 2010
I looked again at my mainloop to figure out why are there not enough
jobs from being called in the inner  loop despite the huge number of
availble workers.
Answer: not enough ready jobs! :(
I set my foreach.max.threads=100 so there can only be 100 outerloop
jobs (6k total)  at a time.  these outerloop jobs is a dependency for
the innerloop jobs so there will be a slow start of the number of
ready jobs.
Another bottleneck is my data mapper wrapped as an app.  since it's
only a local job, the default throttle is set to 4 at a time. I made
this work around because of synchronization issues on mappers a few
months ago. I think it would be good to look at the previous version
of my workflow again.
-Allan
2010/6/2 Mihael Hategan <hategan at mcs.anl.gov>:
> On Wed, 2010-06-02 at 19:03 -0500, Allan Espinosa wrote:
>> My Cybershake workflow.  its basically a 2 level for loop with varying
>> inner  loop sizes.
>> foreach i in (~4k elements) {
>>   x = f();
>>   foreach (20-2k elements) {
> Yep. You have a winner. Max threads = 1024 * 1024.
> You should adjust that parameter accordingly. I.e. foreach.max.threads =
> sqrt(maxTotalThreads).
>> > On Wed, 2010-06-02 at 18:40 -0500, Allan Espinosa wrote:
>> >> I tried a HEAPMAX of 4GB.
>> >> No memory problems so far :)
>> > Still odd. What's the swift script?
>> > I'm asking because foreach.max.threads should work, but it applies to
>> > each individual foreach rather than globally.
>> >> > On Wed, 2010-06-02 at 17:47 -0500, Mihael Hategan wrote:
>> >> >> On Wed, 2010-06-02 at 17:32 -0500, Allan Espinosa wrote:
>> >> >> > btw
>> >> >> > foreach.maxthreads=1024
>> >> >> or more heapmax.
>> >> > Ehm, I though you found a solution :)
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user mailing list
