[Swift-user] tutorial issue 9
Daniel S. Katz
dsk at ci.uchicago.edu
Thu Oct 14 13:14:44 CDT 2010
The code in example 3.9 on http://www.ci.uchicago.edu/swift/guides/tutorial.php doesn't seem to work.
When I try to run it, I get:
tmp:swift dsk$ swift iterate.swift
Could not start execution.
variable a has multiple writers.
There are some other issues with this example, too:
1. simple_mapper is not introduced or explained; it just shows up.
2. @extractint is not introduced or explained; it just shows up.
3. trace() is not introduced or explained; it just shows up.
4. based on what I learned from example 3.3, it seems I should be able to anonymous files here - is this correct? If so, would I just change
counterfile a[] <simple_mapper;prefix="foldout">;
to
counterfile a[];
Can I use an array of anonymous files like this?
Dan
Daniel S. Katz
University of Chicago
(773) 834-7186 (voice)
(773) 834-3700 (fax)
d.katz at ieee.org or dsk at ci.uchicago.edu
http://www.ci.uchicago.edu/~dsk/
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20101014/4563f040/attachment.html>
More information about the Swift-user
