[Swift-user] Argument list to long
Jonathan Monette jon.monette at gmail.com
Sun Oct 10 20:08:06 CDT 2010
  Ok.  Thanks.  That got it for me.
#!/bin/bash
"/home/jonmon/Library/Montage/bin/mProject" "-X
raw_dir/2mass-atlas-000315s-j0330245.fits
proj_dir/proj_2mass-atlas-000315s-j0330245.fits|header.hdr"
1>"stdout.txt" 2>"stderr.txt"
Why is there at "|" right before the parameter header?  If I were to run
this by hand in a shell, the command would be
/home/jonmon/Library/Montage/bin/mProject -X
proj_dir/proj_2mass-atlas-000315s-j0330245.fits header.hdr
Is this how it is supposed to be? I thought | in bash meant pipe output
from left into whats on the right?
On 10/10/10 7:55 PM, Mihael Hategan wrote:
> On Sun, 2010-10-10 at 19:51 -0500, Jonathan Monette wrote:
>> This environment variable can be set to anything? As long as it is not
>> null? For instance in my login shell I can execute the command:
>> export SWIFT_GEN_SCRIPTS=1
>> and it will generate these run.sh?
> Not unless the jobs magically inherit your login environment.
> I.e., set it in sites.xml for each site you want this to work on.
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user mailing list
