[Swift-user] Argument list to long
Jonathan Monette
jon.monette at gmail.com
Sun Oct 10 19:51:21 CDT 2010
This environment variable can be set to anything? As long as it is not
null? For instance in my login shell I can execute the command:
export SWIFT_GEN_SCRIPTS=1
and it will generate these run.sh?
On 10/10/10 7:49 PM, Mihael Hategan wrote:
> On Sun, 2010-10-10 at 19:42 -0500, Jonathan Monette wrote:
>> Is _swiftseq the wrapper that actually executes the app?
> That would be _swiftwrap not _swiftseq.
>> The app in
>> Swift eventually has to be executed in the shell correct? What I am
>> trying to see is what is that command line that is submitted to the shell.
> You could add an environment variable called "SWIFT_GEN_SCRIPTS" and set
> it to some non-null value. That will generate run.sh files in the
> relevant job directories which would contain all that information (and
> can be used to re-run individual apps).
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
