[Swift-user] Argument list to long
Mihael Hategan
hategan at mcs.anl.gov
Sun Oct 10 17:12:07 CDT 2010
I'm good. Try now.
On Sun, 2010-10-10 at 17:09 -0500, Jonathan Monette wrote:
> Ok. If you need anymore of my log files I can gather some up for you.
> On 10/10/10 5:05 PM, Mihael Hategan wrote:
> > Ok. I can reproduce this.
> > It means it wasn't the previous problem.
> > On Sun, 2010-10-10 at 15:51 -0500, Jonathan Monette wrote:
> >> cog is at revision 2910 and swift is at revision 3676. I have added
> >> "wrapper.parameter.mode=files" into my swift.properties. Here is the
> >> output to the screen:
> >> RunID: 20101010-1548-ky63yf59
> >> Progress:
> >> Progress:Progress:Progress: uninitialized:4
> >> uninitialized:3 uninitialized:4
> >> Progress: Selecting site:4118 Initializing site shared directory:1
> >> Progress: Selecting site:4017 Stage in:101 Submitting:1
> >> original callback URI is http://169.254.95.119:37936
> >> callback URI has been overridden to http://192.5.86.6:37936
> >> Progress: Selecting site:4017 Submitted:101 Active:1
> >> Failed to transfer wrapper log from
> >> unrectified-20101010-1548-ky63yf59/info/k on pads
> >> unrectified-20101010-1548-ky63yf59/info/7 on pads
> >> unrectified-20101010-1548-ky63yf59/info/6 on pads
> >> Execution failed:
> >> unrectified-20101010-1548-ky63yf59/info/g on pads
> >> unrectified-20101010-1548-ky63yf59/info/j on pads
> >> unrectified-20101010-1548-ky63yf59/info/t on pads
> >> Exception in mProject:
> >> Arguments: [-X, raw_dir/2mass-atlas-000218s-j0150091.fits,
> >> proj_dir/proj_2mass-atlas-000218s-j0150091.fits, header.hdr]
> >> Host: pads
> >> Directory: unrectified-20101010-1548-ky63yf59/jobs/6/mProject-6g4u6zzj
> >> stderr.txt:
> >> stdout.txt:
> >> Caused by:
> >> Job failed with an exit code of 254
> >> Cleaning up...
> >> After that coasters just cancels the other jobs.
> >> On 10/10/10 3:26 PM, Mihael Hategan wrote:
> >>> Can you re-try the current thing with parameter.mode=files and the
> >>> latest trunk first?
> >>> On Sun, 2010-10-10 at 15:09 -0500, Jonathan Monette wrote:
> >>>> Also, how do I declare the image list as an external type?
> >>>> On 10/9/10 3:02 PM, Mihael Hategan wrote:
> >>>>> On Sat, 2010-10-09 at 20:00 +0000, jon.monette at gmail.com wrote:
> >>>>>> What do you mean by manage them independently?
> >>>>> I'm not sure. I guess it's whether swift can skip staging them in and
> >>>>> stop keeping track of them. But that's pretty much the same as saying
> >>>>> they are "external", so it seems circular.
More information about the Swift-user
