[Swift-user] Argument list to long
Mihael Hategan hategan at mcs.anl.gov
Sun Oct 10 17:05:54 CDT 2010
Ok. I can reproduce this.
It means it wasn't the previous problem.
On Sun, 2010-10-10 at 15:51 -0500, Jonathan Monette wrote:
> cog is at revision 2910 and swift is at revision 3676.  I have added
> "wrapper.parameter.mode=files" into my swift.properties.  Here is the
> output to the screen:
> RunID: 20101010-1548-ky63yf59
> Progress:
> Progress:Progress:Progress:  uninitialized:4
>    uninitialized:3  uninitialized:4
> Progress:  Selecting site:4118  Initializing site shared directory:1
> Progress:  Selecting site:4017  Stage in:101  Submitting:1
> original callback URI is http://169.254.95.119:37936
> callback URI has been overridden to http://192.5.86.6:37936
> Progress:  Selecting site:4017  Submitted:101  Active:1
> Failed to transfer wrapper log from
> unrectified-20101010-1548-ky63yf59/info/k on pads
> unrectified-20101010-1548-ky63yf59/info/7 on pads
> unrectified-20101010-1548-ky63yf59/info/6 on pads
> Execution failed:
> unrectified-20101010-1548-ky63yf59/info/g on pads
> unrectified-20101010-1548-ky63yf59/info/j on pads
> unrectified-20101010-1548-ky63yf59/info/t on pads
> Exception in mProject:
> Arguments: [-X, raw_dir/2mass-atlas-000218s-j0150091.fits,
> proj_dir/proj_2mass-atlas-000218s-j0150091.fits, header.hdr]
> Host: pads
> Directory: unrectified-20101010-1548-ky63yf59/jobs/6/mProject-6g4u6zzj
> stderr.txt:
> stdout.txt:
> Caused by:
>      Job failed with an exit code of 254
> Cleaning up...
> After that coasters just cancels the other jobs.
> On 10/10/10 3:26 PM, Mihael Hategan wrote:
> > Can you re-try the current thing with parameter.mode=files and the
> > latest trunk first?
> > On Sun, 2010-10-10 at 15:09 -0500, Jonathan Monette wrote:
> >> Also, how do I declare the image list as an external type?
> >> On 10/9/10 3:02 PM, Mihael Hategan wrote:
> >>> On Sat, 2010-10-09 at 20:00 +0000, jon.monette at gmail.com wrote:
> >>>> What do you mean by manage them independently?
> >>> I'm not sure. I guess it's whether swift can skip staging them in and
> >>> stop keeping track of them. But that's pretty much the same as saying
> >>> they are "external", so it seems circular.
More information about the Swift-user mailing list
