[Swift-user] Argument list to long
Jonathan Monette
jon.monette at gmail.com
Sat Oct 9 14:47:19 CDT 2010
app ( Table img_tbl ) mImgtbl( Image imgs[] )
mImgtbl @dirname( imgs[0] ) @img_tbl;
On 10/9/10 2:45 PM, Mihael Hategan wrote:
> Can you post the app procedure from your swift file that invokes
> mImgtbl?
> Mihael
> On Sat, 2010-10-09 at 13:44 -0500, Jonathan Monette wrote:
>> My bad. Forgot to put them in the home directory. They are there now
>> On 10/9/10 1:41 PM, Mihael Hategan wrote:
>>> And these files would be where exactly?
>>> On Mon, 2010-10-04 at 21:48 -0500, Jonathan Monette wrote:
>>>> Sure can. I have two log files in my home directory on the ci
>>>> machines. ~jonmon
>>>> One is rather large(20M) and that is the one with
>>>> "wrapper.paramter.mode=files" not set. The other is about 4.7M and that
>>>> one has "wrapper.parameter.mode=files" set.
>>>> You should have permissions to read them.
>>>> On 10/04/2010 09:44 PM, Mihael Hategan wrote:
>>>>> Ok. I believe that now you hit a bug in swift. Luckily there might be
>>>>> something we can do about that.
>>>>> May I have the log file?
>>>>> On Mon, 2010-10-04 at 21:39 -0500, Jonathan Monette wrote:
>>>>>> By setting "wrapper.parameter.mode=files" I get "failed to transfer
>>>>>> wrapper logs". Here is my swift.properties file.
>>>>>> execution.retries=0
>>>>>> sitedir.keep=true
>>>>>> status.mode=provider
>>>>>> //wrapper.log.always.transfer=true
>>>>>> foreach.maxthreads=1024
>>>>>> I have tried this with "wrapper.log.always.transfer=true" both commented
>>>>>> and uncommented still get the same error.
>>>>>> On 10/04/2010 08:25 PM, Mihael Hategan wrote:
>>>>>>> Groovy. Then set "wrapper.parameter.mode=files" in swift.properties.
>>>>>>> On Mon, 2010-10-04 at 18:59 -0500, Jonathan Monette wrote:
>>>>>>>> well if I am understanding the problem the input list will be about
>>>>>>>> 4100 files and the output list will be a single file (unless Swift adds
>>>>>>>> more input and output files). I do not think I am using provider
>>>>>>>> staging though. In my swift.properties i do not set the
>>>>>>>> use.provider.staging option and in etc/swift.properties
>>>>>>>> use.provider.staging is set to false.
>>>>>>>> On 10/4/10 6:46 PM, Mihael Hategan wrote:
>>>>>>>>> On Mon, 2010-10-04 at 18:39 -0500, Jonathan Monette wrote:
>>>>>>>>>> Yes. I have to make sure that all 4100 files are created before the
>>>>>>>>>> failing app can execute.
>>>>>>>>>> The writeData() way seems like a hack to get around the problem is Swift
>>>>>>>>>> but I will try it out and see if my script completes.
>>>>>>>>>> Mihael: pasted below is the stack trace that was generated in the log file.
>>>>>>>>> Yeah. It's what Mike says.
>>>>>>>>> But it's not the app arguments. Instead, I'm guessing it's the
>>>>>>>>> input/output file lists.
>>>>>>>>> There was a scheme in non-provider-staging swift to pass these things in
>>>>>>>>> lists, but I'm guessing you are using provider staging. Perhaps some
>>>>>>>>> mode to automatically do this for large numbers of arguments is in
>>>>>>>>> order.
>>>>>>>>> Mihael
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
