[Swift-user] Argument list to long
Jonathan Monette jon.monette at gmail.com
Sat Oct 9 13:44:38 CDT 2010
  My bad.  Forgot to put them in the home directory.  They are there now
On 10/9/10 1:41 PM, Mihael Hategan wrote:
> And these files would be where exactly?
> On Mon, 2010-10-04 at 21:48 -0500, Jonathan Monette wrote:
>> Sure can.  I have two log files in my home directory on the ci
>> machines.  ~jonmon
>> One is rather large(20M) and that is the one with
>> "wrapper.paramter.mode=files" not set.  The other is about 4.7M and that
>> one has "wrapper.parameter.mode=files" set.
>> You should have permissions to read them.
>> On 10/04/2010 09:44 PM, Mihael Hategan wrote:
>>> Ok. I believe that now you hit a bug in swift. Luckily there might be
>>> something we can do about that.
>>> May I have the log file?
>>> On Mon, 2010-10-04 at 21:39 -0500, Jonathan Monette wrote:
>>>> By setting "wrapper.parameter.mode=files" I get "failed to transfer
>>>> wrapper logs".  Here is my swift.properties file.
>>>> execution.retries=0
>>>> sitedir.keep=true
>>>> status.mode=provider
>>>> //wrapper.log.always.transfer=true
>>>> foreach.maxthreads=1024
>>>> I have tried this with "wrapper.log.always.transfer=true" both commented
>>>> and uncommented still get the same error.
>>>> On 10/04/2010 08:25 PM, Mihael Hategan wrote:
>>>>> Groovy. Then set "wrapper.parameter.mode=files" in swift.properties.
>>>>> On Mon, 2010-10-04 at 18:59 -0500, Jonathan Monette wrote:
>>>>>> well if I am understanding the problem the input list will be about
>>>>>> 4100 files and the output list will be a single file (unless Swift adds
>>>>>> more input and output files).  I do not think I am using provider
>>>>>> staging though.  In my swift.properties i do not set the
>>>>>> use.provider.staging option and in etc/swift.properties
>>>>>> use.provider.staging is set to false.
>>>>>> On 10/4/10 6:46 PM, Mihael Hategan wrote:
>>>>>>> On Mon, 2010-10-04 at 18:39 -0500, Jonathan Monette wrote:
>>>>>>>> Yes.  I have to make sure that all 4100 files are created before the
>>>>>>>> failing app can execute.
>>>>>>>> The writeData() way seems like a hack to get around the problem is Swift
>>>>>>>> but I will try it out and see if my script completes.
>>>>>>>> Mihael: pasted below is the stack trace that was generated in the log file.
>>>>>>> Yeah. It's what Mike says.
>>>>>>> But it's not the app arguments. Instead, I'm guessing it's the
>>>>>>> input/output file lists.
>>>>>>> There was a scheme in non-provider-staging swift to pass these things in
>>>>>>> lists, but I'm guessing you are using provider staging. Perhaps some
>>>>>>> mode to automatically do this for large numbers of arguments is in
>>>>>>> order.
>>>>>>> Mihael
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user mailing list
