[Swift-user] Question: Setting environment variables
Michael Wilde
wilde at mcs.anl.gov
Fri May 28 12:39:57 CDT 2010
----- "Taleena R Sines" <trsines0 at frostburg.edu> wrote:
> What needs to be entered in the data file and what needs to be entered
> in the actual script?
> Thank you, I will post to the list
Lets say you want to invoke the program "myprog" from a Swift script.
You write an "app" function called myprog() in the .swift file, and in tc.data you add entries to specify the pathname of that program on each "site" (e.g., cluster) that you want to compute on.
This is described in the Swift Tutorial, in sec 3.2, Adding Another Application:
http://www.ci.uchicago.edu/swift/guides/tutorial.php#id2884021
- Mike
> Taleena R. Sines
> Major: Computer Science
> -----Original Message-----
> From: Michael Wilde [ mailto:wilde at mcs.anl.gov ]
> Sent: Fri 5/28/2010 1:04 PM
> To: Taleena R Sines
> Cc: Swift User
> Subject: Re: [Swift-user] Question: Setting environment variables
> Did you make sure that all the fields are separated by a tab
> character, not spaces?
> If that was not the cause, I'll need to double-check and test my
> syntax.
> (please send all your replies back to the swift-user list).
> - Mike
> > I inserted that line and it is giving me the error:
> > unexpected token: /
> > Taleena R. Sines
> > Sent: Fri 5/28/2010 12:48 PM
> > To: Taleena R Sines
> > Cc: Swift User
> > For:
> > setenv CODE_HOME /trsines/code/my_code
> > the example:
> > localhost myapp /usr/bin/env none none ENV::myenvvar="something";
> > would become:
> > localhost myapp /usr/bin/env none none ENV::CODE_HOME
> > ="/trsines/code/my_code";
> > - Mike
> > > If my code in c-script is :
> > > What would actually be typed in the swift-script in place of that?
> > > thank you
> > > T. R. Sines
> > > From: wilde at mcs.anl.gov [ mailto:wilde at mcs.anl.gov ]
> > > Sent: Fri 5/28/2010 12:15 PM
> > > To: Taleena R Sines
> > > Cc: swift-user at ci.uchicago.edu
> > > Taleena,
> > > You set env vars for a given app in the tc.data file using an "Env
> > > profile":
> > > http://www.ci.uchicago.edu/swift/guides/userguide.php#profile.env
> > > For example:
> > > Thats not real clear in the User Guide - we will fix that.
> > > - Mike
> > > > Hello,
> > > > In swift, how would I set an environment variable?
> > > > For example, in a c-script:
> > > > setenv WKDIR /user/bin
> > > > would translate to swift how?
> > > > Thank you
> > > > T. R. Sines
> > > > _______________________________________________
> > > > Swift-user mailing list
> > > > Swift-user at ci.uchicago.edu
> > > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > > Michael Wilde
> > > Computation Institute, University of Chicago
> > > Mathematics and Computer Science Division
> > > Argonne National Laboratory
> > Michael Wilde
> Michael Wilde
Michael Wilde
More information about the Swift-user
