[Swift-user] handling prestaged data on multiple sites
Justin M Wozniak wozniak at mcs.anl.gov
Tue May 4 13:25:23 CDT 2010
Collective Data Management.  The general idea is to exploit user
information to improve data access for Swift scripts.  Specifically, you
can plug in new data access mechanisms without modifying the application
script- most of the details are specified in a small user configuration
file (analogous to tc.data) and managed by extensions to the wrapper
script (_swiftwrap, etc.).  Dynamically renaming data sources is a big
part of it.
The framework is there in trunk and a few methods are implemented,
including a staging-skipping DIRECT method, a BROADCAST, and an
output-aggregating GATHER method.  I can easily put in a new method for
Globus.org, I'll take a look and get back to you, Allan.
On Tue, 4 May 2010, Ian Foster wrote:
> What is CDM?
> Ian
> On May 4, 2010, at 10:45 AM, Allan Espinosa wrote:
>> Hi Justin,
>> I used globus.org's data movement service.
>> Right now I have the dataset on these OSG sites:
>> ff-grid.unl.edu:/panfs/panasas/CMS/data/scec/RuptureVariations/*
>> tuscany.med.harvard.edu:/osg/storage/data/engage/scec/RuptureVariations/*
>> On Mar, 2010-05-04 at 10:20 -0500, Justin Wozniak wrote:
>>> This is probably a good use case for CDM.  How did you prestage the
>>> files?
>>> ______________________________________________________________________
>>> Hi,
>>> I prestaged 11k small files (total ~2GB) to two sites. if I were just
>>> computing on 1 site, i can just place hardwired strings of absolute
>>> pathnames to disable staging. I was originally thinking of passing
>>> '$OSG_DATA' variable names since the app functions wraps to bash
>>> shell
>>> scripts. this backfired because swift passes these string args
>>> literally.
>>> any other recommended approaches?
>>> thanks!
>>> -Allan
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
Justin M Wozniak
More information about the Swift-user mailing list
